Arduino source code now posted on last page.
Wiring diagram NOW ON LAST PAGE...
and video clip of monster in action to follow ASAP...
Remove these ads by
Signing UpStep 1The basics, chicken wire, phone bills, PVA glue and lots of mess!
The stuff in question is the plastic coated 2mm wire mesh with 2" by 4" rectangular holes. First this was formed into a cylinder and then by forming the top three level of holes into an inwards ruffle the shoulders were formed. I trimmed the excess to form a waist line and used the off cut to form a smaller version which I then twisted together on top of the large one to form his head.
Now the messy part starts. with a very sharp knife and a straight edge I sliced up four years worth of household utility bills into 2" and 4" strips (so that they would neatly go through the holes in the wire) and starting from the bottom of the shell, layered them up like roofing shingles after dipping each one in a PVA glue and water mix (about 10 water to 1 of glue). The inside of the shell was strengthened with some 4mm steel rod that I fashioned into two semicircles, fitted in front and back and then tack welded the ends together to form a strong ring. Two uprights of c-channel aluminium were added and holes drilled in them to accommodate welding wire being twisted trough to hold it all together. You can just about see the internal harness that is attached to the strong points inside along with the waist band to stop it toppling forward. The arms at this stage are just old tent poles bent to shape and wire tied and welded into place.
6
comments
Add Comment
l8nite
says:
roofletch (author)
says:
roofletch (author)
says:
Kiteman
says:
Add Comment
