The inevitable: I make an instructable on: the Joule Thief.
This is a great circuit to teach children about electronics especially inductors and coiling considerind it contains so few parts and is so easy to make...
Let's get started.
To get us started, I have a video.
By the way: I had forgotten to put the arrows for the LEDs...sorry.
Remove these ads by
Signing UpStep 1Materials, Materials, Materials
1 "dead" battery (with 1 volt left.)
1 2N3904 Transistor
1 jumper
1 handmade inductor or two pre-made.
1 Solderless breadboard
We have had lots of power autage lately therefore id like to make several joule thief but before i make the inductors I`d like to know what wire you recomend as the best- What type, number . If thicker or thinner is better. etc
Thanks
Whether or not you can use it is a question. I used CAT5 cable (solid)
Any torroid will work as long as you wrap a lot of turns. As long as you purchase a torroid like in the picture below...to me, color and size don't really matter but I could be wrong.
I got the same torroid in your picture so I´m on my way and I understand that the more turns the better.
Thanks.
With the right transistor and resistor, you can light up 5 or more LEDs brightly. Some of the right transistors are: KSD5041, KSC2500, 2SD965, NTE11. These transistors are made for handling high current - several amps. The 2N3904 is a poor choice for a Joule Thief, its rated at an absolute maximum current of only 200 milliamps.
can i have that circuit so can drive many led instead 3, thanks
That picture with the big transistor and ic is not related to the thief in any way whatsoever. It is an organ I never finished. I just needed a large breadboard. I don't know the number of LEDs or the power each one consumes so stick a potentiometer where the 1k resistor should go and find something you like by adjusting the values.
2==what is the diameter for the ring that you use?
3==magnetic ring or ferric core ring?
2. I used a 1 inch (2.535cm) diameter ring.
3. "Ferrite" not "ferric" core ring.
Very good idea.
Thanks for your instrucctios,
Alarchbold
And I got a recycled inductor like this one:
http://media.digikey.com/photos/Bourns%20Photos/08412.jpg
Can I use it? And how I can connect it? because it have 4 pins, not only 3...
Thanks!
Your BC547 should work just fine...just make sure you check which pin is which.
But this is not a transformer, it seems to be one, but is an inductor...
Well, I try to make an inductor with an speaker magnet.
+1 point for you! ;)
Good Luck.
What is power? Power is voltage x current. If there is extremely low voltage say...0.5 volts...and 15 amps of current, then the power is 7.5.
However, if voltage is high and current is low, like in solar panels, then power is also low. If I had 15 volts and 0.5 amps then my power would still be 7.5.
Now, if I had high voltage as well as current, then the transistor may blow such as 15 volts and 15 amps...it equals 225.
However, if I had lots of LEDs, then there would be much less current because each LED steals some current. That's why I put them in parallel not series. In series, each LED takes the voltage it needs and then passes it on. However if one light blew, all of them would blow. In parallel, the LEDs try to all pull whatever they can. However, if I have lots of them and they all pull all they can there would be less current for the transistor to dissipate.
I know what you mean though. When I left out the resistor and had one LED, I heard a slight whistling sound. as I added more LEDs the whistling sound slowly died down.
When I have built joule thief circuits I normally put some hot glue on the inductor to stop the noise. It has worked for me.
How many LEDs did you use? I left out the resistor because I was going to power lots of LEDs for a long time.
What types of LEDs did you use (color) and what voltage are they rated at?
What type of transistor did you use?
These questions will help me access your problems.
If you use a bunch more it should work.
