3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Intimate Video Light/ Handheld photograpy light.
  • C:\Documents and Settings\owner\Desktop\camera light\New Folder\IMG_6875_resize.jpg
  • C:\Documents and Settings\owner\Desktop\camera light\New Folder\IMG_6879_resize.jpg
  • C:\Documents and Settings\owner\Desktop\camera light\New Folder\IMG_6876_resize.jpg
  • C:\Documents and Settings\owner\Desktop\camera light\New Folder (2)\IMG_6955_resize.jpg
I know what you're thinking. By "intimate," I meant close-up lighting under difficult light situations--not necessarily for "intimate situations." (However, it can be used for that as well...)
As a New York City videographer--or guerrilla filmaker--it's sometimes difficult to have the necessary lighting. As a solution, I built this compact, portable device.
This light is a great way to get a really unique, soft light that works great as both a fill (in daylight) and aesthetically-pleasing primary light in lower-light situations.
The design is a nice alternative to what's on the market, as it gives a more even spread of light than some of the shoemount spot lights available--especially for close-up situations. This particular design is for the Canon GL-1; with some ingenuity, however, the design can be modified to fit many existing video cameras. (Plus it makes a great handheld fill light for still photos.)
I've tried to make this as simple as possible for anyone to make one of these lights. I've tried not too get too technical (to scare off the less-technically-inclined) or too basic (to bore the techies). I've created a resource page and parts list at the end. The build time, with minimal tools, is around 3-4 hours.
Step 1Tools and supplies.
Tools and supplies.
Tools needed:
Ruler or measuring tape
Saw (bandsaw preferred, but can be mitered by hand)
Drill press (preferred; drill okay as alternative)
Drill bits (size based on specifics of components you buy)
Screwdriver
Wire strippers
Soldering iron how to
Pliers
6-32 Tap (can be substituted with self-tapping screws)
Materials needed:
Four Luxeon K-2 LED's
Two 2-AA battery holders
Four AA batteries
Two 5-inch aluminum picture frame kits (Note: only 2 rails come in each kit)
Four 1 and 1/8th-inch makeup pots if you get 5 you'll have a carrying case for extra screens and diffusions.
Four 1/4-inch 8-32 barrel nuts
Diffusion
1" wire screens to be used if needed to cut down light in the diffusers
On/off switch
1.5-Ohm resistor
4 6-32 U style clips
4 6-32 x3/8 screws
Expendables:
Sandpaper (200-grit)
Red and black 22-gauge wire
JB Weld (I used the fast set JB-kwik)
Locktite
Solder & flux
Doublestick foam tape
Heat shrink or electrical tape
Optional materials:
Beleza Pura Cachaca
Basil
Pepper
Ice
Potato chips
Sour cream
Lipton onion soup mix
Pizza
For the record, by no means am I an expert when it comes to electronics. I know just enough to get by. With that in mind, please use caution when using my recommendations on wiring, resistors, heat sinking, etc. I am also open to advice, feedback or criticism (constructive or destructive).
However, when it comes to the booze, trust me.
27 comments
Feb 17, 2010. 10:51 PMolivermellan says:
 yum
Jan 23, 2010. 3:59 PMphant0m_sp00f3ra says:
 I am thinking in moding this design to fit my Reflex camera for taking portraits, sort of DIY Ring flash. I think that i could mount all the electronics in a spare Lens hood. I just wanted to know, do this rig get's along with faces? Probably ill diffuse it a little, Waddaya think?
Feb 8, 2008. 3:07 AMhal9000 says:
Great instructable. I've been looking for a cheap video light. I'll definitely give this one a try. Thanks
Oct 8, 2007. 5:34 PMfbosch says:
I was wondering how well this light can be adapted to 16x9?
Sep 19, 2007. 4:47 AMjamese says:
Pretty cool, but I'd suggest putting the lights on something so they can pivot. Maybe not a full range of motion, but at least along the Y axis (to pivot horizontally). In some of the situations, the lighting is kind of flat, so this may help give the whole key light/fill light effect. Other than that, really cool.
Jul 4, 2007. 11:56 AMidamtnboy says:
Which color of LED, the cool white, neutral white, or warm white?
Jul 3, 2007. 7:21 PMidamtnboy says:
Just learned of this instructable. Wish I would have had it a couple of years for a special photo project I did! How about noting which lighting is which on the bottom set of stills? I'm having trouble distinguishing which is which.
Jul 3, 2007. 10:09 AMkrip says:
Fantastic instructable! Your step-by-steps are so very clear (and well-written), and the terrific photos illustrate the process and make it non-intimidating. The video examples of what this light can do have motivated me to get started on this project right away... Good luck!
Jul 2, 2007. 11:53 AMApplesGuy says:
Excellent instrutable...Great concept,idea,detail, photos. Just a very cool project... You have got my vote. I Hope you win.
Jul 2, 2007. 8:08 PM5thgrd_techr says:
Are you smarter than a 5th grader? Well if not you still might be able to build this. Very clear, easy to read and understand. Aside from the soldering I know a few of my students could build this with these directions. Bravo! As far as instructions give this person an A++. Just found this site, I love it.
Jun 25, 2007. 12:57 PMDirk_Ridgable says:
Very Cool!!! I've been wanting something cool to build and I have a GL1. Is there a model name or number for the frame you used? I don't want to get the wrong one. You've got my vote as of now.
Jun 25, 2007. 3:57 AMMyself says:
Good stuff! The January '07 issue of Nuts and Volts had a similar lighting ring project.
I'm curious how heavy your rig is -- the frame looks pretty bulky, to accomodate those batteries right inside itself. But it looks like your camera's not slipping into an Altoids tin any time soon, anyway. ;)
Jun 25, 2007. 10:05 AMgmoon says:
I immediately thought of 'ring light' when I saw this one (as Myself noted first.) These things were invented for macro photography (and used a lot in dentistry and such), but the unique lighting effect for regular photography (models, portraits, etc.) were so cool that photogs began using them creatively. Cool enough I might have to try a build myself...maybe with a larger diffusion ring.
Jun 25, 2007. 12:34 AMje1330 says:
This is great, I've been thinking of something similar to this for a while, but as a macro light for use with my DSLR. I could get away with only two LED's for that. I think I'd add a switch for each LED though, so as to be able to turn one off for lighting a subject from one side or the other. It's not a large distance with something like this, but sometimes a few inches can be a big difference in the image with still or video photography. Good job though Curve, very nice...
Jun 25, 2007. 1:47 AMRavinss says:
This is one of the best Instructables I've read... really great descriptions, photos and attention to detail. If you've entered this in one of the competitions, I hope you win.
Jun 24, 2007. 10:57 PMtheRIAA says:
all your LED links are dead, you can get some nice LEDs from Dealextreme.com for cheap
Jun 25, 2007. 1:45 AMFrenchCrawler says:
That looks to be a real nice site to get other items too :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:curve12
