Introduction: The Indestructible USB Containment Unit
Picture of The Indestructible USB Containment Unit
     Have you ever found yourself behind enemy lines in an alien environment with an important, top-secret message encrypted on a USB drive that could prevent World War III? No? Well, the following guide could assist you if the likely situation ever arises.
     This instructable will teach you how to make a full steel USB container. As the picture shows, it is large enough for it not to be lost yet small enough to fit in a briefcase or jacket. The USB exo-suit  can withstand brutal forces including the following: Drops onto concrete, drops into a body of water, extreme cold, open flame, the weight of a Isuzu Rodeo, hits from a metal bat, an attack by Godzilla (as far as we know), and an extremely violent shot from a nine foot air cannon pressured at 110 psi.
Step 1: Step 1: Locate the Materials
Picture of Step 1: Locate the Materials
The following supplies are needed in either the construction of the container or to use as a tool in the process of making the container:
1/8 in 1.25x1.25 square steel tubing (length does not matter as much, ours was 6in.)
1/8 in flat steel
2 lockable steel draw catches (usually come in packs of 2)
3-4 inch thick Floral foam
USB drive
Water sealant tape (sold next to electrical tape at Lowes)
(Optional) USB extension cable (this prevents the need of removing the USB drive from the container)
(Optional) Rust preventing spray paint/coating
(Optional) Lock mechanism
-Tools-
Chop Saw with a steel rated blade
Welder
Small, sturdy, thin object to hollow floral foam (dental pick, small knife, toothpicks)
Metal grinder
Step 2: Step 2: Cut the Steel
Picture of Step 2: Cut the Steel
The first step one must perform is to cut the metal. Grab your steel tubing and cut it to an appropriate length to fit the entire USB drive inside, lengthwise. The lack of definite size specifications is due to the varying size of USB drives and if you choose to add an extension cable to it (Mine took up around 4 inches of space within the metal tubing.)
Place your metal piece on the chop saw and cut it at the predetermined marking. Then, grab the flat metal and measure two 1 square inch pieces to serve as caps.
Step 3: Step 3: Grind
Picture of Step 3: Grind
Grind all of the burrs and metal “pokeys” off of the metal you just cut. This creates a better fit and makes it look a lot better. Also, metal splinters are not fun, so wear gloves when grinding and cutting.
Step 4: Step 4: Shaping the Floral Foam
Picture of Step 4: Shaping the Floral Foam
Locate your floral foam. Make sure you could fit all of your USB drive, with some extra space within it, if it were hollow. Once you confirm that, you can grab your metal tubing you just cut and push it through the foam. Depending on your foam, a hammer may have to be used.
Once the metal goes all the way through the foam, a perfectly sized piece of the floral foam should be stuck within the metal pipe. Push this out. This process can produce a lot of floral foam dust, I would not attempt it indoors.
Step 5: Step 5: Hollowing the Floral Foam
Picture of Step 5: Hollowing the Floral Foam
In this step you just grab your pick like device and scrape away the inside of the floral foam. Just eyeball the proper depth for your specific USB drive. Create the walls of the hollowed area small enough that the flash drive could not move about on the inside. Make sure you do not go all the way through and do not let the sides break off.
Once complete, the majority of the flash drive should not be visible from the side when it is concealed in the foam.
The reason the USB needs to be concealed in the foam is so that there is no space for it to bump around inside. Also, the foam serves as an excellent insulator against heat and cold.
Remove the foam and flash drive now that is all sized and hollowed.
Step 6: Step 6: Weld the Case
Picture of Step 6: Weld the Case
Now, set up your welder (mine was a mig, others should work though). Take one of the metal squares and weld it to what would be the bottom of the case. Make sure it is level before you weld it so you can have it sit upright.
Now, once the square is sitting on the bottom of the case, weld it on all four sides. Make sure no gap exists as it would allow water to leak in. Optional: grind the welds down in order to improve aesthetics. Just make sure you do not grind through the metal.
Step 7: Step 7: Weld on the Side Clamps
Picture of Step 7: Weld on the Side Clamps
Place a clamp on the side of the container and the clamp hook on the nonwelded metal square, which acts as a lid. Align them on the side of the container and mark their positions so they can easily be put back in the same place. Do this for both sides.
Being very precise, weld a clamp hook on each side of the lid square. Be sure to not make the weld too big because it could either distort the clamp hook or make it so the lid won’t rest evenly on the lip of the container.
