loading
Step 2: Materials and tools
All I actually bought for this project were the magnets - small, countersunk neodymium magnets from ebay.
The rest was made of material I already had stocked in my shed - scrap timber, bamboo skewers and a pair of dead ball-point pens.
Similarly, no specialist tools were required - a junior hacksaw with blades for wood and metal, a hot-glue gun, drill and my multi-tool.
Health and Safety
You'll be using hot things, sharp things and very whizzy things. Be careful.
Take particular care with neodymium magnets - they can nip painfully, and will shatter if allowed to fly together.
Can you put in a different YouTube video? This one is no longer available. <br> <br>Great Instructable though :)
The video should be fine - it's working as of this message's time-stamp, and there was no reason for it to be down.
I mean the first embedded video on step1, according to YouTube, the user closed their account.
Woa, I didn't notice that, thanks.
Hard to see it is
Fixed.
<p>Anechoic rubber-clad foam forms a decent &quot;skin&quot; for this type of underwater propulsion. With a long enough transit between each of what you termed &quot;ribs&quot; you need only limited flexibility in line with the ribs, rather than a fully elastic membrane as a whole. You can also drive this with electromagnets above/below the permanent magnet at the end of each rib to eliminate moving parts in the body of the vessel and allow more asymmetric variations in movement between each side and in different operational modes. I tried a similar design and then used Nitinol SMA wire on either side to draw each spar upwards and downwards in sequence, reducing the external EM signature of the ROV.</p>
One thing though,If the magnets are too strong, they could interfere with the motors. <br>AMAZING design though.
I love this idea! I think, however, that only the front rib needs to be driven, and the others can be free-moving. Perhaps the rear rib (and the front) can be engaged or released, allowing reversal of thrust. Also, the magnetic force will decrease as the ribs reach e tops and bottoms of their paths. Perhaps a straight sided vessel with sliding magnets would reduce this problem (a similar mechanism on the outside would reduce it further). <br> <br>I might try building something like this. A vertical fin in the rear (and perhaps front) could be driven the same way and make steering easy.
Cool - post an Instructable if you do.
Did you think about the resistance of water? Magnet system could be unefficent under water. But if you use 2 crank shafts -one for both sides- you can easily control your ROV's movements ,for example turning, just by reversing one of the motors or making it move faster than the other one. Great instructable though!
Water is non-magnetic, and so does not affect the efficiency of the system in that way. <br> <br>If you look at step 8, at the bottom-right part of my sketches, you'll see I already thought of the two-crankshaft idea. <br> <br>Thanks, by the way.
I was talking about the resistance force of the water. I mean, you are testing the system in air and there is much less resistance in air than it is in water. Are your magnets powerful enough to beat that force?
Oh... <br> <br>As far as I know, it should be OK as long as things go steadily - too quick, and the magnets could get jolted out of synch.
This is such a good idea, if I understand it correctly you'd have 3 different part propelling the submersible forward and because of the design they'd be each helping to move the other parts within. And because it's using magnets and not gears in would be easier to stop one side physically to turn and such if it where being used as a manned submersible.
I love this project, although to simplify the drive mechanism I think having the crankshaft outside the hull would be easier to build.
Putting it outside would need something to pierce the hull, which defeats the object.<br>
what if you put a circular plate with magnets attached on the end of the exterior cam shaft .. then instead of having to run a camshaft inside the rov taking up lots of space you could have a much smaller motor with a matching magnetic wheel inside the rov to propel the exterior camshaft <br> <br>if that doesnt make sense to you .. let me know .. i will try to rephrase it
Biomimicry, awesome. This design is closer to a cuttlefish propulsion. i read about a fish that has similar fins on top and bottom and can move in any direction without changing orientation. I.E. vertically while remaining horizontal. I think that movement was achieved by ripples originating at the extremes of the fins moving towards the center causing a vortex above the fish that sucked it upwards. Don't quote me on that but it was something like that. I wish I could remember what kind of fish it was, it would be really useful info for you I imagine.
