3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Lego C4 Semi-Automatic Crossbow
The C4 Semi-Automatic Crossbow is the first semi-automatic crossbow which is as powerful as a regular lego crossbow. The crossbow can fire 35 feet or more, and has a 4 round capacity. I came up with the idea for a semi-automatic lego crossbow when I was trying to create a gun which could fire the Y1 Shotgun Shell powerful enough to separate it, which would be a crossbow, but also had a higher rate of fire (semi-automatic). The prototype which fired the Y1 eventually failed, but 5 months later, I readapted it to fire my standard crossbow round( (2x4)F ), which worked out very well. The gun works very well, and has a good rate of fire, and a good sight (similar to the M16 sight). It is powerful enough to go through paper, and ricochet very far. How the crossbow is semi-automatic but still looks like a crossbow is that the cover that goes over the magazine is wider than it would be on a normal semi-auto, which allows the rubberbands to still go on the trigger at an angle. This allows maximum power. The way the firing rubberbands work is that once one shot is fired, its corresponding rubberband flies to the front of the gun, and below the firing runway, where it stays. This prevents the used rubberbands from blocking the next shot.
TO BUILD THE IMPROVED VERSION, THE C4.1 ------> [http://www.instructables.com/id/The-C41-Lego-Semi-Automatic-Crossbow/ ]
MY WEBSITE: http://sites.google.com/site/bblegobrickworks/Home
For the C4.1 Semi-Automatic Crossbow (coming in a few weeks), these changes will be made: The top of the magazine holder will be altered to be more sturdy (The C4's hasn't broken yet, but its just a precaution), the firing capacity will be increased to 5 rounds, a stock will be added, and a bipod will be added.
Step 1Main Forward Body
Main Forward Body
  • last photo ←
This step will build the base of the front half of the crossbow.
8 comments
Nov 3, 2009. 7:02 PMgeodez says:
when in dbout C4.
Oct 17, 2011. 4:39 PMking kolton9 says:
Say it with me everybody: Jamie want big boom.
Nov 14, 2010. 5:18 PMsoggymushrooms says:
i can't 4 rbs. can you do a step on hw to load 4?
Sep 4, 2009. 8:47 PMmuttyfutty says:
nice! I wonder how much space it takes on the Instructables server with all theese Images!!
Aug 23, 2009. 3:35 PMJesus. says:
i...................................need...........................................tiny................................gears........................!!!!!!!!!!!!!!!!!!
Aug 16, 2009. 1:53 PMknexsuperbuilderfreak says:
i gotta bulid this 5*
Aug 17, 2009. 7:52 AMknexsuperbuilderfreak says:
ok
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
52
Author:Bitterberry9
