loading
Step 4: Pitch (up-down Steering)
The hinge for the pitch is made in a similar way, on the other side of the reciever/servo unit. First a 1,5 cm balsa "beam" is glued in a "T" to the main beam. It is important to put the pivot point high enough to make room for the motor connector and to make sure the control rod can move freely when "giving down".
Here the "moving part" of the hinge is chosen larger as it will actually become the fixed support to be attached to the blimp. Three balsa "beams", are glued to this part, to be attached to the inflated balloon. They are stuck on the balloon with some double sided tape, one by one. This is done by removing the protective layer on the second piece of double sided tape only after the first is stuck in place. T The third one is done proceeding the same way.
<p>Sorry, I wish I could fix it, the balloon is no longer available. I will however adjust the text.</p>
<p>The link to get the baloon Doesn't work. Can you Fix that please?</p><p>Thanks!</p>
I think a brushless would be muuuch much better. And I think you should put the motor in the front, since it is a slow flyer, pulling principles would apply better
The main factor at this time is the weight distribution. But as these days there are some brushless motors + ESC under 3g are available, I am planning to try it out one day.<br><br>Indeed brushless motors are bound to give a better power/weight ratio.<br><br>However putting the motor in front would defeat the purpose of building an indoor flyer that can hit a wall and continue flying without even crashing.<br><br>As for pulling principles applying better? I learned that a push prop is slightly more efficient than a pulling prop. Is that not the case for a slow flyer? If so, I am curious why.<br><br>Or do you mean it would be easier to control? Probably, but as long it can be controlled I prefer the more robust configuration of a motor at the stern.
Are you selling these blimps anywhere?<br>
No, I'm not.<br><br>I might one day, when it is further developed.
Hey masynmachien - Nice blimp!<br> <br> Couple questions for you. How much weight will it pick up?<br> - I ask becuase i just picked up a DXG half HD video camera which weighs approx 5 ounces... thought it might be pretty cool to lift the video camera up and see how things look from the top so to speak. ;0)<br> <br> Lastly - Just out of curiousity really - have you tried running it slowly into a lite candle made to look like a&nbsp;wire tower or something,&nbsp;and filmed it&nbsp;with a high speed camera and played it back in&nbsp;slo-mo? Thought that might be pretty neat to see... the hindenburge effect kinda thing.<br> <br> I read you work with kids - so the&nbsp;last one might be a little much depending on the age group but - on your own - might be a pretty cool thing to try...&nbsp; well i'd like to try it.<br> <br> I did check your link for the blimp it's in a launguage i don't under stand but i take it since the page you directed us to is pretty well blank with the exception of this:<br> <br> Webshop der Deutschen Zeppelin-Reederei GmbH<br> Herzlichen Willkommen in unserem Webshop. Nehmen Sie sich Zeit und st&ouml;bern Sie in unseren Artikeln rund um den Zeppelin.<br> <br> Not sure what it means but - if i were to guess i'd say it says something abut the page being under construction - maybe - maybe not.<br> <br> can you translate this - or someone that understands the launguage translate what it means?<br> <br> Any other link for the balloon? In english or with an english page.<br> <br> thanx and again - real nice blimp!<br> -chase -
Thanks!<br><br>The Zeppelin NT balloon lifts only about 20g (as mentionned). It belongs to the class of microblimps and so it not at all suited to carry a camera. i.<br><br>Actually, 5 ounces is rather heavy for &quot;livingroom&quot; or &quot;classroom&quot; blimps. You would need one of the larger RC blimps as used in sports or exhibition halls.<br>Check out http://www.blimpguys.com/ for example.<br><br>As it is filled with helium, a flame would simply puncture the envelope and have it slowly deflate. So nothing spectacular to film.<br><br>Now you mention it, although the Deutsche Zeppelin-Reederei site is doubled in English, the web shop seems not to be. It is not under construction, You simply come to the start of the German version inviting you to look around and check out the articles. I will add some guiding through, both here and to the Ible:<br><br>klick on &quot;Start Zeppelin Online Shop&quot; or &quot;Zeppelin-shop starten&quot; in German. Then click on &quot;Produkt&uuml;bersicht&quot; and choose &quot;Accessoires&quot;. Scrolling down quite a bit brings you to the balloon.
