Step 7Shopping list and Resources
Here is the first footage I shot using this light. My camera was set on auto exposure and you can see the difference when the light goes on and off. I'll be adding more footage later this week.
As many of you are probably aware, McMaster Carr is a great source for much of the stuff for a project like this. On McMaster's website and Ebay, I was able to find everything I needed rather easily. I've created a detailed shopping list with McMaster's product numbers. Hopefully this will make building a light for yourself even easier.
McMaster (Use part numbers in bold below and the build your order tab.)
7712K15 Battery Holder, Polypropylene, End To End Style For 2 AA Cells
7347K53 Miniature Toggle Switch, Spdt, On-On, 6 Amps At 125 Vac, Quick-Disconnect
7598A975 Light Duty Polyethylene Foam Tape, Acrylic Adhesive
93121A315 Aluminum Binding Screw, 1/8"L Barrel, 7/16" Head Dia, 8-32 X 3/16"L Thread
7605A13 J-B Weld Epoxy, 2 Oz, Begins To Harden 4 Min
9317T553 Corrosion-Resistant 304 SS Wire Cloth Disc 60 X 60 Mesh, 1" Diameter
9317T551 Corrosion-Resistant 304 SS Wire Cloth Disc 20 X 20 Mesh, 1" Diameter
9317T551 Corrosion-Resistant 304 Ss Wire Cloth Disc 20 X 20 Mesh, 1" Diameter
94808A105 Standard U-Style Clip-On Nut 6-32 Sz, .045"- .062" Panel, .296"HOLE Ctr To Edge
69835K711 Irradiated Stranded Single-Conductor Wire Ul 1429, 26 Awg, 150 Vac, Red
69835K311 Irradiated Stranded Single-Conductor Wire Ul 1429, 26 Awg, 150 Vac, Black
Ebay
Lumiled K-2 LED's ( http://myworld.ebay.com/thontia )
Make-up pots ( http://myworld.ebay.com/pilotvials )
"Pearl Paint"
Nielsen Bainbridge metal frame (They have a few models; it's important you get the right one. It measures 1-1/4" deep and 5/8" thick.)Product #f90502 (f90602 is a six" frame)
Alternate Resources
Lumileds
TheLEDLight
LED calculator
Here are some images of the effects of still shots with this light. I shot each of these with no extra light, just the built in flash, just the LED light held of to the left, and finally flash with lED of to the left again. Let me know what you think... more video coming soon.
UPGRADE
I recently upgraded the frame to accept a 1/4-20 screw in the base for mounting onto a tripod. Quick easy setup for extra lighting effects.
Add Comment
