The Hotmail Heater, prepper bug out off the grid heat and hot water
 by rowerwet
I built a Teardrop trailer in 2011, finding a cheap heat source for of-the-grid camping that is safe is one of those ideas always being kicked around on the best (IMO) website for Tear Drop Trailers (TD) http://www.tnttt.com/index.php.  There is a company that makes a tent heater powered by propane, but a few years ago they stopped making the model that would work the best for tents and TD, instead they now sell a very expensive large capacity one that mostly seems aimed at the military and others with big tents to heat.
    I am an airplane mechanic for a living and small twin engine aircraft are mostly heated using a combustion heater like this one http://www.kellyaerospace.com/articles/Heater_AMT.pdf , I figured there has to be a cheap way to make heat for tents and TD's that uses common hardware store items. Then as I was wandering around in the the blue Borg, (though orange is my favorite, we don't have green around where I live)  I think I figured it out.
   My idea is simple, a kerosene lantern, which is used by most of the people in the world, and two mailboxes. the rest is just using physics to get heat to go where we want it and soot to stay out of our lungs.
   While searching for the BTU (heat output) rating of a kerosene lantern I found a site that reports that most people in the world without electricity use kerosene lanterns, and stoves, most of these are not vented to the outdoors, and this causes quite a few lung problems. SO WORK CAREFULLY, SEAL ALL YOUR SEAMS, AND IF IT IS WINDY OUT USE THE 12v FAN FOR POSITIVE PRESSURE SAFTEY.
   One other note, while a candle is a better-than-nothing source of heat, it actually coats the inside of your tent, TD, and lungs with wax as it burns, and anything that burns is using up the oxygen in your tent or TD, every year people don't wake up in their tents due to using candles, lanterns, and stoves to heat. YOU ARE JUST VISITING THIS PLANET, DON'T CUT IT SHORT, PLAN AHEAD AND BE SAFE.
  The figures I found show that a candle puts out 90-100 BTU's (per hour), a human being puts around 250 out (equal to a 100 watt incandescent bulb) and a kerosene lantern puts out 800-3000 BTU's (depending on model and wick width, if a mantel is used, etc.) I am using the cheap oil/kerosene lantern from wallyworld for this which I believe will give me 1000 BTU's input.
For comparison, my house has a rather small oil boiler rated at 85,000 BTU's, and a pellet boiler rated at 175,000 BTU's, Most homes have 100,000 to 300,000 BTU rated systems. However my TD is about 40 square feet compared to 1,200 sq ft in my house.
   For disaster or emergency use a kerosene lantern is your best bet in most cases for light and now for heat, most wick type lanterns will run on olive, jojoba and just about any type of oil, kerosene or lamp oil may not be around when you need more.
Step 1: List of parts and tools
right now you will need to decide what you want to make....
Do you want a free standing (tent) heater, or a built-in one (TD, TTT (tiny travel trailer), or small caravan)?
Parts to make a tent heater:
-lantern
-standard size mail box (make sure your lantern fits inside)
-sheet of 1/4" plywood
-adhesive for sticking plywood together
-(2) sink tailpieces (brass not plastic)
-dryer flex hose, RV sewer hose, or SCAT hose (long enough to reach your tent,
-12 volt computer fan and power supply (8 D cell batteries in a PVC pipe would work)
-dryer hose duct flange, RV hose flange, which ever you chose.
-hinges (2)
-latch
-1" X ?" board to fit into the base of the mailbox.
-a tube or two of high temp RTV (auto parts store will have this)
Parts for making a built-in heater (teardrop, tiny trailer or caravan) :
-lantern
-standard size mailbox (make sure the lantern fits inside with the door shut)
-a bigger mailbox (the little one has to fit inside with the door shut)
-a tube or two of high temp RTV, (any car parts place should have this)
- (2) 1" rigid wiring conduit end piece, (the part that seals the end of the conduit to the wiring )
-or (2) brass sink drain tail pieces (the kind with a rubber grommet, a nut and a flared end that the nut tightens against)
- slide bolt latch
-screws and nuts to mount latch
-(2) dryer or heating duct flanges
-12v computer fan (same diameter as the duct you use)
-12v power source (a stack of 8 D cell batteries in a PVC pipe will do the trick)
-(4) bolts and nuts (long enough to tie the inner mail box to the outer one in four places)
Tools:
-drill
-drill bits
-hole saws (to match the diameter of the conduit/tailpieces, and dryer/heat ducts.
-screwdrivers, wrenches, pliers
weldor says: Jun 20, 2012. 12:57 PM
Look in the wood stove/fireplace supplies at the local hardware and try to find the fire barrier/fire stop spray in foam. There are several different ratings for this as well as the RTV silicone sealants. If you wet you fingers (spit on them!) you can use them to get a really nice smooth finish on the RTV.
StupidGenius says: May 22, 2012. 1:02 PM
Looks good on LCD. Now go out and build one. If it works I am sure it will be a huge hit. Can't wait to see the prototype.
rowerwet (author) says: Apr 14, 2012. 6:39 AM
the outer box wouldn't be that hot, at least I don't think it would be hot enough to melt plastic.
I labeled some of the pictures, hope that helps.
josh
SeamusDubh says: Apr 12, 2012. 3:08 PM
Some labeling of the parts/sections, flow directions in the diagrams would be nice.
Also I wouldn't use the foil faced bubble wrap.
(Plastic, melty, burn, poisonous gas, bad, very bad.)
Hit up the plumping section of you hardware store for water heater exhaust insulation. It's made to handle the heat and is rather fire proof/resistant. Or even the regular household insulation section, looking specifically for fire rated.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
