The Ice-Worm Cocktail
This bright green cocktail boils furiously, and when the mist finally clears, the drinker spies, "drowned in alcohol, an ice-worm... bilious blue... eyes a bulbous red... gross... and hideous of head."
We served this cocktail first as graduate students years ago, and we toyed with a variety of names: "Snakebite", "Venom", "Ice-green" all seemed pretty lame and cliched. It was only earlier this year when a learned, witty and Arctic-obsessed colleague proposed calling it "The Ice-Worm Cocktail", after the Robert W. Service ballad. Despite the name, no Mesenchytraeus solifugus are sacrificed in the preparation of this beverage.
Step 1Ingredients
Ingredients
This is no ordinary cocktail; it requires an ingredient you won't easily find at your local liquor store.
Galliano ~ green creme de menthe ~ gummi worm ~ liquid nitrogen
38 comments
Oct 17, 2011. 8:22 PMilpug says:
You might try a piece of food-grade dry ice
Dec 25, 2009. 12:17 PMCaptainNemo says:
You might try also adding a led illumination device to the cocktail to give it a added effect.
Oct 14, 2011. 9:33 AMloqk says:
true :-D
led throwies (minus the magnet) work perfectly well, (if a bit dimmer) while frozen in water, i suspect they would be less flashy immersed in LN2. they probably better be on the outside of the glass shining in.
though, now i must get some LN2 and try it, just to see what happens :-D
Oct 31, 2010. 1:05 PMCobaltBlue says:
You would have to figure out some excuse to use a laser cutter.
Apr 2, 2010. 2:43 PMTalonX says:
Kinda new here but this sparked a memory of working at a novelty store in the mall. We used to sell liquid activated LED shot glasses that flash when they have something in em. probably make bigger glasses too but I'm not sure. i think I'm gonna go the dry ice route because its much easier to get. But this sounds to me like a winning combo for some crazy drinks. if it works i might try writing it up. a quick search led me to this page that might be worth checking out seems to have lots of fun flashy things. http://www.windycitynovelties.com/211828p/blue-l-e-d-shot-glass.html
Mar 31, 2011. 6:29 PMcmanuel1 says:
This seems rather dangerous. But since I could be mistaken, is liquid nitrogen diluted with another liquid safe to drink? And would dry ice in maybe a glass of water be essentially the same as carbonized water?
Oct 14, 2011. 9:30 AMloqk says:
I'm pretty sure you can mix it with liquid oxygen, though, that may not be what the questioners meant...
Dec 23, 2009. 9:38 PMEvil Bike says:
 where can you get liquid nitrogen?
Jan 22, 2010. 1:53 PMsnarke says:
 It isn't? I called Praxair here in Seattle last summer to ask about buying LN2 for making ice cream. They told me as long as I had a suitable container (which is to say, a dewar), they'd be happy to sell me some liquid nitrogen. I wouldn't need a special license or secret password or anything.
I rather suspect that they figure anybody who knows enough about LN2 to figure out where to get it and how to transport it can have some. After all, it's not nearly as dangerous as, say, fireworks.
If your local supplier seems less inclined to cooperate, you could try approaching them as a doctor or chef. Doctors use LN2 for removing warts; chefs, well, if you don't know that, you don't watch enough programming on the Food Network. Both of these professions would be (to the supplier) individuals buying small amounts.
I do not recommend lying to them, by the way. "Approaching them" as in "We're looking at revising our menu/adding some new cocktails to our bar menu [true], and I'm looking for a source for small amounts of liquid nitrogen."
That's Plan B, though. Odds are very good that if you call them up and say "Hi, I've got a party coming up and I'd like to serve some special cocktails. I have a recipe that involves liquid nitrogen. The instructions include instructions for safely handling the LN2, but don't have much advice on where to get it. Can I get it from you guys, and is there any advice about handling it that you'd like to make sure I know about?" that they'll be quite happy to explain how not to hurt yourself, and what they'll expect when you show up at their plant to buy yourself some chilly chilly N2.
As a matter of fact, it was the helpful guy at Praxair that explained to me the main difference between a beverage thermos and a dewar. The dewar has a pressure relief valve built in so that the slowly evaporating gas doesn't build up pressure until it explodes. (And that's why they won't let me take my nitrogen home in a thermos.)