Thanx - sorry i didn't see the lifting weight first time around.<br> <br> I looked at the blimpguys blinps thanx for the link btw<br> &nbsp;- those are pretty big for what i was thinking. actually huge for what i was thiking of... suppose i could build one inbetween the size you made and those though. Shouldn't be too hard.<br> <br> Btw - i found this though i'm sure there are others even smaller these days.<br> Wireless COLOR Pinhole Camera<br> Perfect for Radio controlled cars,airplanes,boats, and spying.<br> Weighs only 20 grams and sends<br> COLOR images up to 100 meters<br> <br> and found a couple with 300 meter ranges.<br> <br> Helium - ah haa... the Zepplin was filled with Hydrogen - don't know why i was thinking helium... my bad. Though i suppose i could fill one with hydrogen... ;0)<br> <br> voting for you right after i post this as per request.<br> and good luck with the contest - didn't know they had one going on.<br> <br> chase<br>
Where id you find the colour pinhole camera? <br>Can you supply a link? I looked but did nopt find anything I liked, (and could afford...). <br>Thanks. <br> <br>BTW, masynmachien, cool dirigible! <br>[Yes, I know the difference, but it just sounds more cool than saying <br>aiship or blimp...] <br> ;-)
Hey avatar_i,<br> <br> The wireless pinhole video cameras can be fairly up there so i took a look around and you might like this one...<br> <br> Its Not wireless but could still be used from what i'm seeing and it's net weight is only 14grams.<br> <br> Some specs on this one are:<br> <br> 1280*960 full real-time video<br> Motion Detection<br> 8 million-pixel digital camera<br> Web camera function<br> High-quality record function<br> Can record while charging<br> Support 16GB Micro SD Card<br> View range: 60 degree<br> Recording resolution: 1280*960@30fps<br> <br> and like most digital stuff - prices go down as advancements go up.<br> Here is a link to it... don't know if that is in your price range or not but take a look at it..<br> <br> <a href="http://www.lightinthebox.com/8-MP-HD-Video-Recorder-Mini-Camera--PC-Camera--Motion-Detection-_p174967.html">HD Pinhole Video camera</a><br> <br> <br> Have fun,<br> chase<br> <br>
Thank you very much for your vote.<br> <br> When choosing a size for your camera blimp project, bear in mind that the volume of a balloon, and therefore the lifting capacity changes with the scale factor raised to the power 3. That makes building small blimps a challenge. Luckily, modern miniaturisation comes to our help. When using an &quot;RC toy&quot; blimp 52&quot; x 27&quot; balloon (or an oversized 52&quot; x 37&quot; replacement from <a href="http://www.microflight.com/Online-Catalog/R-C-Toys/Balloon-Blimp-shape-52x37-for-Tri-Turbofan_2">Plantraco</a>),&nbsp;with RC gear of the latest generation you get some lift capacity to spare.<br> <br> This makes room for such a pinhole camera. However pay attention to the fact that while the Blimp RC gear works on a single Lipo cell (1s, 3.7 V), the wireless cameras most often need 5V or even more, so you will have to account for extra batteries. Again, nowadays you can find Lipo batteries weighing only couple of grams per cell, of course with limited capacity.
cool i liked it thanks for sharing
thank you
your welcome
Enjoyed the read. Thanks for sharing.
Thank you for your attention!
Id be filling it with Hydrogen. Then you can use bigger motors and/or batterys :)<br>
Actually, the difference in lift capacity between hydrogen and helium is less than 10%. The use of hydrogen is clearly not worth the risk.
Yeah your right, I did some research about it. It turns out o be closer to 8%.<br>Even though hydrogen is approx twice as light as helium.<br>It has to do with the difference of density. Helium is already so much lighter then air, Even a vacume would not even make much difference.<br><br>Who would have thought :)<br><br>The only problem with helium is the price.<br>I still like the idea of use hydrogen though. Its a lot safer than a lot of people think.<br>
In a vacuum, both helium and hydrogen filled balloons would sink like rocks! Or?
