3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Laser Tunnel Glove!
Step 3Its Soldering Time!
Its Soldering Time!
alright, now that we have our case ready we can start the soldering!
Now dont be alarmed all you first timers, this was my first time soldering and it's quite easy, so lets get to work!
1. solder one of the wires to one of the sides of the battery case, if your wondering where i got that 1 battery case well i made it out of a 2 battery case the came from the tape recorder(I just cut the original battery case down the middle and superglued a piece of metal to the end..)
2. run the wire you didnt solder through the two holes you made in the bottom of the box and solder it to
the on-off switch.(see the second and third pictures)
3. take your extra wire, run it through the holes in the bottom and solder one end to the on-off switch and the other end the the battery case (see the second and third pictures)
4. superglue your battery case to the bottom of the cassette case (see the second and third pictures)
5. put the on-off switch in it's designated hole and superglue it in place.(see the second and third pictures)
pop in a battery to check that it's working,
if all is well then go on to step 4.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Chimera14
