Introduction: The Legend of Zelda: Skyward Sword Goddess Chest
Picture of The Legend of Zelda: Skyward Sword Goddess Chest
Some background info:
I had found a Skyward Sword heart container necklace to give to a friend (http://www.thepixelsmithy.com/collections/necklaces), but I wanted to present it in the most elaborate way possible.
So, to make it true to the game, I made the Goddess Chest (oh and the Goddess cube is the gift box). The chest even plays the chest opening tune as you open it.
Step 1: Modelling the Chest - Part 1
Picture of Modelling the Chest - Part 1
My method of modelling things in 3D is as follows:
I first outline the object in Adobe Illustrator. I prefer Illustrator over the outline capabilities of 3D modelling tools.
I then export it as an AutoCAD drawing, which allows me to import the vector graphic into SolidWorks.
I then perform the necessary 3D manipulations in SolidWorks.
It is during outlining that I plan the 3D manipulations. One needs to be mindful of the types of vectors needed to perform certain manipulations. It is also during the outlining phase that I plan all the pieces I need. The chest top, bottom, legs, and in inner top lining to house the electronics are all separate pieces, and I need enough vector artwork to model them as separate pieces.
Shown, are the reference photos I've used. It is best if you can extract the actual 3D model from the game, but purely for the texture mapping images (the 3D model used in-game is crude). I am able to find the papercraft model for the chest, so I used that for my reference images.
Step 2: Modelling Chest - Part 2
Picture of Modelling Chest - Part 2
Here, I've already imported the vector artwork into SolidWorks.  You can see some of the vector graphics in the screenshots.
Most of the parts are easily recognizable. The last image is of the inner top lining of the chest. It leaves enough space in the top cavity for the electronics. There's also a notch for the reed switch (which I will talk about later). There are also holes in the lining to allow for sound to escape.
Step 3: Printing the Model
Picture of Printing the Model
I have a PP3DP. Which I've used to print the chest with.
The steps in which I designed, modelled, and printed the chest did not account for the brass hinge that I eventually used. So I did not add a notch for the hinge on the chest. I had to file down a space for the hinge.
Step 4: Electronics
Picture of Electronics
The easiest way to get the sound playing is to cannibalize those audio modules in gift cards. I found a company that produces the actual modules and to my luck, they even made one that supports uploading the audio file via USB. Here is where I got them: www.bigdawgspromo.com/slider-greeting-card-type.html. The switching mechanism is not needed as we're going to rewire the contacts to a reed switch.
ALL reed switches are NO (normally opened). When you bring it near a magnet, it closes. However, I wanted it to function NC. The magnet would be on the bottom portion of the chest. When the chest is closed, the magnet opens the reed switch. When the chest is opened, the switch will be in it's NC position, triggering the sound module to play.
Note that there are "NC" reed switches, but they're really NO's that's been modified to work as NC. You may try to find those switches, but we can also create our own. Shown in the images below is how we can contruct one. We need some rare earth magnets. By attaching one to the reed switch, we keep the leads constantly magnetized. If we expose the switch with another magnet with the some polarity, we cause one of the leads to become magnetized with the introduced magnet, causing the leads to oppose each other.
Shown below is the constructed audio module attached to the chest lining.
Step 5: Painting
Picture of Painting
So for the coloring, I really wanted to capture the iridescence of the chest. So I searched for some way to paint the iridescence. It turns out Tamiya sells iridescent paints. And to my luck, they have a purple-green combination, which is what it is in the game:  http://www.tamiyausa.com/product/item.php?product-id=86046.
The gold is from a gold oil pen (although, really any gold paint would probably work)
And here is where painting gets a bit tough. You have to paint the iridescent paint on top of a base color. I looked at samples of the paint color and the suggest black as the base paint makes the effective color too dark. I started experimenting with different paint combinations.
Here are my findings:
- The chemical compound of the Tamiya paint, which is intended for polycarbonate plastic, DOES NOT mix with krylon paints. The solvent in the Tamiya paint dissolves the Krylon paints. It doesn't turn it into a liquidy mess, but it does soften the paint. With enough time, the paint eventually dries. However, there is significant risk that the paint starts to wrinkle. If you have enough time, you can apply REALLY light coats and wait for days for the paint to dry before apply more coats.
- Use Vinyl dye instead for the base coat. It actually dyes the plastic so the Tamiya paint solvents won't eat into the base color. However, if you are planning to use dye, you have to sand the printed object really well as the dye is unforgiving and will accentual all of the printing errors.
The iridescent affect is hard to capture on camera. It's best when viewed at an angle and with natural warm light. But the image below shows the some purple glimmering.
Step 6: Construction
Picture of Construction
Glue everything together! I used superglue.
Just a note:
I also embedded magnets to the front corners of the chest to hold the chest closed. I did not add space for the magnets in the 3D model, so I had to hand file space.
I also didn't bother to embed the reed switch magnet in the bottom of the chest. It is just glued to the inner-front of the chest. It's not really noticeable.
Step 7: The Icing on the Cake
Picture of The Icing on the Cake
I'm not going to talk much about this step, but I did draw the goddess cube in Illustrator.
I had purchased a 7" cubed gift box from the Container Store. I transferred the cube design with sticker paper to the gift box. (Update: I've included the PDF of the cube design now)
I also bought a Skyward Sword master sword keychain as a ribbon topper (and some purple-y ribbon). The ribbon's like the master sword's energy beam thing, which is used to get the Goddess Cube to disappear and expose the chest. Get it? hurhurhur
I've released my STL files on my Thingiverse account. So go grab the model files here: http://www.thingiverse.com/thing:87465
NataliaB3 (author)2015-07-20
Hi
Can you show how exactly you do that?
