Step 4Getting ready...
The reason we have the outlet boxes is for the secure mounting of the outlets. If you decide to use panel mounts like I did you'll probably want to hot glue them from behind. This is just to make sure they don't pull out when you go to unplug things from them. It's just some added insurance.You'll see that I used a bridge buss to connect everything in this one. I got that out of an old CB home station that was discarded. I'm not using this for heating or anything heavy duty so this is substantial enough for my needs. You may want to use a screw terminal or just solder wires directly to the PCB. I did it this way to save wear and tare on the board if I should want to reconfigure it later.
Add Comment
