It is a simple Spectrum Analyser, completely done in software, which reads the output from an earphone plug (on A01), and generates a 5-channel pattern on the LMP, based on the loudness and frequency of the signal.
Here is a sample video:
All you need, beside the LMP and, of course, the Arduino, is a cable with a jack that fits into an earphone socket. It doesn;t matter whether you use the Left or Right channel.
Remove these ads by
Signing UpStep 1The Sketch (LMP_Musicator01)
- VUmeter / Light organ (Full db presentation)
- Horizontal presentation - center-out linear display
- (c) Copyright 2009 QS@quantsuff.com
- All Rights Reserved
- LED Matrix row:1-5; col:1-6
- Map PORTB == D8:D12 - pin[row+7] : +v
- PORTD == D2:D7 - pin[8-col] ; Gnd
- Our output: col::D2:D7 -ve (LOW) while row::D8:D13 +ve
char msg[] = {
0x11, 0x0a, 0x0e, 0x0e, 0x0a, 0x11, // Starburst
0x00, 0x00, 0x00, 0x00, 0x00, 0x0e,
0x11, 0x19, 0x1e, 0x00, 0x1f, 0x10, // Q U
0x1f, 0x00, 0x1e, 0x05, 0x1e, 0x00, // A
0x1f, 0x06, 0x0c, 0x1f, 0x00, 0x03, // N T
0x1f, 0x03, 0x00, 0x12, 0x15, 0x09, // S
0x00, 0x1f, 0x10, 0x1f, 0x00, 0x1f, // U F
0x05, 0x05, 0x00, 0x1f, 0x05, 0x05, // F
0,0,0,0,0,0 }; //Plus an overrun buffer
// bit pattern, 1 byte per column. Top = lsb
char display[6], hdisp[6] ;
int w10kbuf[2], w1kbuf[20], w100buf[100]; // Assume all zeroed (:P)
int w10kidx, w1kidx, w100idx;
// int w10kmax, w5kmax, w1kmax, w500max, w100max;
long w, w10ksum=0, w1ksum=0, w100sum=0;
int www, w10k, w1k, w100, meter[5] ;
int scale=3; // log scale (start at 23)
int recal=0; //AGC rate
int inPin=1 ; // analogRead on A01
void setup() // run once, when the sketch starts
for (int ledPin=2; ledPin<=12; ledPin++) {
pinMode(ledPin, OUTPUT); // sets the digital pin as output
digitalWrite(ledPin,(ledPin<=7)) ; //Disable all cols
lmpWrite(msg,0,15); //Cycle delay is 1/10 secs
// (it's really to initialize the counters)
analogReference(INTERNAL) ; // Do not use DEFAULT or EXTERNAL!
int i= digitalRead(inPin); // remove old data
void loop() // run over and over again
w100 = (w100sum / 23) >> scale; // A cheap filter @ app 100Hz
w1k = abs((w1ksum / 3)-w100) >> scale; // 1kHz
w10k = (www+w10ksum) >> scale; // 10kHz
w= (w100 + w1k + w10k) ; // Total power (VU function)
if (w<13) {
recal++;
if (recal>=15) { //350mS counts before recalibration of meter
recal=0;
scale-= (scale>3);
} }// increase res only if less than 1/2 scale
// if ((w100>33) || (w1k>30) || (w10k>33)) { // log2
if ((w100+w1k+w10k)>83) { // Peaked: make it less sensitive
recal=0;
scale++;
w100= w100>>1;
w1k = w1k >>1;
w10k = w10k >>1;
meter[0]= min(w100>>1,31);
meter[1]= min(abs(w100+w1k-w10k)>>2,31);
meter[2]= min(w1k>>2,31);
meter[3]= min(abs(w1k+w10k-w100)>>2,31);
meter[4]= min((w10k*5)>>3,31);
for (int col=0;col<6;col++) {
int c=0;
for (int mm=0; mm<=4; mm++) {
c= c<<1;
c+= (meter[mm] > col);
hdisp[col]= c;
display[0]= hdisp[4];
display[1]= hdisp[2];
display[2]= hdisp[0];
display[3]= hdisp[0];
display[4]= hdisp[2];
display[5]= hdisp[4];
lmpWrite(display,0,1);
display[0]= hdisp[5];
display[1]= hdisp[3];
display[2]= hdisp[1];
display[3]= hdisp[1];
display[4]= hdisp[3];
display[5]= hdisp[5];
/* Vertical display routine
fillVBar(display,0,w100);
fillVBar(display,1,abs(w100+w1k-w10k));
fillVBar(display,2,w1k);
fillVBar(display,3,abs(w1k+w10k-w100));
fillVBar(display,4,w10k);
//fillVBar(display,5,w10k>>1);
//fillVBar (display,5,scale+1);
int i=0;
int s=scale-1;
for (int ii=0; ii<5; ii++) {