Boxfish?<br><br>Sunfish?
I thought of doing this same thing several years ago! Way to go!! I didn't think about using magnets. I figured using a long cam in the middle would reduce weight and give the same effect. I would dream of using it for submersibles, as well as air craft. Carbon filaments epoxied to thinfilm. I also thought it would work the other way around, and place the membrane inside a tube and jet the water/air through it. I never got to try it, but it is nice to see someone else working on it!
Thanks.
was thinking of using this kind of propulsion for a rc air ship someone has technically already done this but mine will be steampunkish here is link; http://www.youtube.com/watch?v=UxPzodKQays
Wish I had seen this instructable a long time ago.&nbsp; A couple years ago I made a&nbsp;proof-of-concept for a magnetically coupled fish tail with no mechanical coupling between the tail and the drive mechanism.&nbsp; The fish tail shown is on a metal swivel, but the next thing would be to eliminate the swivel and use something flexible, probably just the same material as the tail.&nbsp; The idea was to make a propulsion system that would be very quiet, i.e., stealthy.&nbsp; I used a servo motor rigged to spin constantly with neomagnets mounted on top, and with neomagnets also mounted on the tail.&nbsp; Next I wanted to try electromagnetic coils so that there would be no noise from a motor.&nbsp;<br /> <br /> <a href="http://www.youtube.com/watch?v=NohFbnIj7GE" rel="nofollow">http://www.youtube.com/watch?v=NohFbnIj7GE</a>&nbsp; <br /> <br />
That's nice - does it actually move?<br />
Yeah, it actually moves.&nbsp; Works just like a fish.&nbsp;&nbsp;Of course it&nbsp;needs a lot of refinement.
I just had a thought about this. What if the wings weren't made watertight and adjusted to changes in pressure naturally, but then a center hull had a master ballast system like a normal ROV that could push the craft close enough to the surface to be&nbsp;retrieved? The cavities of the wing should be able to equalize to the pressure outside the craft quickly enough to adapt and not be crushed, right?<br /> <br /> Also, I remember hearing about Speedo making a new nearly frictionless bodysuit that sparked some&nbsp;controversy&nbsp;for helping as many people break records as it did. It's just a thought, I'm in no position to spend $257+ on a pair of shorts to destroy for an ROV concept. If it isn't usable, what about normal wetsuit material?<br /> <br /> I like this idea and I'll&nbsp;definitely&nbsp;try to push it further as soon as I have time and materials.&nbsp;<br />
wow, very impressive... i will definitely be taking this concept further.<br /> <br /> <br /> How do you think turning will be handled?- you can't turn with both wings doing the same thing.<br /> <br /> <br /> I'll keep you posted<br />
I thought of running each wing separately - look at the bottom-right of the sketch in step 8.<br /> <br /> I was just proving an idea, though - others (you) will be able to take it much further.<br /> <br /> (Don't forget to post an Instructable.)<br />
What about using some form of latex as the shell of this vehicle?
wow talk about the next davinci
So, you basically want to build a Festo Ray:<br/><br/><a rel="nofollow" href="http://www.festo.com/inetdomino/coorp_sites/en/c79c5d07d5805095c12572b9006f04f5.htm">http://www.festo.com/inetdomino/coorp_sites/en/c79c5d07d5805095c12572b9006f04f5.htm</a><br/>
I hope this is not too late: It would be interesting to see how well this will work. The idea of a "swimming" ROV or MPV is quite interesting. Magnetohydrodynamics has been disappointing. Propellers have hit their development limit. Have you considered making your "joints" linear induction motors?
This could be simplified even more by just using one rib, and having the rest of the wing trail it and pivot on it freely within the range allowed by a "pizza with slice missing" shaped blocker.
can you use gear system like in the ornithopter to produce the up and down motion for the propulsion. I been working on my own idea in the same general direction I stuck with the up and down motion with the idea that I have . I like the design and good ideal. WELL DONE
you could do this without the possible drawbacks(and possible fin loss) of the magnet concept by just sheathing the entire ROV in vinyl or latex or something...so build mechanically attached ribs that could be independantly controlled or cam controlled or whatever controlled then just cover the whole thing with a flexible skin...it would probably be easier to accomplish turning without having to muck with the magnet parts...
