Designed to be the most powerful* K'nex fully-auto machine gun yet. Really - every single round of Cyclone's belt carries some decent strengh for a K'nex gun.
- If you have enough pieces, build two! It's one-handed.
- Unlike its picky predecessor, Cyclone has an open front and can use any size of rod for ammo. This includes flighted 'sniper' rounds.
Version History (updated):
2.0 - "Cyclone" first created but kept classified. Based off of the likewise-named weapon from Perfect Dark, it was powerful and fast-firing, but pitiful that only 17 of 19 barrels were usable.
2.1 - Extensive restructuring was necessary to make it fire from the top where barrels are further apart, instead of the side. This new layout is more compact.
2.11 - Significant improvement made to ammunition belt allowing for variable ammo sizes.
** Before you build: Know that not all K'nex motors are made equal. Some K'nex motors (at least a few of mine that I know for sure) are incapable of being used on the Cyclone because they too easily start clicking under too much load. Proceed if you are confident you have a good motor. Just a fair warning. **
*Hardest hitting, not fastest rpm.
Remove these ads by
Signing UpStep 1: The Ammunition Belt
Find an efficient method for building them, else you'll be spending a lot of time on this step. (okay, it will take a long time regardless)
This step alone requires:
209 dark-grey connectors
209 blue spacers
57 grey spacers (each counts as 3 blue spacers)
57 black chain-links
57 red and light-grey connectors
.. among other things.
Use 2x type 64 rubber bands only! Too much power may result in broken K'nex pieces.
For simplicity's sake when attaching and removing the ammo belt, make sure that every black chain link is facing down.
Cyclone requires a specific number of barrels, unlike other open-belt machine guns. 19, to be exact. Get to it!
Visit Our Store »
Go Pro Today »
Love to make it
and to make two i mean holy s***!!!!!
*3.5
But we cool. =p
=p
http://www.instructables.com/id/Knex-Sniper-Rifle-SR-70-Instructions/
@Warlocksteve, lol take a look at this gun when it finishes.
, cause its like 1 battery pack with two motors?
Also, Cyclone has more barrels, 16 vs. 19.
I wish we could compare videos, but here's what I have, two cyclones (both operated by me at the same time) firing off a full load of grey rods (Like most every other machine gun cannot do) It can fire red and yellow rods a whole lot harder, but you get the idea.
http://www.instructables.com/id/fullyauto-knex-gun/
here is what I did with the motors they are sweet!
What if there was a gun that had three revolving barrels that were triggered with a knex piece having three gears on it and each level you push, it would trigger the corresponding barrel.
How about this barrel X 3
It would be nice to have an unreal tournament gun =/ sadly i dont have enough pieces.... just bought enough to get two cyclones... and just enough to come up with an idea....
p.s. your machine gun rules. but i modded it to work with my 6 inches of wire. the picture is on the machine gun instructable
thnx perfect duck for your perfect cyclone!
However, don't feel let down. My twin pistols are built very similarly to Red Impact and carry the same theme of dual-weilding action, on a much smaller scale. I've decided to post them eventually. Here's the preview.
- The ammo belts took an excruciatingly long time to build. The repetitive process almost drove me insane. The rest was easy and fun. (I like building when it's not the same damn thing over and over again!)
- Thanks. I owe inspiration to my earlier K'nexecutioner project, and Perfect Dark.
- Medium gears are an elusive piece that only large sets seem to come with. I never have enough of them myself. Took every last one I had to make the cyclones.
somewhere it should give you the fps
all you need is that, and a backdrop with marks at equal intervals so you can measure the progress of the projectile from frame to frame
then you can get the velocity using the simple equation: velocity = distance/time
doable?
but anyway amazing gun !!!!!!!!!!!!!
http://www.knexusergroup.org.uk/acatalog/knex-parts-guides.html
But I have yet to make a really cool video showing it off like I did for the first K'nexecutioner.