I never thought about it, They would fall yes.<br><br>As for like a 'rock'. I think they would.<br><br>Consider this.<br> Dropping a marble and a bowling ball at the same time, They both hit the ground almost simultaneously. Only the aerodynamics of the objects will affect the speed.<br> In a vacuum aerodynamics does not exist.<br><br>So yes, It would fall faster then a rock in air :)
Indeed.
In small amounts the danger with hydrogen is not that big, obviously. But helium is still safer. And as the Hummingblimp uses only about 45 liters, the price is not that important. At the balloon shop they will typically fill it for an euro or so. You pay for the service, the helium price is only a smaller part of that. And as it keeps about a week or two, that is very reasonable cost.<br><br>For larger blimps the helium price becomes important, but then the risks become important too.<br><br>After all we're not talking about a choice between gasoline in a tank versus gas in a high pressure tank, where hydrogen can be an acceptable choice. We're talking about the choice of lifting gas in a very thin envelope.
Mooi gedaan, jongen. Ik zal proberen of ik een Zeppelin in Canada can krijgen.
Een compliment in het Nederlands, bedankt!&nbsp;<br> <br> A compliment in Dutch, Thanks!<br> <br> I'll continue in English, so others can read the info too.<br> <br> In Canada, good sources for blimp stuff are <a href="http://www.microflight.com/">Plantraco</a> and <a href="http://www.blimpguys.com/">Blimpguys</a>.<br> <br> As far as I know the the only source for the Zeppelin NT balloons is Deutschen Zeppelin-Reederei GmbH, but they probably ship worldwide.But you could try the California based <a href="http://www.airshipventures.com/shop/index.php">Airshipventures</a>.<br>
would it be feasible to simply glue (or duct tape) one of those cheap and seriously annoying to fly RC helicopters on the zeppelin body itself? <br><br>just a random thought
It could be interesting to try, but unless you do some serious adaptions you would end up with to much power and to little control.<br><br>In fact these tiny airplanes, like those from Silverlit, in particular the ones with two motors, would be more suited to convert to a blimp, with a classic gondola set up.
Go 100% authentic and use hydrogen instead...
Hydrogen is highly explosive and therefor dangerous.
Pure Hydrogen is only explosive when mixed with oxygen. It can be fairly inert in its pure form.
Yes, so if there is a leak, it would leave an explosive mixture in the air.
Yes, H2 contact in air would be dangerous. Generally H2 mixed with air would burn with a flame, much like any other flammable gas. <br>However if the Hydrogen was mixed in with a stiochemetric amount of oxygen, then it would explode if ignited.<br>Neither situation is desirable unless you intend it to be a spectacle, such as flying the blimp over fire.
Then give an authentic end by flying it out in a thunder storm (make sure that there is a leak though or it won't be authentic)...
Oh the humanity! Hydrogen Baloon on a open fire <a href="http://www.youtube.com/watch?v=PqFCem-3xi8">http://www.youtube.com/watch?v=PqFCem-3xi8 </a>
You're looking for more spectacle aren't you? :-D<br>But the Zeppelin NT airships were never filled with hydrogen. The first one was produced in 1997.
Yeah you don't want to use hydrogen... http://youtu.be/MMB2VR0087w
Great idea! You might get more responsiveness if you added bow planes...just a thought.
Indeed, bow fins would increase responsiveness, but actually the blimp was already to responsve without any fins. So the fins were added near the stern to reduce resonsiveness and increase stability. The position and size of the fins could be tuned further to get just that responsiveness that is suited for the size of the room.
Hypnotic
Very cute, looks a little like a narwhal!
Awesome!
Cool beans!
Great!
Wow, this is the best design for an RC blimp I have ever seen!
Thanks.<br><br>Of course, the idea of the single rotor at the stern comes from Daniel Geery with his Hyperblimp.
About This Instructable
40,256views
138favorites
License:
Bio: Send me a message if you're interested in Technology or Science Workshops in Flanders, Brussels or the Southern of the Netherlands. I have over ... More »
More by masynmachien:Laser Cut Posable Figure Laser Cut Rubber Band Three Wheeler Simple Laser Cut Tree Building System.
Add instructable to:
