I jumped on the band wagon as well and started making a 3D printed docking station. I started modeling a 3D printed docking station but as I worked on it I wasn't happy with the results. It lacked the extra geek factor I look for when purchasing my own Apple accessories, it was mundane and just plain ordinary.
When people walked by my desk I didn't get any of the neck breaker double takes. So I endeavored in my search for the ultimate docking station design. Still, nothing out there was good enough so I started asking myself what was the ultimate sign of power and geekiness. Then while browsing the inter-webs I came across a 10,000 dollar life size 3D printed Iron Throne from the Game of Thrones HBO series. Then that's when I realized that the Iron Throne would make the ultimate docking station for any true geek out there.
For more of my work go to nuPROTO.com
Step 1: Modeling and cleaning up the model
Modeling was actually the easy part believe it or not. Getting it non-manifold, "watertight" and without any holes was the greatest challenge. Basically all of the technical details which are essential when 3d printing. To give you an idea of the amount of work.. you see those little yellow dots on my model? each dot represents a non-manifold vertex that, after a few major clean ups, still needed to be fixed.
It was extremely painful and extremely time consuming. However, after I was done I had to make it thick enough to be printable (greater than 1mm) and skinny enough so it didn't take forever to print and use and absurd amount of material. Creating such a complex model is no easy feat in and of itself, and each step required more precision since I knew I was going to be printing.
Step 2: Slice it up and get it ready for printing
Step 3: Interchangeable Custom made docking stations
Step 4: Printing and glueing model together
The final step was to glue the parts together, sand, and prep for painting.
Since my printer uses ABS plastic (not PLA), I glued the parts by melting small pieces of ABS in a cup using acetone. This makes a very fine and sticky paste that is brushed on using small brushes. As the acetone evaporates and dries out... the paste becomes solid and fuses both pieces together. This process gives excellent results that leaves a seamless effect. Everything else like crazy glue, two part glue, plastic glue, etc are all horrible and leave very bad seams and discoloration.
Step 5: Prepping, sanding, prepping, sanding and painting!! Then Enjoy!
And voila.. The ultimate Game of Thrones inspired Iron Throne dock is created!!..
Hopefully you guys like it.. So please comment, like, share and vote for me for all the available contests!!
Also please check out my website nuPROTO.com for more of my work and my upcoming projects.
Thanks!
Visit Our Store »
Go Pro Today »
sunshiine
If would ever consider releasing the stl let me know and I could build you one (free) and of course one for me. My son is a big George R. R. Martin fan. Regards
Recently i published a Metal-Casting-at-Home tutorial with the low cost Bismuth (Metal) using your very own personal 3D Printer, ABS filament ,Acetone and a free software called Meshlab.
This innovative easy method (originally created by CosmoWenman) will cut your 3D printing cost in Metal to practically nothing.. instead of paying $8-$10 per cubic cm to 3D printing services who by the way demand a 3mm wall thickness..
http://www.thingiverse.com/thing:33450
Dizingof
http://www.thingiverse.com/Dizingof/things