Dec 28, 2009. 3:07 PMShela says:
It look great and the effect is eerie.  I just need to fine the liquid nitrogen.  Can dry ice be added and get the same effect?
Dec 19, 2009. 1:00 PMAngryRedhead says:
I like Grasshoppers and other minty drinks (or just straight mint leaves).  I like gummies.  I admit I don't like Galliano because all I taste is the anise, but this flavor combination seems a bit confusing despite existing cocktails which include creme de menthe and galliano.  Assuming you wanted the green color and the gummi worm, why not Midori and Mango Rum? or Sour Apple Schnapps and Currant Vodka? or some other combination such as with Tequila so the gummi is a "true" mock worm?
For the record, I do like this Instructable, and I'm certainly intrigued by a gummi worm in a cocktail.
Dec 19, 2009. 2:46 PMAngryRedhead says:
Ah ha, now I get it.  I still don't think it's my bag, but the reasoning behind it does make sense now.
Blue curacao isn't so bad (use it like triple sec), and you can get a nice blue color with very little of it so long as all the other ingredients are clear.  Of course you don't want the curacao to be the overwhelming flavor because that would be a bit ick in my opinion, so use rum, vodka, other white liqueurs, etc.  For a lovely violet/plum color, use chambord.
I'll give you 3 guesses as to how I do it for less than $1, and I'll tell you now it's not a photoshop/GIMP trick.
Dec 19, 2009. 3:00 PMAngryRedhead says:
Also, if you don't get it in 3 guesses, I'll do a quick Instructable on it.
Dec 19, 2009. 3:47 PMAngryRedhead says:
Ha!  You got it with guess #1!  It's a piece of white poster board bent onto the inside of my tripod (obviously when it's not being used) with a tiny piece of electrical tape to hold it in place - I use electrical tape because it's easy to reposition without tearing.  Then I rig my lights to the tripod or lay them on the surface.  The lights and bulbs were purchased as grow lights originally, and I already had the tripod.  So it's all for less than $1.
Sometimes I have to use two sheets of poster board ($0.78 + tax) and do some very minor editing in GIMP to remove the seam, not always but sometimes if it doesn't disappear in color editing.  And I have done a white tablecloth against white poster board which isn't very seamless at all but sometimes necessary for the large shots without any other options.  Cloth is wrinkly and likes to warp.  Poster board is ideal because it's easy to bend and will stay smooth, and it's hella cheap.  However, you're limited by space (i.e., they're only so big) and lighting schemes (i.e., they aren't transparent).
So there you have it.  You were able to figure it out very quickly, clever boy!  Maybe I'll do an Instructable on my next photography/lighting scheme which I already have brewing in my head.
Dec 18, 2009. 8:09 PMGlockenator says:
i thought you said a drop. you must of put close to 1/4 cup in there
Dec 10, 2009. 1:21 AMycc2106 says:
Thanks for the tips, smoky drinks does add a lot at halloween parties.
I think you should add:
DO NOT directly drink liquid nitrogen, even a small sip (unless your aiming a suicide effect)
1st time I saw one was at the Giger bar in Tokyo.
Dec 17, 2009. 1:35 PMskylane says:
 That is NOT steam coming from the nostrils.
It's more like FOG.  It's condensed moisture from
the extream cold.
Liquid nitrogen is so cold that it will make a tennis ball
shatter like a cheap wine glass, when dropped.
"Dry ice"... solid carbon dioxide is MUCH less dangerous
and probably quite adaquate for this stuff...
Dec 17, 2009. 1:37 PMSamuelLeung83 says:
So freakin' cool! No puns intended.
Dec 12, 2009. 9:13 AMycc2106 says:
Don't know how LN reacts if you drink it but I've heard that people have died by ingesting sub-zero vodka in quantity: so cold that as they imbibe, it freezes all that it comes in contact with.  (seems to happen in places where temperature goes below -80F)
Dec 11, 2009. 1:23 PMthepelton says:
Something you should read:
"Ballad of the Ice Worm Cocktail" by Robert Service
http://plagiarist.com/poetry/4158
Dec 12, 2009. 11:30 AMthepelton says:
I took no offense.  Your whole presentation just brought that poem to my mind.  8>)
Dec 10, 2009. 10:30 AMJayefuu says:
Fantastic! Got my vote. Amazing photos.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
180
Author:makendo
I like to make stuff more than I like to buy things
