3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Lego C3.1 Shotgun-Crossbow
This is the FIRST lego shotgun that actually fires a self contained shell which releases multiple pieces when fired. It is largely based off my C3 design, because the shells require a large amount of force to seperate, which I can only replicate with my C3's multiple rubber bands. The shells have a range of approximately 25 feet (to be effective), and have a 1 metre horizontal spread, and 2 metre (max) vertical spread. Each shell is one large piece and 5 smaller pieces attached to it, which seperate when fired. It is VERY powerful. Changes to the C3 Crossbow are:
-improved, more realistic stock (the actual shoulder rest on the back of the stock can bend for added comfort)
-a shotgun sight (approximately showing where fragments will go)
-a shotgun firing runway (gradually widens to allow shell to seperate more horizontally)
NOTE THAT IF YOU HAVE NOT ALREADY BUILT THE C3 CROSSBOW, YOU NEED TO GO TO MY OTHER INSTRUCTABLE TO BUILD IT: http://www.instructables.com/id/The_C3_Crossbow/ THIS INSTRUCTABLE REQUIRES YOU TO HAVE ALREADY BUILT THE C3, BECAUSE THESE ARE THE IMPROVEMENTS.
Please visit my website for other lego guns like this: http://sites.google.com/site/bblegobrickworks/
Step 1Runway Changes
Runway Changes
  • last photo ←
Basically, jbefore starting this step, take off all the flats and thin pieces on top, so that the run way is only a TOTAL of 1 and 1/3 bricks thick in the MIDDLE of the runway. Then, start with pic 1.
3 comments
Jul 24, 2010. 10:51 PMsacram98 says:
man u should make this auto matic or semi
Mar 11, 2011. 10:18 AMtim1 says:
i agree
Mar 2, 2010. 12:06 PMvoemaster says:
what is its firing range?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
52
Author:Bitterberry9
