The LeapCopter ! (Leap Motion to Control Quad Copter )
37,339
328
47
Posted
Introduction: The LeapCopter ! (Leap Motion to Control Quad Copter )
Hello everyone!
This is my first instructable hope you'll enjoy it.
What I did in this project was taking the Leap Motion platform and used it to control a quad copter with nothing but hand gestures!
Using digital to analog converters and the arduino uno we made the Syma X1 quad copter's remote control to recieve its commands from the leap motion sensor.
Parts you will need:
1. Leap Motion - 80$
2. Syma X1 - 40$
3. Arduino Uno - 30$
4. 3x D2A mcp4725 - 5$
5. BS170 Transistor - 2$
6. R10K Resistor - 1$
7. 2x R2.5K Resistor - 1$
Leap Motion you can get over here:
http://www.anrdoezrs.net/click-7389900-11514579
Tools you will need:
1. Soldering iron and some solder
2. Desoldering wick
3. Wires
4. Screwdriver
5. Magnifying glass
6. Dremel
You can see the result over here:
http://www.youtube.com/watch?v=RyIa_Ef23Bw
and here:
I would like to thank my friends Moshe and Tomer that helped me a lot in this project
Step 1: Step 1 Syma X1 Remote Control:
1. Disassemble the remote control and take off all the plastic parts leaving only the remote's board with the small LCD still attached. I left the same battery holder box and just extended the wires and cut all the excess plastic with a dremel.
2. With a soldering iron and a solder wick, carefully take out the two potentiometers, you can also desolder and take out the annoying buzzer.
3. Once you take out the left potentiometer there are 2 things you need to do -
First you have to add two 2.5K resistors as shown in the circuit picture.
Next thing you have to do is to short three points as shown in the picture.
4. On the left potentiometer, once you remove it you need to short four points as shown in the picture.
Step 2: Step 2 Digital to Analog Cards:
1. Connect the VCC output from each of the 3 A/Ds (analog-to-digital converter) together to the arduino's 3V3 input (The RED wires on the circuit picture)
2. Connect the SDA output from each of the 3 A/Ds together to the arduino's analog 4 input (The GREEN wires on the circuit picture)
3. Connect the CSL output from each of the 3 A/Ds together to the arduino's analog 5 input (The BLUE wires on the circuit picture)
4. Connect the ANALOG output from each of the 3 A/Ds and choose one for the throttle, one for the roll, and one for
        the pitch. (The light blue wires on the circuit picture)
5. Connect the GND output from each of the 3 A/Ds together to the arduino's GND input (The BLACK wires on the circuit picture)
6. Connect a wire to the lower left pin in each of the main chips in the 3 A/Ds and using a magnifying glass:
        in the throttle A/D connect the wire to the arduino's digital 8 (The brown wires on the circuit picture)
        in the roll A/D connect the wire to the arduino's digital 10 (The brown wires on the circuit picture)
        in the pitch A/D connect the wire to the arduino's digital 12 (The brown wires on the circuit picture)
Step 3: Step 3 Flip Button:
1. Connect the BS170's Source pin to the arduino's GND (The black wire on the circuit picture)
2. Connect the BS170's Drain pin to the push button's upper left pin (The yellow wire on the circuit picture)
3. Connect the BS170's Grille pin to the arduino's DIGITAL 5 (The orange wire on the circuit picture)
4. Connect the 10K resistor to short the GND wire and the grille wire.
Step 4: The Code (C# + Ardunio)
You can find all necessary code files in this link:
https://drive.google.com/folderview?id=0Bw0DWKT9vijdbm9aUG00Y0pRQWs&usp=sharing
(I used google drive to upload it).
If you don't care about the code and want to use it as is just download the file "LeapDino.exe"
Please make sure you've got all your Leap motion drivers properly installed and it will work!
For more deep understanding I used 123D to make the circuit in this link you can find the project
I made alone the schematic for the remote control and the MCP4725 D2A, 123D GUI is very simple and very helpful !
if you have any questions or problems you are more than welcome to leave me a comment so I can help
GOOD LUCK!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
  • Sew Warm Contest 2018
47 Comments
@the_ice_man the tutorial is amazing. I would like to interface the leap motion controller with the arduino using Java. Could you help please!
Hello.
I'm trying to connect a OEM Syma X1 controller (w/A7105) with an arduino w/NRF24L01+ but none of the libraries that I get, works. It's because A7105 can´t connect with NRF24L01? Can you help me?
Thanks.
RC
hi, i'm in final year, so i choose this project to be my final assignment, all i want to ask, did u or anybody here have any suggestion on using other than MCP4725 converter. please...,
Hi I am going to make this but with a custom built tricopter and with a turnigy 9x controller will this still work and could you show me how to set it up for my controller and for my tricopter.
Great tutorial! Are you soldering a wire to the bottom left pin of the DAC chips to allow the Arduino to control multiple DACs? I was just wondering since I wanted to make this project using an Adafruit mcp4725 breakout board which already has an ADDR pin out. Can I just use that instead?
Hi, I am getting an error when running the program. An unhandled exception of type 'System.TypeInitializationException' occurred in LeapCSharp.NET4.0.dll. Any hint in how to fix it?
Hi, I'll be doing this project in the coming days. Are you still around?
How did you change the address on the A0 pin on the DAC? We are trying to write those pins high to change the address, but the pin seems to be linked to ground, which keeps the pin low. Thanks!
Were you able to resolve this issue? I'm having the same problem, all of the DACs are enabled all the time because of hardwiring to ground on the breakout board. I'm not sure how to fix this other than cutting the ground line on the pcb itself
We didn't really find a better solution than cutting the ground line. It looks like this is an new model of that DAC and they changed that one part for some reason. Our group ended up simply creating our own low pass filters to change the arduino PWM to a constant voltage.
