Step 2Lay Out Driver Placement on Plywood
After cutting your piece of plywood down to size (35" x 82" in this case), plan and lay out your speaker arrangement on the plywood. Use the overall driver diameters to achieve proper spacing, but make sure to leave 1.5" between woofer mounting holes to allow for 2 x 4 bracing on the backside. In my case, my woofers are exactly 12" in diameter, but require an 11" hole. For my layout, I started in the exact center of the board with the tweeters, then moved outward with the midranges, and finally placed the woofers on top and bottom. If you plan well, you can get distances between divers to be quite symmetrical.
Add Comment
