Red Dot Sight
Published
Introduction: Red Dot Sight
You might need to edit your sight based on the dimensions of your laser pointer.
Step 1: The Base
The hole in the front and sides are necessary to be able to use the sight, so make sure you include them. Also make sure that the pointer is sideways, otherwise the trigger won't work. The piece of paper is optional, I only needed it to make it show more laser so that it will be brighter. You might not need this depending on your pointer.
Step 2: The Trigger
You don't need that specific piece, so long as it can go two bricks deep.
Step 3: Turning It On
To activate the sight, push the trigger on the side in. To turn it off, pull it out. This was my first instructable, so tell me how I did!
    • Stick It! Contest
      Stick It! Contest
    • Woodworking Contest
      Woodworking Contest
    5 Comments
    I made this same kind of Lego sight u might wanna check it out on my profile
    This looks very interesting, does the sight help you complete some task? Awesome job showing your process, welcome to instructables!
    I use the sight for airsoft, but someone could probably find another use for it, and thank you for the complement.
    With my gun it works fine, its just a little high.
