The Keyblade
Published
Introduction: The Keyblade
About: Hi my name is Jacob and I enjoy making stuff. I don't create much any more but I might in the future. Also keep in mind most of the work here was put up nearly four years ago and at the time I was in middle...
This a keyblade i made out of the tops of lightsaber blades, carboard, tape, and keychain rings!
Hope you like it!
If you want to know how i made it go to this link www.instructables.com/id/How-to-make-a-Keyblade/
OMG! Over 500 VIEWS! I never thought my key would get so many views!
    • Stick It! Contest
      Stick It! Contest
    • Woodworking Contest
      Woodworking Contest
    25 Comments
    can you make out of wood an oathkeeper out of wood=]?
    nice keyblade man!
    Great idea . . that being said you should  try to refine your technique its not a very smooth final product
    i recently made it look a little smoother by adding metal tape and a new layer of tape for the hilt it looks alot cooler
    Yeah. its way better than my first one which was about 3 ft long or somethin and was just a tube of silver paper. I also made oathkeeper and oblivion but the oathkeeper isnt as good as this and the oblivion stinks
    But i didnt put them on instructables
    Now i did, thier on my slidehow the final fantasy and kingdom hearts collection
    cool. I bet it holds together better than mine. here is a pic of mine.
    Wow thats cool I like the teeth cuz the have the crown shape like in the games and mine doesnt, also how long is that? it looks pretty long
    Thanks, I'm thinking about putting tape on it like you did and then repainting it because all that is holding it together is hot glue so I can't swing it at all. :( Should I post an instructable on it? Oh I almost forgot, it is 3 feet and 8 inches long. Yeah I like the teeth too. I call it the nightmare keyblade. Oh and your oblivion keyblade looks great for making it out of the materials that you did. That is more of the type of keyblade to be made out of wood.
    Whats is your key made of?
    card board and PVC pipe.
    Oh OK. I could tell it wuz a PVC pipe but then you said that you cant swing it i wuz cunfused. well the blade and teeth look awesome good job, but i think the handle guard thing could be bigger, mabey you could cut some more cardboard to make a new guard. If you want to keep it as the Nightmare Keyblade i suggest keeping the blade that way and doing something cool for the guard like demon wings or tentacles or both one on one side one on the other because if its a nightmare key you should add something that you see in nightmares to make it really cool. Like i said in the slideshow for the keychain i used real keychains. but first i took a keychain ring and taped it to the handle, then i took one of those things you attach the keychains too on your backpack and stuff and clipped that on. then i just kept attaching keyrings together so the keychain is on mine is removable. If you keep it as the nightmare key or normal key once its stable you should put it on instructables :)
    Cool, I will try your keychain method. I will probably keep the gaurd as it is since it is all ready on there but on my next keyblade I will make a better guard. :)
    Cool, the bottom keyring thats conected to the mickey head is a keyring that clips and unclips so i can easily take it off if a wan to put the keychain on a diferent key and change the keychain symbol thing. Which one are you makin next
    Thats a good question. Probably the same keyblade but different colors. I am going to make a bond of flame keyblade later on out of wood. When I do the next keyblade that is when I will make an instructable. I will probably do an instructable on wooden ones too. Do you have any idea about foam ones? Just thought I would ask :)
    THAT'S TIGHT!!! I know mine won't be as detailed as that. He must have done a lot of work.
    OK here is my finished keyblade. Now I can swing it, hit stuff with it, and it has a keychain. I did this all today.
