loading
Step 3: The A-frames
The base was made up of two A-frames, each 1.85m tall, which would lean towards each other when assembled.
<p>addition, not edition</p>
<p>double plus good.....</p>
Thanks for the instructable - it helped a lot. A bit of editing to use the materials we had on hand and we used to send pumpkins flying for a church festival. I forgot to try for a good photo the day we were using it. Counterweights were 475 pounds - mainly old barbell sets and some chain.
the one photo above is just a picture while under construction - the final product was square and had more boards (in x shapes) for support. We left the sides (base 4x4's) wide on purpose for carrying.
Forgot the video - old phone did take a video (very short and not very good), but the trebuchet worked well this year too http://www.youtube.com/watch?v=9PtVMy1SbaM we are making some adjustments for next year - fires ok. Now to get distance better. Short sling this year due to forgetting the actual one at home.
Wow good job - it looks like it would have shaped up to be an awesome piece of equipment! I'm glad I could help. Definitely get some photos and /or video next time you take it out, I'd love to see it in action!
People in asia used it too but that was because the Macedonians and other parts of greece developed it
How big does the axle and the 2 other bars have to be? (Thanks a lot for this instructables it was very useful and awesome) :) <br />Live long and prosper.
The axle we have is about 3cm diameter and we used the same bar for the counterweight pins. Originally it was a hollow tube but that bent on the first use. We couldn't find 3cm solid bar anywhere so we ended up putting a number of consecutively smaller tubes inside each other to make a solid bar. <br>Thanks for the compliment and well wishes!
&quot;...one end of the sling detaches (when it detaches is adjustable, to account for differently weighted missiles) and opens out to allow the projectile to be thrown free.&quot;<br> <br> Can you please explain how it works?<br> <br> I'm making a trebuchet, and my fear is the the projectile does not free itself and stays tangled into the sling.<br> <br> Thanks in advance!
--setup--<br> - one end of the sling is attached to the arm of the trebuchet, and the other to hangs free and is attached to a ring.<br> - In step 9 you see the the release mechanism. It's pin, an you can adjust its angle with respect to the arm. The ring goes over this pin, so that the sling is now attached to the arm at both ends and the projectile won't fall out<br> <br> --firing--<br> - When the arm rotates around, the sling moves with it, but at a higher speed.<br> - As the two bodies (arm and sling) rotate, due to their different velocities, the angle between them will change. In the beginning, when the arm is at rest, they're at ~120&deg; to each other.<br> - Thanks to centrifugal force, as the sling rotates around, the projectile imparts a force on the sling outwards at 90&deg; to its direction of motion like swinging a bucket round an the water stays in.<br> - When the sling moves to be roughly inline with the arm, at 0&deg;, the projectile's centrifugal force will be acting at ~0&deg; to the arm too, and it pulls the ring off the pin.<br> <br> --adjustment--<br> - What keeps the ring on the pin is friction. The projectile is always trying to pull the ring off, with its F*cos(a) where F is the centrifugal force and a is the angle between the sling and the pin.<br> - at 90&deg;, the cos(90) is 0. So it is physically impossible to pull the ring off.<br> - at 1&deg;, it would never happen, but if theoretically you had a ridiculously heavy weight moving extremely quickly, F*cos(1) would be enough to overcome the friction between ring and pin.<br> - at 0&deg;, cos(o) = 1, so ALL the centrifugal force is acting to pull the ring off the pin<br> <br> - SOOOO, the heavier the projectile, the earlier it will release, because it will have more centrifugal force to overcome friction at larger angles. This means that you have to adjust the angle of the pin so that is points more upwards (when arm is ready to fire) so that when the sling releases at 0&deg; to the arm, not earlier.<br> <br> You asked for an answer, you got it!<br> <br> There's a good video <a href="http://www.youtube.com/watch?v=NV9iK5PFbiU" rel="nofollow">here</a> showing a slow mo of the sling releasing if you need a visual
*edit: I meant at 89&Acirc;&deg; it would never happen, not 1&Acirc;&deg;. <br>At 1&Acirc;&deg; it would almost certainly release with anything weighing more than about 1 gram (the weight of the empty sling would be enough)
Thank you very much for this very thorough and helpful answer!
we made a trebuchet for a scout project. We lobbed water balloons into the campsite of another troop, to our great amusement. <br>The best projectile was to tape sparklers onto softballs. DIY meteors; very cool
Hey now this is EXACTLY what we need over here in Ireland! Maybe a tad BIGGER though. Thanks for the instructions and helping me to realize that I am not alone in my madness and that stuff NEEDS to get launched! Amen
I take it you play rome total war. Awesome !!<br>
good job with the trebuchet. few changes and suggestions first off all trebuchets use counter weights. second i would hinge the counterweight in between the main axle and itself creating greater efficiency. next try a more advancd design like a floating axle trebuchet or king arthur trebuchet or my favorite the floating axle king arthur trebuchet (FAKA). <br>good work
Thanks for the suggestions!<br>I've been thinking about a floating arm trebuchet for a while now, but I'd never heard of a King Arthur - I just googled it and am very excited :P
yes, the king arthur is a little more advanced especially with the trigger release system. i am proobaably going to make an 'ible on the FAKA im building. great job. <br>oh and is the massive counterweight really necessary
No not at all, most of the time we're actually just running off 2 of 4 weights (so 60kg) but with a missile of any more than about 1.5kg there's a noticeable improvement in distance using the full 120. Also, I just came across an article on &quot;traction trebuchets&quot;, which used teams of slaves and a big rope to pull the arm around, so there :P
I have never heard of a Traction Trebuchet. that sounds like a crazy idea. what is your regular ammo for your trebuchet, rocks, logs, or somethings else.
Yeah I guess so, the usual - boulders, dead cows etc.<br>actually it was the first kind of trebuchet, before they thought of using a big weight
oh i also notice in the video that oyur throwing arm is curving during every throw. i would try and make the arm one peice as when the arm curves you lose energy due to the joint.
dead cows. hahaha <br>i normally just throw rocks or waterballoons. once i tried to throw a firework. it didnt work too well. :) <br>traction trebuchet. hmmmm <br>just a crazy idea
I've made a couple trebuchets in my time, but never one that was mobile! Great job!
Thanks very much!<br>I too have made a few catapults in the past, but when we designed this one we decided that it was one of the - if not THE - main criteria that it would pack up really easily and be fully transportable
Cool!
Okay, this is pretty cool, and the counterweight makes it look kinda like Thor's hammer or something!
http://www.youtube.com/watch?v=cBnAQ85IJWg
About This Instructable
54,122views
66favorites
License:
Bio: I study Aerospace Engineering at RMIT, in the hope that one day I will be able to bring about the return of intercontinental airship cruises ... More »
More by squiggy2:Autonomous Miniquad (software) Autonomous Miniquad (assembly) Wiring an Xbox Kinect for USB
Add instructable to:
