So I removed the planks on my bench, trimmed them so I had a width enough for my saw to fit down into the table. Built a bottom for the saw to set on and made sure the bed of the saw was flush with the top of the workbench. The saw can come out and be stowed out of the way.
Now that there was a recess, it needed a cover to make the bench one surface again... and since it would be removable, I made the cover double as a router table too. All that was needed would be a secure way to fasten the router to the underside but enable it to easily be removed for hand work. I traced my routers' base on the cover, glued two blocks at near right angles along the traced line, so that the round router base would nestle into place. Another longer board acts as a swing arm on the opposite side to clamp the router firmly against the other glued blocks. A beveled bit of lumber wedges the router tightly to the underside of the cover plate. A simple bungee is all that is needed to keep the contraption snug.
The workbench is electric! I know, you'd never see this in the woodwright shop, but my bench plugs in like a lamp. I wired a n outlet under the bench and is controlled by a switch. This is so that my shopvac dust collector runs at the flip of a switch and my saw and router can as well. flip a switch and the saw can work or router starts spinning, with the vacuum starting at the same time.
Visit Our Store »
Go Pro Today »
Thanks for sharing an impressive project! I feel motivated to do this.
It's normally made from a piece of board a few inches wide and several inches deep, maybe a 1' board or a scrap of 12-18 mm plywood; and has two cleats (say about 1" square, or 1" x 1/2" even) on opposite ends ~ one on 'top' at the back that stops the piece you're working on, the front cleat is 'under' so that it holds against the front of the bench.
So a typical "bench hook" is really only about a quarter of the size of that one in the photo. You should be able to find a better description in any good basic woodworking or carpentry manual.
Some instructive websites out there must have such info' as well..
Google is your friend at these times...
Then I got a job and we had to move and we got a house AND I got my detached garage workshop *giggles like a giddy little school girl* I still plan on making my portable workbench because I've had to many instances where a project requires to pack up the tools and go to the remote site, so I just like the portable option.
This is it.