The trouble with flexible skins is that pressure deforms them, and the deeper the ROV goes the greater the pressure, and the greater the amount of deformation on the skin. This would eventually split the skin or jam it in the moving parts.
What if you had everything inside working in liquid (maybe that 'dry water' used in offices to extinguish flames without water damage) as well? Fish don't deform because they have (uncompressable) liquid inside - maybe that's the key?
mineral oil
If you fill it with something besides air, you're going to run into buoyancy issues. Plus, part of the reason for producing this concept was to keep cost and complexity down for amateurs.
i heard you can use ammonium chloride to solve your buoyancy problem. Apparently this allows some squid to submerge several thousands of feet deep.
Fish don't have buoyancy issues... and before you might bring up swim bladders, etc; using a liquid of similar density should cause no problem - it would make it easier to dive/maintain depth below the surface than using air which would make it want to rise to the surface all the time (unless it is counteracted with more weight = inefficient). This method of propulsion is not for use on the surface.<br/>I don't see this being any more of a problem for amateurs than any of the other issues that are being struggled with so far. There are always 'issues' no matter which way you go.<br/><br/>For reference, your response was a bit abrupt - I was merely making a suggestion. <br/>
Read it all together - your post and mine - it's just a reply, nothing abrupt intended.
No probs then.
also kite...i don't want my comments construed as saying your idea is crap....it's a fun method of locomotion..just trying to think of ways to avoid the drawbacks... such as: what happens if something hits one of the ribs and knocks it off of the body of the "vessel"? how would the force of the water change the way the ribs are moving? etc..
That's something for future work.<br/><br/>I wasn't planning on holding the ribs in place with magnets, the point is that magnets allow mechanisms to &quot;penetrate&quot; the hull without presenting a leakage issue. Maybe strap them to the outside of the ROV?<br/><br/>I <em>think</em> that, underwater, it would be possible to produce a more efficient, rhythmic motion if there was some resistance to the ribs - it was hard to produce a nice <em>wave</em> for the video because there was nothing pushing back against the ribs.<br/>
you could probably quite easily have a propeller driven by the magnets. eg:<br/>(looking along where the shaft would usually be)<br/> O<br/> |<br/>O----+----O<br/> |<br/> O<br/><br/>O = magnets<br/><br/>have two of the above thingys, one inside and one outside the hull, with the external + connected to an axle mounted in brackets with bearings and the external axle is connected to the propeller, and the internal + is connected to the motor.<br/><br/>follow that?<br/>
sorry, my magnetic coupling ascii didn't work. it was meant to look like a cross, not a T on its side
I got what you meant, and people do use that. I was after something more biomimetic.
love it, just need to make the ribs spin slowly and you have a remote controlled marshmallow toaster. Not making fun, the U.S. Navy is working on a robotic tuna, And they guarantee it is mercury free. would make a dar n crunchy sandwich though. Oh, in reply to "drofenvy" yes you could use emagnets but the amount of Amps required to get the 14000 Gauss you get with a mid range neodymium would create so much E.M. hum that any sensitive equipment nearby would have to be heavily shielded. Kiteman, I think you should go ahead and build it. Use a arduino to control six servos with the magnets on the ends of the horns two more servos for the "fang" looking things on the ray and tail and a body made of silicon rubber with a dry suit seal for the guts. House all the stuff in some PVC and take the thing to your navy, tell them you never liked tuna.
About This Instructable
41,757views
134favorites
License:
Bio: The answer is "lasers", now, what was the question? If you need help, feel free to contact me. Project previews on Tumblr & Twitter: @KitemanX
More by Kiteman:Valentine's Heart FidgetCube Halloween Projects
Add instructable to:
