Step 6Make Mounting Brackets
The "back" section is a 6" long piece of 2 x 6 with a 3.5" L-bracket screwed to it. I used blue painter's tape wrapped several times around the end of the bracket to protect the doorway trim when the bracket pulls against it. I drilled a 1" diameter hole 4" deep into the end of the 2 x 6 and drilled a 1/2" hole through the remaining 2". Then I installed a 3/8" T-nut into the 4" deep hole. This allows the carriage bolt to reach the T-nut only 2" into the assembly.
The "front" section is a 7" long 3/8" carriage bolt with a wing nut screwed all the way tight against the head and a jam nut locking it in place. This can be replaced by any type of thumb screw type fastener, but I had trouble finding a one-piece option that was this length and diameter. Then I used a 1.5" diameter fender washer and a 3" diameter by 3/4" thick particle board "washer" to completely cover the slot when in position.
Add Comment
