Introduction: Knex Gun: the Kinetic Rifle
The Kinetic Rifle is finally here! To those of you who have been waiting since christmas for me to post this I'd like to say that I'm sorry it couldn't have been posted sooner...I simply have too much going on in my junior year in high school. For those of you that this gun is new to, here's a description of the gun and how it works:
This gun is a bullpup, horizontal magazine, pump action, sling semi-repeater. Quite a mouthful. The term semi repeater means that it requires two actions to load it: pulling back the band and then pumping it, rather than simply pumping it, although it has a 4 shot horizontal magazine, meaning you don't have to manually load each shot. My emphasis on this gun was to prove the potential that horizontal magazines have, and the plain coolness of the mechanism.
So I hope you guys enjoy it and I know a lot of people have been leaving recently so I'll just say this: K'nex is not dead, innovation is just currently at a standstill. If you decide to leave, your going to have the most amazing idea sooner or later and your going to want to come back. There is so much left to be discovered!
*This is an extremely complex build and pictures and image notes must be followed exactly for the gun to work. Everything is the way it is for a reason.
PROS:
100ft+ range (the ratchet can hold pretty much any amount of tension so it's hard to say the exact range)
Pump action!
Much quicker reload than other slings
4 shot H-mag
Sweet reloading and firing system
Just an amazing gun
CONS:
A little too big for some
Slow reload compared to conventional repeaters
Step 1: The Stock (bottom Half)
Each number explains each picture respectively:
1. The lower stock of the gun. Probably the easiest part to build.
2. Build the outer layer
3. Build the inner layer (notice the blue rods where indicated)
4. Build center layer (notice all the white rods)
5. Get one outer layer
6. Attach inner layer
7. Attach center layer
8. Attach inner layer
9. Attach outer layer
You've finished the lower stock!
Step 2: The Upper Stock/mag
*This step is really long
1. One of the unique parts of the gun: the stock/magazine. Also includes the ratchet and trigger.
2. The ratchet system
3. Build these
4. Build this
5. Attach (I would recommend attaching with only one whit rod at first, and adding the other after step 6. Its just easier)
6. Attach other half. Ratchet is complete
7. The trigger of the gun
8. Make these
9. Connect with white rods
10. Make this
11. Attach at center. Trigger is compete.
12. The mag pusher
13. Build these two parts
14. Now build these
15. Place them like so
16. Connect the two using a white and a blue rod
17. Secure with a blue rod as shown. The mag pusher is complete.
18. The magazine/upper stock
19. Make two of these (one without the blue rods)
20. Get these pieces
21. Add them to the outer layer (take notice of the two blue spacers as well)
22. Now make these two parts
23. Add them as shown (this image shows blue spacers on the black wheel. do not add these)
24. Make this (forgot to show it earlier)
25. Add it here
26. Make these again (just don't add the white rod to the Y connector)
27. Add them as shown
28. Add the other outer plate
29. Different view
30. Flip up side down and break where shown
31. Insert mag pusher and reconnect where broken
32. Make this piece
33. Place ratchet as shown and secure with piece made in step 32
34. Break trigger as shown
35. Thread through mag pusher
36. Reconnect the trigger. You are done with the upper stock.
Step 3: The Receiver
1. This is the receiver of the rifle. Disguised as a magazine, it definitely the coolest mechanism I have ever seen in a K'nex gun
2. The lift. This is what you are going to make first.
3. Make these two pieces
4. Make this
5. Connect the two (only 2 of the cut pieces are needed, and the receiver could be modified so that three layers of the lift protrude out of the bottom, where they could be connected, eliminating cut pieces altogether)
6. Make this piece
7. Place as shown
8. Add final layer
9. Add connector on both sides
10. Attach tan clips on each side
11. Make tow of these (one with blue rods and one without blue rods)
12. Make this
13. Add red connector with Y clip and green rod
14. Place white rod as shown
15. Make these (notice that the part made in step 14 is attached to one of these)
16. Add some of the previous pieces where shown (1 layer)
17. Add these pieces as the second layer (leave the rightmost piece unattached as shown. Notice this piece is also trimmed short)
18. Add in the lift
19. Add the rest of the pieces made in step 15 as the third layer
20. Make this
21. Add it here
22. Add final layer. You are done with the receiver.
*Unfortunately I am not able to finish this instructable today, but the rest of the gun will be posted over the course of the next few days.
Step 4: The Upper Barrel
1. The Upper barrel of the gun. Nearly identical to that of my R-SAR
2. Make 7 of these
3. And one of these
4. Get these 8 pieces
5. Connect the parts made in steps 2 and 3 to them as shown
6. Add connect them with green rods
7. Get another 8 of these
8. Connect them as well
9. Now connect them with green rods.
Step 5: The Lower and Fake Barrel
*This part has been modded slightly from the original version to improve efficiency, so it will look different that on the intro picture
1. The lower barrel, fake barrel, and pump
2. You are now going to make the pump
3. Make two of these-one without the white rods and broken pieces. (notice the 4 white rods and 2 broken pieces. (It will probably work without broken pieces, you might want to try it)
4. Now make this
5. Attach it as shown
6. Now attach the other layer made in step 3
7. Make these
8. Attach them where shown
9. Connect them with the blue rod with spacers. You are done with the pump.
10. The lower barrel. This part may be modded to eliminate the broken piece used in the receiver, but I am not sure if it will work.
11. Make these
12. Make this. Read image notes.
13. Connect them as shown
14. Attach the other part made in step 11. You are done with the lower barrel.
15. Make two of these-one with the blue rods and one without them
16. Make these
17. And these
18. Add one layer of parts on where shown. Don't forget the blue spacers.
19. Add the second layer of parts and the lower barrel
20. Add the Third layer and the pump. Don't forget the blue spacers again
21. Flip up sight. Make this
22. Place it here
23. Add the other outer layer made in step 15. Don't forget the tan clip on the sight. You are done with this step.
*24* Quick fix: Remove gray connectors on each side of the middle layer and replace with a red connector that connects to lower barrel
Step 6: Putting It Together
Each number explains each step respectively:
1. Connect the lower barrel to the upper barrel
2. Connection points shown here
3. Connect the upper and lower stock
4. Connection points shown here
5. Connection point at handle
6. Attach a green rod here
7. Connection points shown. Pay attention to the connection between the red connector and the piece you just attached the green rod to
8. Connect the receiver to the rest of the gun
9. Connection points here
10. And here (green connector connects between black connectors)
11. Almost there!
12. Get these pieces for the band guide
13. Attach it to the front of the gun as shown
14. Just need to add the rubber bands!
15. Attach bands here (number of bands will vary depending on the strength of the band used as the sling. I used two.)
16. Another view
17. Attach these to the lift-one on each side
18. Attach a band to the pump
19. Feed band(s) through barrel and over guides and hook on a blue rod. If you are using a single band you will have to break the barrel to feed it through
20. Top view
You are now done with the most advanced piece of knex weaponry out there. Just don't kill anyone please.