Then, place the clamp on the sides of the container on the markings you drew earlier.  Weld it on but make sure the welds will not interfere with the clamping system. I ended up welding it on the bottom of the clamps, in and around the screw hole. This way the welds would be sturdy but would not affect the effectiveness of the clamp.
Once cooled, the clamps should close and lock the lid to the container. It should be secure but not tight.
The reason I used draw catches is so that the container could be locked, further adding protection.
Step 8: Step 8: Insert the Insides
Picture of Step 8: Insert the Insides
This is rather self-explanatory. Insert the foam encased USB drive and the optional extension cord into the container. Note: if you choose to have an extension cord, make sure that it is plugged in to the USB drive when you insert it.
Step 9: Step 9: Add the Sealant
Picture of Step 9: Add the Sealant
Cut small strips of the electrical sealant tape and apply it to the lips of the container. The corners can overlap so extremely precise cutting is not necessary. (Optional): You could add a second layer of water proofing by adding it to the lid, we did not find this necessary. (It may be wanted if you plan on taking this to extreme depths though.)
Now that the sealing is applied, clamp the lid back onto the container. You do not need to wait for the seal to set. When clamping, you will notice a stronger tension on the clamps.
After letting the container sit for a few minutes, you should notice that it is very hard to get the lid off the first time. This is normal.
Step 10: Step 10: Paint and Complete
Picture of Step 10: Paint and Complete
This is the final, easy step. Just paint your container if you want to. Once completed, you can now go about tossing your important information off tall buildings.
(Optional) The clamps have the option for a lock, you can either add a bike lock, gun lock, two padlocks, retina scanner, or any other lock you see fit.
Step 11: Tests
But how much can it really take?
Viaticus (author)2013-04-16
Personally, I don't think there will be a WW3. I do, however, firmly believe that a zombie apocalypse is immanent and this will be great for preserving human history for future civilizations (...that colonize on our planet in the future)! :)
Very cool instructable...thanks for sharing it!
Zaqq (author)Viaticus2013-04-16
And when times get tough in the apocalypse, it could be used, in extreme cases, as a zombie bludgeoning device.
1tri2god (author)2013-04-15
but what about EMP's???
jk...nice job!
maybe try adding lead lining to the tube, that would help a bit.
very good instructable.
fungus amungus (author)1tri2god2013-04-15
That should be covered as well since it's a Faraday cage.
Very good point
shizumadrive (author)2013-04-15
The government might want to buy this. It's one of the best indestructibles I've seen so far (not the easiest to build but oh well)
And that wallpaper is nuts
Zaqq (author)shizumadrive2013-04-15
Thanks man!
docman100 (author)2017-04-06
nice but could you use stainless steel?
downincongnito (author)2014-04-26
Oh! Faraday Cage! Guess i should read all 1st!! Lol
Is this also EMP proofed?
blakesusername (author)2013-04-15
You're actually better off not using gloves when running a grinder as the gloves reduce your dexterity and can become caught in the wheel pulling your hand into the grinding disk.
Zaqq (author)blakesusername2013-04-15
I'll keep that in mind next time. It might get hot though...
neumanngregor (author)Zaqq2013-09-07
Really cool usb stick case you made, for better watterprofing you can try the transparent sanitary silicone sealant, its flexible, transparent if you wanna remove the drive from it and it sticks nice to the interior of the pipe too, and it shud be thermal insulating. Dont use the nonflexible one, thats gonna get rock hard and will not protect from mechanical shocks.
Ramming (author)2013-04-25
Talking about EMP's and Faraday cages. A key point for a Faraday cage to be functioning, is that the device or person protected by the cage, must not be in contact with the sides of the cage. When we talk this build it's possible that this wouldn't be a operational Faraday cage because the distance between the cage and the device is very small, and EMP's can cause high current and voltage surges which can jump over/through non-conducting materials if they not made for high voltage. Furthermore if any metal on the usb device come in contact with the sides, it will definitely not work as a Faraday cage.
vincent7520 (author)2013-04-20
How does it stand on nuclear radiations, chemical exposure, and bacteriological hazard ?…
Then again beware of anything that remind of a cooking pressure pot !!… :/
dlebrun (author)2013-04-19
This is amazing! So, can you do something for external hard drives? I didn't realise how sensitive they were and my husband knocked over 2 1T units and crashed them.I had just cleared off EVERY computer I had info stored on (about 25 years worth) thinking this would be safer.
