The Legend of Zelda: Majora's Mask Replica by Riley Planalp
Featured
Step 8: Paint It Up!
I'll preface this step by saying that I haven't ever used acrylics before.  I figured that the more time I spent painting this thing, the better it would turn out.  The entire process took 3 days.  After I had pulled a good-looking cast, I needed to clean it up with some sanding and glazing putty.  I gave the entire mask two coats of gray primer before I started in with the acrylics.  I started by painting the magenta and purple areas on the mask, since they make up most of the surface.  I used some Frog Painter's Tape to rope off the areas where the black borders were so that I could get a sharp edge.  I used two layers of straight black paint to cover the black areas.  Next, I mixed up a pale yellow color and painted a base coat on each of the horns and the eyes.  If you notice in the pictures, I didn't paint the yellow all the way down the horns so that it would be easier to blend some color into the horns later.  I left all of the paint above to dry overnight before moving into the next steps.
I started day 2 by working out the eyes.  I've seen several other Majora's Masks with eyes that were either too red or too yellow so I spent extra time on these to make sure I got it right.  I used "Cadmium Red Light" to blend from a dark orange into the pale yellow that I had applied the day before.  After that had a few hours to dry, I freehanded the eyes with a small brush.  I actually used a black marker for the outside black ring around the eyes.
After this point, the rest of the mask was all freehand.  I VERY CAREFULLY painted the pink and light blue lines first.  Then, I used the same light blue paint to make the first of the four color "rings" on the symmetrical areas on the bottom part of the mask.
I spent a good three hours blending paint and drybrushing color onto the eight lower horns.  The top two horns were painted with a darker yellow, then a thin layer of brown and finally a layer of black to give them a weathered look.  I gave the bottom eight horns a drybrushing with yellow to blend them together completely.
The last thing I did was the two orange sections at the top near the horns, which was simply orange with straight black sections.  I gave the entire orange sections a black wash to help them match the dark hue of the mask.
And finally, I have the mask three layers of acrylic lacquer to make it nice and shiny, while making the entire thing scratch and water proof
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
