In this tutorial, I will show you how to digitally design and build a dollhouse using laser cut materials and resin-cast parts. These techniques will allow you to reproduce your parts for limited run production if you are so inclined. A little back-story: my father sells dollhouses built strictly by-hand and designed with pen & paper. This was my attempt to replicate one of his houses by using modernized techniques to create templates that would allow us to rapidly reproduce his designs.
In many ways, the dollhouse was built like a prefabricated home. We began with the foundation and assembled the house from laser cut facades atop it. This guide will take you through the process of:
- Planning
- Façade Preparation & Laser Cutting
- Terrain Modeling
- Terrain Molding & Casting
- Terrain Painting
- Façade Construction
- Chimney Modeling
- Chimney Molding & Casting
- Chimney Painting
- Final Assembly
Please note that the Materials and Tools listed at the beginning of each chapter will only pertain to that particular phase of the project. Keep this in mind as you budget your expenses.
Remove these ads by
Signing UpStep 1: Chapter 1- Planning- 1: Concepts and Measurements
- Pen & Paper
- Ruler
- Sketchup (Pro)
- 3DS Max
Begin by brainstorming your design with thumbnail sketches of your house.
Take note of your edge dimensions and be sure to allow 1/4 inch of space for your walls around the perimeter of the house, the interior wall, and second story floor. The floors, stairs, roof, and Tudor trim parts will be laser cut from sheets of plywood because we will want the grain to remain visible after staining. The windows will be cut from 1/16 inch clear acrylic and the walls will be laser cut from sheets of 1/4 inch styrene because it is easier to obtain in “true” measurements (i.e. 1/4 inch of styrene is truly a 1/4 inch, whereas lumber is always slightly smaller). Styrene can be painted any way you like, is strong, and has surface qualities that are amenable to most adhesives.
Josh Jay (author)
in reply to Jun 7, 2012. 7:21 AMReply
Z0M8I3
says:
Jun 6, 2012. 3:36 PMReply
megaduty
says:
Jun 4, 2012. 3:35 PMReply
Penolopy Bulnick
says:
Jun 4, 2012. 5:12 AMReply
Josh Jay (author)
in reply to Jun 4, 2012. 7:21 AMReply
Not Nice
![Trying my hand at: Mold Making and Casting with Silicone RTV [Pittsburgh Tech Shop]](http://www.instructables.com/files/deriv/FEF/TK55/HHS9SOEK/FEFTK55HHS9SOEK.SQUARE.jpg)
Visit Our Store »
Go Pro Today »
