More info at this project at http://diymagicmirror.com
Who's the fairest of them all. Make your own Magic Mirror and find out. The Magic Mirror can read the weather, tell you how your stocks did, can be wired to your doorbell with an IP camera video feed, turns lights & appliances on and off using X-10 control, and even has a Breathalyzer that tells you when you've had too much to drink. The Magic Mirror plays pre-recorded animations based on input from various sensors. Featuring four characters, each character responds to the sensor inputs with its own personality. Characters include a skull for your next Halloween party, a pirate, a princess character, and a really mean pumpkin who disses you New York cabbie style.
Magic Mirror Features:
- Breathalyzer with optional Tweeting
- Photobooth Mode (Link to Separate Instructable on Photobooth Mode)
- Speak your Tweets from Twitter
- Weather Forecast
- Stock Performance
- Sends X-10 CommandsDoorbell input with IP camera feed
- Picasa based slideshow
- Princess, Pirate, Halloween, Insult Characters
- Text to Speech Mode
- Personalize it with your own Videos
- Runs as a native application on the PC, Mac, and Linux
El Cheapo PC or Laptop (a 3-4 Year Model will work)
Arduino Micro-Controller - $30
Used 15" LCD monitor - $50
Dielectric Glass TV Mirror 4mm (2-Way Mirror) 12x12 Sample (Optional) - $20
Magic Mirror Kit with Software
Picture Frame with Oval Matte (Optional)
Sensors (Pick and choose the sensors based on your installation)
Maxbotix Promixity Sensor
Seeedstudio or Phidgets Touch Sensors (3) - $7 each
Alcohol Sensor (1) - $7
Reed Switches (2) - $5 each
See here for all supported sensors
X-10 Components and LEDs (Optional)
X-10 Firecracker - $5 on eBay
X-10 Transceiver Module - $20
X-10 Dimmer Switches (2) - $12 each
LEDs - $5
Remove these ads by
Signing UpStep 1Arduino and Adobe Flash
On the Arduino, you have to load a program called Firmata which let's you control the Arduino from Adobe Flash (specifically Action Script 3.0). There are multiple versions of Firmata out there so be sure to use the one that comes with the Magic Mirror software download. You also have to run a serial server (included in the software download) which acts as a middleman converting serial data received from the Arduino to a TCP/IP port that Flash can access.
Also - Is that you... Keanu Reeves?
:D
if you look above the window you shall see. (pumkin head)
There's the original Mirror, then there's the Mirror, Mirror. I think you have the new one cause it was released in '08 and that's when this was written
I am in shock. :O
is GREAT just WOW!!
