loading
NYC writer KATSU demonstrates the functionality of the latest tool from the Graffiti Research Lab: The High Writer. Drawing on previous paint-pole designs from innovators like Barry McGee and the Citizens Against Ugly Street Spam, the High Writer is a tool that amplifies the scale and height of marks rendered with a spray can. The high writer is easily constructed from materials available at Home Depot and your local bike shop. All praise be to the Eyebeam R&D OpenLab.
To view high writer photos on flickr Click here.
Benefit Art Show and Auction for Daniel McGowan
The prototype High Writer will be auctioned off at the "If They Come for You in the Morning" Benefit Gallery Show for Daniel McGowan hosted by Visual Resistance. All proceeds from the show will benefit the legal fund of environmental and social justice activist Daniel McGowan.
Thursday, July 27 & Friday, July 28, 2006, 5-10pm
ABC No Rio, 156 Rivington St, Lower East Side, NYC
Art Auction on Ebay
The AMERIKA1 mural by KATSU pictured in the video is currently up for bid on ebay. Click here to place your bid. Now lets learn how to write naturally high.
Step 1: Parts, Materials and Tools
Parts:
All of these parts can all be purchased at the local Home Depot or art supply store. Look for the bike parts at used cycle shops.
Hardware store
12-15 foot painter's pole
3 pole extension set
Paint edger attachment
Handyboard sheet
Balsa wood blocks
2-inch #8-32 bolts, nuts and washers
2.5-inch #8-32 bolts, nuts and washers
3/4-inch #8-32 bolts, nuts and washers
1-inch #8-32 bolts, nuts and washers
3-inch 360 swivel coaster
3-inch C-clamps
Transparent tape
JB Weld
5-minute epoxy
Bike shop
Bike V-Brake system: hand lever, bike cable and one brake arm/pad
bike water bottle holder
Art store
Spay-paint can
NY fat caps
Tools:
MItre box
Mitre box saw
screwdriver set
pliers
box cutter
hex key set
measuring tape
cordless drill and 13/64th drill bits
Step 2: Make the head
If you're going to make the Hight Writer you might as well start with the head. The head consists of the water bottle holder that secures the paint can, the mechanisms that spray the can and counter-weights.
Fabricate the Head
First you must fabricate the wood risers and support panel.
1. Download this PDF file and print it actual scale. Use it as a template to help you (a) cut a 6-inch by 13.5-inch panel out of the 1/8th-inch handyboard and (b) drill a number of holes using a 3/16th or 13/64th drill bit.
2. Cut two riser blocks from the balsa wood using a mitre box and saw.
The wheel riser block will be:
2.35-inches x 2-inches x 1.35-inches
The brake arm riser will be:
2-inches x 2-inches 1.2-inches
3. Using the holes in the panel as your template, mark and drill matching sets of holes in the riser blocks.
Assemble the head
Use the #8-32 bolts and nuts, using washers where appropriate, to attach both risers, edger attachment, brake arm and water bottle holder. If your water bottle doesn't line up with the generic holes in the template you will have to experiment with the location of the bottle once you assemble the rest of the head. You can leave the actual brake pad on the arm use it as the contact point with the spray-can cap, or you can make your own contact surface like we did with a 2-inch x 2-inch piece of 1/4-inch Plexiglas. Check the attached images and photo notes for more specific info.
Tighten the C-clamps down on the bottom of the support panel as pictured. This help the system stay flush to the wall.
Step 3: Make the tail
Fabricate the Tail
To build the tail and connect it to the head you will need to fabricate a few parts: the cable, the hand lever and the cable constraints.
1. To make a night writer with a full extension of less than 10-feet you can just go to your local bike shop and ask for a tandem bike brake cable. For lengths greater than 10-feet, I don't know any way other than to make your own cable. (a) Get your local bike repair guy to cut you as much bike cable housing as you got pole to extend. (b) Cut the end connector features at either end of an old bike break cable. (b) Go to the Home Despot and get 1/16th or smaller aircraft cable and JB Weld. (c) Go get a coffee. save the stirrer. (d) Slide your aircraft cable into the cable housing. Experiment with your pole in order to get the right length of housing and cable. (e) Mix the two part JB Weld with the coffee stirrer. Scoop up some of the epoxy into the stirrer. Cut a small section of the epoxy filled stirrer around a 1/4-inch in length. Stick two ends of aircraft cable or bike break cable into the two ends of the stirrer. Let the connection dry for at least 12 hours before use.
Assemble the Tail
2. To make the hand lever that controls the spray-can remotely, you simply need to slide the bike lever over the base of the extension pole and connect the bike cable to the hand lever using the round retention feature on the end of the cable. If you are using a smaller diameter pole, less than 1-inch, this will not be a problem. For those using larger diameter poles (1" dia. or larger), you will need to modify the pole. I modified my Mr. Long Arm painters pole, by removing the rubber grip at the end. This reveals a hollow cavity inside the pole. I epoxied a threaded junction inside this inner cavity and screwed-in a cut section of 0.90-inch diameter extension pole. The hand lever slides easily over this small section of extension pole.
3. For the bike cable to work, you will need to secure the cable housing at a minimum of two locations: the top and bottom of the pole. While a number of ways exist to constrain the cable housing, I use transparent tape. Just wrap the housing and pole with tape. Remember to leave a service loop so the telescoping pole can extend to its full length. Check out the attached images to get more details.