I really want to make sure it doesn't happen again.
Zaqq (author)dlebrun2013-04-19
Thanks for the compliment. I do not believe making one of these for a HDD would be very difficult but I would have to change the design of the shell. The only thing i can think of would be cutting multiple pieces of flat steel and welding them into a box shape. I do not think this would be as strong is the tubing that I used though. I will most likely move on to more projects though, as I am happy with this current build. Meanwhile, you could store them in a small safe since I doubt you take your hard drives in rugged terrain. Have a good day!
jkantola (author)2013-04-19
Why not use a short iron pipe with screw on end caps, much easier to make
Zaqq (author)jkantola2013-04-19
Because building it is the fun part! :)
brtechnology (author)2013-04-19
Fortunately, solid state memory in thumb drives is not magnetic. Flux away!
Pfarmkid (author)2013-04-19
WOW!!! nice job. wish i had a welder so I could make one - no world war three action here though
Great Job! Best Instructable i have seen yet
Conrad
iamallie (author)2013-04-19
AMAZING! That's really cool :)
Rangemaster42 (author)2013-04-18
I'd like to see you going through a security check at an airport with that unit. I bet you'll lose your flight
Zaqq (author)Rangemaster422013-04-18
I thought of that when I realized it looked remarkably like the pipe bomb from the Left 4 Dead video games.
eresendez1 (author)2013-04-17
Make an iphone case
Zaqq (author)eresendez12013-04-18
I would not want to sacrifice my iPhone for the tests. :)
rifakungen (author)2013-04-18
This is neat :) Though, there is already the Corsair Survivor ;)
Zaqq (author)rifakungen2013-04-18
Did not know those existed. I'll have to get one someday and create a competition, DIY vs Professional.
plantprof (author)2013-04-18
Nice project! Could closed-cell foam water pipe insulation work as well? [or even those closed-cell foam swim "noodles"?] Has there been any "chafing" of the foam by the USB as it is shaken inside the container in tests/normal use, and is green dust coming off? Good excuse to get a welder! [among others].
Zaqq (author)plantprof2013-04-18
I would think that the closed cell foam would work, but I do not know for sure. There has been no chafing that I have seen, and the dust was there only the first two times we removed the drive, the dust subsided afterwards.
emerson.john (author)2013-04-18
A++! I really like this.
Where DID you get that wallpaper?
Zaqq (author)emerson.john2013-04-18
Thanks! Here is the link to the wallpaper: http://sharpwriter.deviantart.com/art/Bill-Clinton-the-Lady-Killer-357619589
muhammajunaid (author)2013-04-18
That was one tough USB,
I think you should challenge the blendtech guy, and lets see Will it Blend?
astrong0 (author)2013-04-18
I love Instructables for one of the main reasons for things on this site, we build things because we can!
Pixelmonster (author)2013-04-18
But the question is: Will it blend?
notimeoff (author)2013-04-18
There are times in life when everyone needs to solve a simple problem with and over the top solution.....I love this :-)
PS: my way of doing the same thing was go to a good tobacconist, buy a great cigar that comes in and tube.... smoke the cigar accompanied by some good beer, ( friends optional ), place USB drive in empty tube and bury in the backyard under a rock.
out-of-the-box (author)2013-04-16
I honestly think this could survive a shock wave or even an explosin. haha very cool!
mauronichols (author)2013-04-15
If you could cut steel the with that Chop Saw it isn't indestructible. You can add some kind of password to the USB and make it better for the data. You didn't protect that USB from magnetic erasers. It's a nice job anyway.
mrmerino (author)mauronichols2013-04-16
If the can is magnetic then it should deflect the field.
mrmerino (author)2013-04-16
I would have gone with a drab olive, but that's still really awesome.
fungus amungus (author)2013-04-15
All the indestructibleness and it still takes a couple tries to connect the USB. Why must it always be upside down the first time!
It follows the same law that newton discovered. Buttered Toast always falls butterside down.
katieqm (author)2013-04-15
Wow need to get me one of these!
cod3hack3r (author)2013-04-15
get the iron key!
IR0NxLEGEND (author)2013-04-15
Looks nice mate, I always bust or lose mine working in the "field". Oughta try it out.
About This Instructable
91,799views
292favorites
License:
More by Zaqq:Raspberry Pi Touch Screen Car ComputerPortable Raspberry Pi Emulation MachineFloating Game/DVD Shelf
Add instructable to:
