3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The MacroGyver - or home brew macro filter
Always wanted to take super close up photo's of bugs and small stuff? This is an quick, easy and cheap way to get some nice results for very little effort and money, and still keep all the camera settings like aperature.
You will need:
one slr lens to dismantle, mine was one that had a broken focusing mechanism, but you can get the same part needed from nearly any lens, get cheap one from a second hand sale/flea market for peanuts
blu-tac, to fix the macrogyver onto the front of your normal lens.
set of mini screwdrivers to dismantle the lens.
Step 1Step 1
step 1
With your bits assembled, the first step is to dismantle the surplus lens. most of the time the screws are hidden under the rubber focusing ring, use a screwdriver to slip it off. there may or may not be other screws on the mount part of the lens depending on what lens you have.
17 comments
Jul 7, 2010. 6:11 PMgarakawa says:
I made this from the back element of a broken Nikkor 18-105. First picture is the first attempt, using lots of blu-tac on a cheap uv filter :P Second is the final one, I fixed the back element on the filter using a piece of styrofoam, then hot-glued black EVA around it. The pictures look crisp, even on my kit lenses. The DoF is really narrow so lighting is a bit tricky.
Dec 18, 2009. 6:45 PMzengestarlette says:
is that a cropped image?
Apr 22, 2009. 4:12 AMinst_keith_short says:
I bought an extra lens cap at my photo shop (used, $3), drilled a 3/4 inch hole in the middle then glued the "buddy" lens to that. Makes for easy attachment and removal. I am using a 50mm macro lens and with the buddy I get in very close. Light is a problem so I am looking into an LED macro light ring. I hope to improve on the one in Instructables as I plan to pivot the LEDs to adjust for distance I like your bug photos. I also am a NecroMakroGrapher. Insects flee in terror when I search my garden.
Sep 15, 2009. 5:01 PMDalthran says:
http://www.instructables.com/id/Camera_Light_Ring/
Have a look at that, am in the process of making one myself for macro work.
Jul 27, 2009. 12:37 AMzomie says:
Howdy, I love the build. I am curious if you have DOF issues? Have you tried to just reverse the kit lens with an adapter ring? I am curious how they compare in terms of magnification.
I really enjoyed your instructable and wrote about it at:
http://macroreverse.com/2009/07/27/diy-hacked-kit-stacked-lens-filter/
Apr 21, 2009. 10:47 PMFumaKilla says:
I suppose the object are very still or get sedated... or perhaps not even a living one since taking several picture on different focusing area is really hard!.... I cannot tell the object to stay still can i? any way the result are stagering. the final wasp result is my fav.
Jun 2, 2009. 4:56 AMFumaKilla says:
Thank you. that exactly what i did using a DIY flash diffuser (made of hard fabric) and here is the result :). (now less insect are harmed during my macro photo session)
Jun 5, 2009. 3:56 AMFumaKilla says:
btw I took my name from my hobby of "necromakrography" Fuma : small insect Killa : well you should have known :D I might pay my price on the judgement day :(
Apr 21, 2009. 10:54 PMFumaKilla says:
I've tried my own home brew Macro lenses out of dead old analog camera lens. the problem is thin depth of field..... so mostly i like to shot a non living object or object that was a living one. I personally called this a " Stack Focusing NecroMakroGraphy"... LOL.. I don't even know if that word is exist.... Love your job.
Feb 8, 2009. 5:15 AMjeff-o says:
Well, the results sure are impressive! Nice work.
Feb 7, 2009. 12:34 PMKiteman says:
That rig is ugly, but the results are outstanding!
Well done, that ibler!
Feb 7, 2009. 9:03 PMalvincredible says:
tootally agree. wow that macro is INSANE!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:nurglets
blarg i'm dead
