The MaterBater Pollinator
 by biochemtronics
Featured
Step 9: Put It Together
The steps as simple enough for a child to do.
1 - Fasten one end of the stiff wire to the back of the battery holder using Sugru.
2 - Fashion a cup shaped tip from Sugru as shown to the other end of the wire. The inside is sort of cone shaped like the stamen.
3 - Fasten the motor securely to the stiff wire by wrapping it with un-insulated wire and soldering the wire. I did it this way because the
     solder would not stick to my motor casing. Your's might solder fine.
4 - Solder the battery clip wires to the motor terminals. It doesn't matter which wire goes to which terminal.
5 - Fasten the wires going from the battery to the motor to the stiff wire using Sugru just to keep them out of the way.
6 - Install the batteries
7 - Snap only one terminal of the battery clip onto the battery holder (either one). Nothing will attach to the other terminal right now.
Now you and I both know there are a lot of different ways a person could go about building one of these things. You could use a lot of different materials too. Epoxy glue could replace the Sugru. A coat hanger could replace the stiff wire. You could even add a switch or bigger battery and motor if you want to. Just use what you got and build it to suit yourself.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
