The Mighty Mosquito Coil Holder.
Introduction: The Mighty Mosquito Coil Holder.
This great boon to all humanity grew out of the frustration with using the conventional mosquito coil "stake" holders.
Firstly - they are a prick to use.
Many coils do not have the mounting slot pressed properly into them - meaning you have to force the coils onto the stakes - usually bending the "mounting spike" on the holder.
The design of the stake holders, makes it hard to pick up the coil and stake, and either place them somewhere or move them from room to room.
If you stick the coil and stake on a plate to catch all the ash, they have a real tendenncy to tip over when you do move them.
That said, I got sick of the "bottom dollar" bullshit design, and came up with a permanent solution to the holding, use and transportation of mosquito coils.
Step 1: The Dreaded Slit for Poking With the Pedestal
Many of the coils do not come with the slot properly pressed into the cake, and the stake mounting system is pretty awful anyway.
Step 2: The Beastly Mounting.
The stake is too light, too flimsy and the base is too small making the mounted coil unstable, when moved, or trying too.
Step 3: The Solution of the Century - the Bulldog or Folding Clip
Works like a charm.
Easy to clip onto the coil.
It has handles, so you can pick up and move the coil.
It's reasonably steady, and a bit heavier than the steel foil stand, that came with the coils.
And it lasts a life time.
Step 4: The Benefits and Limitations of This Device and Mosquito Coils.
I don't think mosquito coils are really good for ones lungs, and I only use them in a well ventilated area.
The instructions in Indonesian, are to light the coil, and leave it in a room, long enough to clean away the mosquitos and to then put the coil out.
I was for a time, under the delusion that your supposed to light it and live in the smoke that infiltrated the house.....
Kind of like an insecticidal incense stick.
But no. They are a "clear the mosquitos out and then move in" sort of an arrangement.
The Benefits - where I live the mosquitos mobility and activity are very dependent upon humidity, temperature and sunlight.
So if we are going to have them, they usually become active around 2 hours before sundown and for the first few hours of the night.
What this coil holder does, is that by figuring out the burn time per distance of coil, one can "time the buring of the coil and it's self extinguishing" as the lit bit burns up to the metal clip - which draws the heat out of the glowing coal, and puts it out.
This is a good thing in some locations for some people.
If I wanted to have the coil burn for an hour or so, I'd leave about an hours material on one side of the clip and then it would burn to the clip and go out.
Of if I wanted to have the coil burn for long periods, I could occassionally move the coil around in the clip to keep it burning for as long as I wanted.
One can also simply use the clip to extinguish the lit coil by clipping the ember, and putting it out.
The ONLY down side, is that if your living in a building that has lots of gaps where the mosquitos can get in i.e. no fly screens or netting, there are lots of mosquitos and they are the types that carry nasty diseases - and you really want the coil to burn all night, then unless your prepared to sleep light or take turns adjusting the coil in the holder, every few hours, it's probably best to use the traditional cheap stake type coil holder that came with the coils....
But then again, the folding clip type coil holder, gives the advantages of portability, stability and control of the burning time - where as the basicc stake stands are designed to let the coil burn in it's entireity.
Anyway this arrangement suits me as I can light the coil, for an hour or two before sundown, and use the intake fan to blow the very diluted insecticidal smoke through the building, which also stops the mosquitos from coming inside every time I need to go in or out of the doors etc...
And when I go in for the night, I can easily extinguish the coil, rather than waste it.
So this arangment might really suit you too.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Epilog Challenge 9
      Epilog Challenge 9
    Not a bad idea, it does the job, it’ll burn the mozzie coil right up to where the bulldog clip is clamping the coil. If you want to burn the whole mosquito coil it just won’t work a bit like using a peg, doesn’t stand up on its base because of the roundness at the end of the bull dog clip and by not holding the center you need to be watching the mozzie coil burn. A peg just falls over because it’s pivot point has been designed for a different use.
    I though you might be interested in this……………….
    Once you’ve used a crochead mosquito coil holder, you’ll never go back to any silly little tin thing, our neat little mozzie coil holder holds broken bits effortlessly, stands, hangs or lays on it’s side. Each crochead coil holder is handmade from stainless steel in Tropical Far North Queensland by a locally owned and operated small family business.
    Our customers tell us they now break their mozzie coils on purpose because you’re never really outside for 5 to 8 hrs. Also they do make good business card holders too.
    Check out our youtube video here -
    And our website too -
    burning mosquitoe coils control denghy west nile infections.pngcroc head mozzie control prevention mosquito bites.jpgtiger mossie buzz bites smoke gnat.pngNykko's business card holder.JPG6onside.JPG
    Thanks, it's my wonderful father's invention and it's a hit up here in the Far North.
    We have customers tell us they break their mozzie coils on purpose now they have one of our neat little crochead coil holders.
    They make great business card holders too.
    I'd be happy to send you one, just email an address to post it to.
