The Magic Suitcase is an offshoot of the Magic Mirror project diymagicmirror.com
The suitcase is sitting on top of a laptop which runs the software. The laptop is connected to an Arduino which is connected to some sensors. Here's the logical architecture of the project diymagicmirror.com/files/magic-mirror-logical.jpg
This installation was for a Hotel where the Magic Suitcase among other things, speaks the Weather Forecast to the Guests.
Step 1: The Case
The case was found at a local electronic surplus shop. It's a hard case that used to house a 1950s Smith Corona typewriter.
A jigsaw was used for the oval cutout. A standard LCD mounting bracket was used to mount a 15" LCD monitor to the back of the case.
Step 2: Schematic and Magic Mirror Arduino Shield
Here's the schematic for the project diymagicmirror.com/files/schematic.pdf
You just need an Arduino and can wire the schematic using a breadboard.
If you require a more permanent installation than a breadboard, the Magic Mirror Arduino Shield can be used. The switches and sensors are wired to two standard cat5e cables (T568B wiring) that plug into the Shield. Referencing the manual diymagicmirror.com/files/building_the_sensor_hub.pdf for the Shield, it will tell you what color wire goes to what sensor.
There is a kit available from Seeedstudio which includes the Magic Mirror Shield, necessary components, Seeeduino (Arduino clone), and the Magic Mirror software www.seeedstudio.com/depot/diy-magic-mirror-p-606.html
Step 3: Mounting the Sensors and Switches
Sensors and Switches Used:
Yellow switch = Weather forecast
Green switch = Stock performance
Red switch = X10 on/off commands
Reed switch (magnetic) = Picasa slide show
Proximity Sensor (Maxbotix EV-1) - Plays videos when subject is within certain distances
LED - flashes when within proximity sensor ragne
Black switch - doorbell mode
Potentiometer - dynamically changes between 4 characters/modes (princess, pirate, Halloween, and insult)
Step 4: Installing & Configuring the Software
The Magic Mirror software can be downloaded from diymagicmirror.com/install.html .
After installed, you set the Sensor Hub port which will be the Arduino COM port on Windows (COM3 = 5333, COM4 =5334...) or if on Mac or Linux, will always be 5333.
You then turn on which sensors you have wired up and configure other options diymagicmirror.com/images/configuration.jpg
A complete set of instructions on how to setup and configure the software is found in the manual diymagicmirror.com/files/wiring_and_software_operations.pdf
Step 6: Finishing Touches
There was a large gap between the monitor and the end of the case which ruined the illusion as you could see the casing of the monitor when viewing from an angle. A cardboard tube was added to fix this.
Hose tubing from an automotive shop was added around the oval cutout for a smoother/framed look.
Lastly, since its for a Hotel installation, added some mounting brackets on the front and back so it won't tip over when used by the Guests.
lpxav says: Dec 15, 2010. 6:47 AM
Nice and It is based on magic mirror interactive room already saw before.
You are really creative nice job!! I am a fan!!!
Datawolf says: Feb 4, 2010. 4:08 AM
Fun. But the switches break the magic.
Doctor What says: Jan 27, 2010. 9:43 AM
Magic suitcase on my desk, give me the answer to this test.
your dog in reply to Doctor WhatFeb 3, 2010. 5:18 PM
hahaha!
Spottedfeather says: Jan 31, 2010. 11:28 AM
Where do you get the Magic mirror program ?
alinke (author) in reply to SpottedfeatherJan 31, 2010. 8:45 PM
Hi, its a program I wrote
Stephen D. Alverez says: Jan 27, 2010. 3:28 PM
 That is very, very odd...
red-king in reply to Stephen D. AlverezJan 27, 2010. 8:36 PM
 I think it's pretty cool.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
