The Masterdude Knex Micro Uzi
1,964
6
42
Published
Introduction: The Masterdude Knex Micro Uzi
About: I make K'nex guns, specializing in semi-automatic, RBG-Slingshot hybrid systems which i use in most of my guns. Note: I am not responsible in any way for any damage, injury, or death caused by my Instructab...
This is the gun that was in my slide show:
My slide show
It is strong on one rubber band and can be made stronger by adding more. It also is small and doesn't use many pieces.
Pros:
-Doesn't use many pieces
-Rather strong
-Small
-True trigger
-Mag
Cons:
-Sometimes inaccurate
-Sometimes shoots two bullets at a time
More Instructables by me.
Step 1: Build These
Follow the pictures.
Very easy to make.
Step 2: Put It Together
Step 3: Shooting
Picture #1: Placing or rubber bands.
Picture #2: Ammo.
Warning- If misused may cause harm or injury. Do not point at people. I am not responsible for harm or injury caused by this instructable.
    • Pets Challenge
      Pets Challenge
    • Planter Challenge
      Planter Challenge
    • Make it Move Contest
    42 Comments
    amazing gun and works great with no jams! I would suggest that you clarify where to put the elastic on the orange connector cause it took me almost an hour to figure out where it went :P Im working on a sniper and after reading this 'ible I've decided to use this type of firing mechanism. I'll put credit on mine to you though :)
    Here's the piece count:
    Rods Connecters
    Green:17 White:4
    White/Dark Grey:16 Green:2
    Red:1 Yellow:9
    Grey:1 Orange:6
    Grey:7
    Light Grey:1
    Red/Dark Grey:2
    sorry
    Rods
    Green:17
    White/Dark Grey:16
    Red:1
    Grey:1
    Connecters
    White:4
    Green:2
    Yellow:9
    Orange:6
    Grey:7
    Light Grey:1
    Red/Dark Grey:2
    If it is good (correct) then I don't see why you couldn't. Go ahead if you want to.
    May I ask whether there is a reason why you posted that image or are you just spamming and advertising you creations here?
    that gun is cool and small im trying to buld it with mini knex thx for the instructable
    When you pull the ram rod back the ammo pusher will push a gray connector into the place where the ram rod was. Then the ram rod will push the ammo up to the trigger where it will stay until you pull the trigger which will make the bullet and ammo be able to accelerate forward and will result in it shooting.
    hey, could you please try to make a gun that fires rods for me please. with a magazine, make sure it's small. i you do, i'll surely build it
    you can fit little green rods in the mag.
    This can probably fire white connectors as well.
    this is the first knex gun with a mag that actually works and uses little peices!!! AWESOME!!!!!!!!!!
    put green pices in the holes in the top
    any useful upgrades?
    more detailed of how to connect rubber band to the trigger