i= i | (s & 1);
i= i<<1;
s= s>>1;
display[5]= i;
void fillVBar(char disp[],int o, int val) {
int j= B100000; // digit pattern
val= constrain(val,2,127) ;
while (val>2) {
j|= (j>>1) ;
val= val>>1 ;
disp[o]=j;
void lmpWrite(char disp[],int stchar,int steps)
/* Usage: Loads bit pattern in disp[], starting at stchar,
- 1 byte per column, left-to-right, top-to-bottom
int col, row, cval, lit=0, ww=0;
long delayStart=millis() + 90*(constrain(steps,1,100)) ;
// Display / loop time
www= 0 ;
do {
for (col=0; col<6; col++) {
cval = disp[col+stchar];
for (row=1; row<=5; row++) { //only 5 lower bits
if (cval & 1) { // light this LED
if (lit==0)
digitalWrite(7-col,LOW); //col needs activating
digitalWrite(row+7,HIGH);
lit++ ; // in case we need to know how many LEDs are lit
// Cycle stealing here, to read VU input
ww=max(ww,analogRead(inPin)) ; //Raw volume data (rectified)
www=max(ww,www) ; //Peak retect
delayMicroseconds(80); //This makes sure the panel is
// lit the same period of time.
digitalWrite(row+7,LOW); //Turn LED off
cval = cval>>1 ; // check the next bit
digitalWrite(7-col,HIGH); // turn col OFF
w10ksum+= www-w10kbuf[w10kidx]; // This is our 'capacitor'
w10kbuf[w10kidx]=www;
w10kidx++;
w10kidx= ((w10kidx<1)); // 0 or 1
//if (w10kidx>3) w10kidx=0;
//w10ksum=ww ; // Increase the high-end response
w1ksum+= ww-w1kbuf[w1kidx];
w1kbuf[w1kidx]=ww;
w1kidx++;
if (w1kidx>19) w1kidx=0;
//w1kidx= ((w1kidx<19) && (w1kidx++)); // 0 - 19
w100sum+= ww-w100buf[w100idx];
w100buf[w100idx]=ww;
w100idx++;
if (w100idx>99) w100idx=0;
//w100idx= ((w100idx<1) && (w100idx++)); // 0 - 199
lit = 0;
while (delayStart > millis()) ;
Thanx Ben
I connected the White wire from a salvaged earphone plug to A01 and the black to Ground.
Sorry, but I'm on a really tight schedule at work and have not had time to get to it, but the code above has EVERYTHING you need, specifically the lmpwrite routine which does the actual scrolling message. Put your pattern in msg[] and it'll work - there is nothing else you need. The code does not depend on any external libraries or code (apart from the Arduino's built-in binary loader).
I will get to a more detailed Instrutable when I get the chance.
qs
Having said that, the software is written to have each vertical LED controlled by a single bit of a word, so we have room to go to 16 LEDs vertically. The number of horizontal LEDs is limited by the processing time of the uP so that we can both SEE the LEDs (the eyes need 1/10 of a sec to register each change) and to perceive motion and groups.
What is the application you have in mind?
is it possible to operate this without it being connect to the computer, or does the arduino receive the code from the computer during operation?
Use 6 registers @ 8 bits each, latched in parallel, so thats 48 bits in 8 shifts - common clock, latch - and parallel data = 6 + 1+1...easy data output. Just need to tweak the shiftout library to output a matrix instead of an array. There was a lot of buzz on the forum using more advanced techniques for the backend code for shiftout to not use digitalwrite, but rather some fancy assembly that saves a few clock cycles per shift.
The registers I'm using have an active (I forget) low or high latch for data input mode (output off) and data output mode (output on)...basically you can achieve good thruput with this parallel buffer in that you draw frame n+1 while you display frame n.
GHASP! I've spilled my secrets!
