The original (un-lit) clear plastic frame concept & design is by saul, who led an intersession class at the MIT Media Lab in 2003 (?) where about 10 students each designed and built a clear plastic bicycle frame. Some of the students modified the frame styling a bit, one of the other frames with a more curvy style is shown below.
After seeing one of the frames around MIT in 2004, I had the idea for customized edge lighting so I built up a frame and added the lighting effects.
The full project here is quite a lot of work unless you have a high-end machine shop at your disposal, but there should be several ideas for you along the way. I've included the CAD files for the plastic frame and the C code for the microcontroller. This is an "after the fact" documentation, i built this about 3 years ago.
As seen in the Wired Blog.
This article is brought to you by MonkeyLectric and the Monkey Light bike light
Remove these ads by
Signing UpStep 1Tools & Parts you need
- a 4' x 8' sheet of 3/8" thick clear polycarbonate
- a 2' x 4' sheet of 1/8" thick clear polycarbonate
- a 2' long, 1" diameter clear polycarbonate rod (handlebar)
- acrylic solvent cement
bike build:
- standard bottom bracket
- standard seatpost & seat
- 26" rear wheel with coaster brake
- 26" front wheel
- threadless headset
- 12" long aluminum fork tube (sized for your headset diameter)
- standard stem
- standard crank arms & pedals
LED edge lighting:
- as many LEDs as you desire (this one has about 200 x 5mm leds, but you probably want to use high-power leds)
- 22 guage wire in 4 colors
- three copies of my simple constant-current led driver circuit, one for each bank of LEDs
- simple Atmel AVR controller circuit which drives three FET's, each fet turns on/off one of the LED banks.
Tools:
You need to be able to cleanly cut out the plastic frame parts from the sheet of plastic. You might be able to do this with a jigsaw, a dremel tool and a lot of patience, otherwise you'll need a CNC mill or a CNC waterjet cutter.
You will need a bottom bracket tap to cut the threads into the plastic to screw in the bottom bracket, most bike shops probably don't have one of these and you'll have to try a custom frame builder.
A dremel tool to polish any of the plastic edges that don't quite fit.
standard bike tools
soldering iron & pcb assembly gear
great idea, btw
