The Lighted Fume Extractor
Introduction: The Lighted Fume Extractor
You may of seen this before in a mint tin. This is a version with a built in light. So don't think that I will tell you to do the same thing. This version is different. I hope you can build this better than I did, This I did in like 30 min. Try harder that I did.....
---Please note:
You will run out of power quicker with normal.
The leds need more power.
I now suggest getting a external power supply hooked up instead of the batteries, do what you want though it's your'e own project.
And also I now removed the leds from mine, because of this.
And if you use a external supply you can use 2 fans instead of 1, just make another hole.
so yeah..
Step 1: Make the Circut!
Just follow the schematic below. Please note you can substitute 19v instead of 2 a 7805 instead of a 7812 and a 5v fan instead of a 12v fan. You can either place the leds after the switch or voltage regulator. with the - going to the battery.
Step 2: Cram the Stuff in Your Tin
add a hole in your tin or box so the switch fits and also so the leds fit don't forget the airway for the fan and filter. So then just fit all the components in the tin and close it up. so thats like it pretty much. send me a comment about anything. See ya1
Step 3: Test It Out!
Turn it on and test it out NOTE the metal part of the voltage regulator is the ground so make sure it doesn't touch the tin.
MAKE: I'm a Maker!
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    i can see the corner of a pink ds :D
    Wait, are you trying to drop 6 to 4 volts with a regulator?
    what is the filter material
    Why do you place 6 LEDs instead of just 1? Does this give you a rough voltage estimate?
    No, the point of this is to be a worklight+fume extractor idea. But the voltage estimate is a good idea.... Oh yeah sorry about the bad schematic, I'll try to make a new one.
    Okay everyone, lets get this straight. Yes a guy did this on make, this is an addition. I found that the LEDs will remove some power, and drain the batteries quicker, and also I am only a teenager, what do expect?
    I got some AC filter at home depot, and that was my sisters, she left that on the table. Sorry for the delay! Chrisapalo (Chris-app-uh-low)
    What kind of filter and where do you place it?
    no offence but this is hiddios an inecicient
    Pretty cool, I might try this. Thanks for making the instructable!