Build the device that mounts the sound with the magnets? Or what you bought (model) and as modified?
Thank you
Athanatosti (author)2014-12-27
You said black paint was too dark, but what base colour did you use?
xeijix (author)Athanatosti2014-12-27
I used a grey primer
Athanatosti (author)2014-07-27
This amazing! Please tell me you are willing to sell one to me! :'D And if not would you be so kind to answer these two questions? What type of plastic did you use to print it? And where did you put the magnet and how small is it?
Athanatosti (author)Athanatosti2014-07-27
I meant the magnet for the reed switch or did you operate it in a different way and am I saying something stupid?...
xeijix (author)Athanatosti2014-07-27
hi, sorry I can't take commission work now. To answer your question, I used ABS, but you can probably print it with PLA as well. I placed the reed switch in the center of the top lip of the chest, so the magnet would have to be placed on the bottom lip at the center (or somewhere close to the reed switch). Unless you're talking about the magnet ON the reed switch, it's hard to describe, but I placed it at the end of the reed switch (check my drawing). As for the size of the magnet, it doesn't really matter except that it has to be small. I believe I used a 3mm cubic magnet
Athanatosti (author)xeijix2014-07-28
Well I guess I have to do it myself, will be a challenge for me ;)
And yes I am going blind because I only just now noticed the battery above the reed switch *facepalm*
jcole24 (author)2014-07-09
OH MY GOODNESS THIS IS AWESOME!!!!! I am obsessed with the legend of zelda series, and not this past year but the year before my parents bought me Skyward Sword for christmas.
RyGuy176 (author)2014-03-09
Thank you for sharing everything! Love it all! Sadly, the link you provided for the sound module doesn't seem to work anymore. Do you by chance have any other recomondations?
xeijix (author)RyGuy1762014-03-11
I checked the link out, it still works. Here's a link to their direct product page where you can purchase it:
http://store.bigdawgspromo.com/product_info.php?products_id=12976&osCsid=798f69990a3e7b294b03bb3958713de8
RyGuy176 (author)xeijix2014-03-12
Perfecto! Works fine for me now! Thanks mate
lastoryx (author)2014-03-02
Working on this next!!! Printing on Taz 3! We rendered it a little differently and we're using PLA!!! <3
Mark345 (author)2013-12-30
Could you share the design of the goddess cube? Its amazing¡¡¡
emilyvanleemput (author)2013-06-14
Finalist! Congrats!
camilat (author)2013-05-10
where did you get the little sword in the ribbon?
xeijix (author)camilat2013-05-10
The ribbons were from The Container Store and the sword's a Japanese gashapon like collectable. For my case, I got it from a seller on amazon: http://www.amazon.com/Legend-Zelda-Skyward-Master-Keychain/dp/B00AMTC30Y
Iceflow (author)xeijix2013-05-11
Maybe you could answer to all the people who ask for the 3D files for the chest... it wont hurt at all ;)
xeijix (author)Iceflow2013-05-11
Patience is virtue. I've shared my files on Thingiverse. I've included the link in the last step
Iceflow (author)xeijix2013-05-12
Thanks for sharing :D
magdielr21 (author)2013-05-05
Where did you do the 3D printing? thanks. awesome project by the way!
xeijix (author)magdielr212013-05-11
I have a pp3d printer so I printed it myself.
D: i love it! it's the most spectacular thing i have seen!
gvoyer-perrault (author)2013-05-06
Is there a way that I could access the finished STLs? Or possibly some way I could get one or two of these printed (say via Shapeways?)
Iceflow (author)2013-05-05
Can you share the STLs to print the chest? Amazing work!!
neonix (author)2013-05-05
Mega awesome!
coppeis (author)2013-05-05
could you post a link to the file for the chest?
wanamoka (author)2013-05-05
This is way cool!
beefsupreme (author)2013-05-05
Never thought I'd say this, but it would be really beautiful to somehow turn this into a music box. That song with the harp sounds like it'd come out nicely.
fluffydragon (author)2013-05-05
This is amazing, and beautiful!
Bluemetal (author)2013-05-05
Great project! Will you make the 3D stl files available to others?
ab032 (author)2013-05-04
I would love this as a gift to a special some one, but I don't have any of this to make it :( Amazing work!
BrittLiv (author)2013-04-29
Wow this is awesome! The end result is so clean and neat!
BrittLiv (author)BrittLiv2013-04-30
Btw. why is this not in the "Game.Life 3" contest?
xeijix (author)BrittLiv2013-04-30
A moderator fairy placed me in the contest today. Thank you mysterious moderator!
Ironsloth1993 (author)BrittLiv2013-04-30
My thoughts exactly.
A complete flub on my part. I didn't notice that contest when I published this instructable. And now it's too late to enter! Nooo
flameheadrod (author)2013-04-29
this is technology?
xeijix (author)flameheadrod2013-04-29
Lol I did put it under 3d printing, but one of the editors featured it so I have no control over where it's featured
About This Instructable
51,626views
523favorites
License:
Bio: I'm an electrical engineer specializing in software. My hobbies consist of software, hardware, and design. I dabble with industrial design.
More by xeijix:Game of Thrones: Joffrey Baratheon's CrownThe Legend of Zelda: Skyward Sword Goddess Chest3D modelling cases, chassis, etc
Add instructable to:
