The Key Keeper
43,839
690
79
Posted
Introduction: The Key Keeper
Do you ever set your keys down on the desk, to turn around and see them walking off with the small person, aka little brother. As the oldest of eight it happens to me all the time. So I made my self this key keeper, its my take on the classic hook that you hang your keys on.
Thank you! Caleb Stephens
Step 1: Materials and Tools
Materials
I used two air fittings a quick coupler and the plug that goes in to it. You can get those at any hardware store or Amazon.com.
For the wood I used a scrap of black walnut I had cut for some knife scales. You can use what ever wood you prefer though. If you feel really bold try some iron wood. ;)
This is optional but I used a 12 gauge Winchester shot gun shell to make a cap to cover the screw I used to mount it. If your not the gun type you could always use a dowel rod, or nothing at all!
Tools
A drill with a 3/4 inch spade bit and 1/2 inch drill bit.
Sand paper various grits
And you do not need this but I used a belt grinder and buffing wheel to finish some of the brass and metal pieces.
Step 2: Wood
I cut my block 4 1/2" by 3" you can make it as small or as big as you want though, if you want multiple key keepers on one board then cut your self a longer one. After your board is cut just sand away get that thing so smooth that it feels like something really smooth! Remember to go with the grain of the wood as well that's always important to getting it smooth.
Step 3: The Key Chain
Now you need to make the piece that will hold your keys to the holder. I ground the threads off the fitting because I wanted to if your not picky like that then just skip this part and drill that thing!
If you do want to grind them off just start sanding with your belt sander till its all smooth. A very good suggestion that was put in the comets is to place the fitting in a drill and use a file or sand paper to crate a lathe affect. If you do not have a belt sander this would be the best way to do this step.
Drill your hole about 1/4'' in from the end of the fitting, that way you can get it on the key ring. Once your holes drilled clean it up with some 220 grit and buff it all shiny. If you don't have a buffing wheel i'm sorry I charge $20 per a fitting if you want me to do it for you.
Step 4: The Coupler
Now you need to mount the coupler to your block of wood. I used a 1/2 inch drill bit and drilled a hole about 1/2" into the block, then threaded my coupler into the block make sure its flush and tight. Be careful not to mar up your smooth sanding job.
Step 5: Spice It Up a Little
I used a 12 gauge shot gun shell if you want to do something else by all means do it! Note to everyone make sure you use a EMPTY SHELL! Do not try to cut open a loaded shot gun shell that's just stupid.
You need to take your shell and cut all the plastic off and sand about 1/4" off of the metal that way it fits in the wood well.
Then take a 3/4 inch spade bit and drilled a hole about 3/8 inch deep into the wood. Now I can put in my screw and then cover it up with the shot gun shell.
Then place your piece into the hole if it does not fit you might have to take a rotary tool and sand out the hole a little not to much though. Once its in your ready for the instal!
Step 6: Instal!
Find a stud please! don't just put a screw any wear its a bad Idea. I found two studs when I was at it.
Then put your screw in I used a 2 1/2" torx head screw with a small washer on the end. Once its on tight and level place your 12 gauge cover over it. And BOOM!!! You have your self a child proof key keeper that looks pretty good as well.
Step 7: Final Thoughts
Over all I'm happy with how this came out. I think I would have made mine longer and put three couplers on so I could keep a few different sets of keys on it. Other then that I'm happy with it.
As always thank you for taking a look! I hope you like what you see and I would love to see your take on it. If you have any questions ask away.
2 People Made This Project!
  • Gluten Free Challenge
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
75 Comments
Very cool!! I like the spent shotgun shell repurposed!
Whats it's purpose though? I like to reload mine for a purpose. I like it. Its a nice touch but serves virtually no purpose. Unless I'm missing something.
The purpose of the spent shell is to cover the screw hole so it looks nicer
You are - he's not a redneck who needs to save every spent shell because he's broke. The purpose of the spent shell is for looks, just like your hairstyle - and your clothes, and car, and furniture and everything else you own. It doesn't HAVE to be that way, you could have your hair uncut and messy, why spend the money on barbers and product? Why do your clothes look that way? you could wear sackcloth and still keep warm. #seriouslystupidpplannoyme
You're a jerk. I asked a simple question as the covering of the screw got by me. Hence the "Unless I'm missing something?" part of my comment which the author clarified and I thanked him. All very simple without your annoying stupidity.
LOL wow - overract much? How come it's taken you a month to give me another reply, not very on the ball are you, and what's with the all the repeat posts..... online version of tourettes methinks. #trollingrednecks
No I'm just reacting, appropriately to a complete jackass. You sure have an imagination there. Unlike you in my busy schedule the instructables comment section is right their at the very bottom on my list of not "important things" nor "
just "things" I need to accomplish but "Non-important" items. Thats right its at the bottom of my "non-important" things. In fact its on my "Things I dont really give a sh*t about" list. Tourettes? Of course since you live in a hostile world you think of some bazaar negative reason for the repeats. In todays world we have electronic devices called computers. They are connected wirelessly over the airwaves, browsers freeze up. A person may be hitting enter and its not registering on their end yetr its actually being sdent. Thats the more plausible explanation for five repeats.
wow calm down just a little bit:) maybe you just cant afford a reloading setup:P it actually costs more to reload than to buy crap ammo. I reload for accuracy's sake. Obviously not shotgun shells but all my 30-06 and .308.
yes bud we get it; you have guns, good for you.. Lots of other people have guns too, not a great deal of common sense, but LOTS of guns. Maybe the common sense has a better vetting process and much longer waiting time to aquire it...