4. Once you have welded the cable to its intended length, attached the hand lever, inserted the cable retention feature into the lever and constrained the cable housing, you can insert the other cable retention feature into the brake arm. You should initially leave a good deal of slack in the cable so you don't inadvertently trigger the paint can during assembly.
Step 4: How to write high
Before you use the High Writer to communicate your message on a large scale, you will need to: practice writing with the high writer, prepare and load a spray-paint can and fine tune the bike cable and hand lever to make sure you can spray the can by squeezing the lever. If the cable is too tight it will trigger the can to spray inadvertently. If it is too slack, it won't trigger at all when you squeeze.
Preparing and Loading a Spray-Paint Can
To prepare a spray-paint can, you need to make a ball of transparent tape. You can then tape the small crumpled ball of tape to the front of the paint can. Then continue to wrap the paint can with transparent tape until it looks like the paint can is pregnant on one side. This tape is needed to thicken the can and thus secure it in the water bottle holder that is slightly over-sized relative to the can. The paint can should go into the water bottle holder with the tape lump pointing toward the front.
High Writer Calibration
The High Writer can be fine tuned by loosening the hand lever hex bolt and sliding the lever along the length of the pole. The opposite end of the cable should be secured by the retention feature on the brake arm. This should increase and decrease tension on the cables Experiment with the right amount of tension necessary to trigger the can to spray when you pull the handle.
Using the High Writer
In order to use the high writer you should treat it like a giant paint brush. The swivel wheel allows you to rest the majority of the weight of the High Writer against the wall. You don't need to lift the wheel off the wall to most efficiently operate it. You just release the hand lever when you want the writer to stop spraying.
Good Luck.
I don't get why people are assaulting the comment box, but I think this really shows an incredible degree of ingenuity and artistic passion. Go for it man, I hope to see some high-rise art in Philly. Great work.<br />
put a butane torch on the end. be good for hunting ducks, you wouldn't need to shoot them, just pick them up and eat 'em!
Lol.<br />
it is simply art there should not be this much debate on it and in many places austria places in france for example this is totally legal
Graffiti is another form of "freedom of press, expression, etc." that the first amendment gives to us, so everybody may say what they like on this instructable, cause you have that right, but when you start hurting feelings you don't have that right. so be kind and don't be un-patriotic you greedy, selfish single-minded people. nice instructable though, don't think it will be easy for transport though. :D
What I like about this is that it keeps the criminals preoccupied and his hands busy so I am free to come up behind them and kick their balls up through the top of their head for tagging something that doesn't belong to them. Fun indeed.
I love how the haters get so angry about this...the funny thing is that they have no idea of the difference between gang tags and graffiti art.
If you are painting on something that does not belong to you, or you were not contracted to do it, there is no difference. If you are painting something that you paid for, something that actually belongs to you, have at it. Art is subjective, and some of us "haters" think your "art" looks like crap and do not want to look at it all over our buildings.
Stop being such a douch. You bitched about my exaust thing, and now this. Just deal with the fact that you can't control society, unless you decide you want to threaten or kill people. once again, you sir, may go F**k yourself
So tell me, what makes you think you can roam around in society vandalizing other peoples' property, and disrupting others' peace and quiet? Did you once ever stop and think that maybe people don't want to look at your crap or listen to your obnoxiously loud vehicle? Did the universe suddenly start revolving around you? Attitudes like yours will eventually land you in jail.
It's <strong>Steal</strong> dipshit. Not <strong>steel</strong>. That is a type of metal.<br/>
what about the corporate vandalism we all live with everyday? The billboards, signs on buses, fliers and posters which litter walls and streets often put up with harmful glues? Why should a corporation like McDonald's have the right to decide what the aesthetic of our environment is? Do you really want to look at garish and unsightly advertisements which demean our intelligence and objectify us? Did the universe suddenly start revolving around advertising? Attitudes like yours have put us in the social and economic positions we are now.
amen brother iv bin saying the saim thing for years
what makes you think that you could kick anyone in the balls when there doing something thats more fun than what your doing
First off, I dont spray paint walls, thought I'd clear that up. and, attitudes like mine will land me in jail? .... well thinking that the world should be perfect and should conform to everyone elses standards isnt going to get you anywhere
Hey "jesus"- It looks like you seem to have an identity problem. Why have you decided to call yourself Jesus? Do you value the real Jesus? Those who do would never speak to anyone as you just did. Chew on that for awhile.
What are fat caps?
Generically, 'fat caps' (or graf caps) are spray can nozzles modified for different spray patterns... fat cap in the nongeneric sense is a cap with a nozzle that sprays a wide line
WOULD IF THE WORLD HAD NO ADVERTISING JUST ART? Ibanezfoo is clue less. kicking some body in the balls makes you a criminal jast as much or more than a graffiti righter.
lol
weoooow, gonna stick to 'em rooftops or my pot to get high
Having to tape up the can is a big time waster. Replace the water bottle holder with a small platform to support the can [think scrap of wood], and use a velcro strap to hold the can in place. This also makes it quick change for different colors.
Super ILL production! This will keep the buffing at bay, plus you could maybe add a multiple can holder/sprayer, so you could get triple the outline or fill lots of fun!!!!!!
I'd replace the tape buildup to hold the spraycan snug with loops of bike innertube or surgical tubing. It wouldn't have to be redone each time you needed to reload and it would make it easier to get the nozzle in the same position each time
Impressive piece. You guys keep surprising me.
There from Montana Gold. www.montan-paint.com
heh.. cool
About This Instructable
27,525views
39favorites
License:
More by resistor:The High Writer
Add instructable to:
