We served this cocktail first as graduate students years ago, and we toyed with a variety of names: "Snakebite", "Venom", "Ice-green" all seemed pretty lame and cliched. It was only earlier this year when a learned, witty and Arctic-obsessed colleague proposed calling it "The Ice-Worm Cocktail", after the Robert W. Service ballad. Despite the name, no Mesenchytraeus solifugus are sacrificed in the preparation of this beverage.
Remove these ads by
Signing UpStep 1Ingredients
Galliano ~ green creme de menthe ~ gummi worm ~ liquid nitrogen
led throwies (minus the magnet) work perfectly well, (if a bit dimmer) while frozen in water, i suspect they would be less flashy immersed in LN2. they probably better be on the outside of the glass shining in.
though, now i must get some LN2 and try it, just to see what happens :-D
Dry ice is safer, for sure. It will carbonate the water, but only weakly because it won't be under pressure.
It isn't? I called Praxair here in Seattle last summer to ask about buying LN2 for making ice cream. They told me as long as I had a suitable container (which is to say, a dewar), they'd be happy to sell me some liquid nitrogen. I wouldn't need a special license or secret password or anything.
If your local supplier seems less inclined to cooperate, you could try approaching them as a doctor or chef. Doctors use LN2 for removing warts; chefs, well, if you don't know that, you don't watch enough programming on the Food Network. Both of these professions would be (to the supplier) individuals buying small amounts.
I do not recommend lying to them, by the way. "Approaching them" as in "We're looking at revising our menu/adding some new cocktails to our bar menu [true], and I'm looking for a source for small amounts of liquid nitrogen."
That's Plan B, though. Odds are very good that if you call them up and say "Hi, I've got a party coming up and I'd like to serve some special cocktails. I have a recipe that involves liquid nitrogen. The instructions include instructions for safely handling the LN2, but don't have much advice on where to get it. Can I get it from you guys, and is there any advice about handling it that you'd like to make sure I know about?" that they'll be quite happy to explain how not to hurt yourself, and what they'll expect when you show up at their plant to buy yourself some chilly chilly N2.
As a matter of fact, it was the helpful guy at Praxair that explained to me the main difference between a beverage thermos and a dewar. The dewar has a pressure relief valve built in so that the slowly evaporating gas doesn't build up pressure until it explodes. (And that's why they won't let me take my nitrogen home in a thermos.)
I also agree with you about safety. LN2 is much safer even than boiling water - a substance most of us handle daily without giving it much thought - I certainly know which I'd rather spill on myself!
For the record, I do like this Instructable, and I'm certainly intrigued by a gummi worm in a cocktail.
Now, I have a question for you - how do you get the beautiful seamless white backgrounds in your photos?
Blue curacao isn't so bad (use it like triple sec), and you can get a nice blue color with very little of it so long as all the other ingredients are clear. Of course you don't want the curacao to be the overwhelming flavor because that would be a bit ick in my opinion, so use rum, vodka, other white liqueurs, etc. For a lovely violet/plum color, use chambord.
I'll give you 3 guesses as to how I do it for less than $1, and I'll tell you now it's not a photoshop/GIMP trick.
I think you should do an instructable on it anyway! Do you 1. use a large flexible piece of white stuff, perhaps formica, white painted hardboard, or plastic, that you bend up out of shot? 2. a piece of white cloth in the same sort of fashion? 3. a white table pushed against a white wall?
Sometimes I have to use two sheets of poster board ($0.78 + tax) and do some very minor editing in GIMP to remove the seam, not always but sometimes if it doesn't disappear in color editing. And I have done a white tablecloth against white poster board which isn't very seamless at all but sometimes necessary for the large shots without any other options. Cloth is wrinkly and likes to warp. Poster board is ideal because it's easy to bend and will stay smooth, and it's hella cheap. However, you're limited by space (i.e., they're only so big) and lighting schemes (i.e., they aren't transparent).
So there you have it. You were able to figure it out very quickly, clever boy! Maybe I'll do an Instructable on my next photography/lighting scheme which I already have brewing in my head.
I think you should add:
DO NOT directly drink liquid nitrogen, even a small sip (unless your aiming a suicide effect)
1st time I saw one was at the Giger bar in Tokyo.
It's more like FOG. It's condensed moisture from
the extream cold.
Liquid nitrogen is so cold that it will make a tennis ball
shatter like a cheap wine glass, when dropped.
"Dry ice"... solid carbon dioxide is MUCH less dangerous
and probably quite adaquate for this stuff...
Dry ice will certainly make a neat looking drink - it will happily bubble away, making a nice smoky effect (note: not actually smoke). It will also last much longer, is readily available, and is safer. It won't, however, crackle menacingly, shatter tennis balls, or boil furiously, and as SamuelLeung83 put it... that's freakin' cool!
"Ballad of the Ice Worm Cocktail" by Robert Service
http://plagiarist.com/poetry/4158
