Step 9Pipe'n drill!
Now, it's time to pull out the 1/10" drill bit and drill in that hole again! this will be the actual passage for the air to go into the hot pipe. be VERY VERY careful! how much you damage the inside of the pipe will determine how well your vortex tube works. like before the drill bit should almost scrape the inside of the pipe when it cuts through. Depending on how the previous holes were drilled, you'll have to move your drill accordingly. Drill both sides and then glue the washer into the groove.
CAREFUL!!!
Center the washer FIRST!!! make SURE the hole is centered with the inside of the pipe.
comment
Add Comment
Add Comment
