Introduction: The Mood Wine
Hello, I'm a student at Howest Kortrijk education Industrial productdesign.
In this turtorial, I will show you how do make a mood lamp from a wine crate in a simple way.
Step 1: What Do You Need?
A wine crate
A flexible transparant tube
Led strips (12V) inclusive trasformer 230V/12V and controler
Red and black wire
Strip tang
A soldering iron
Solder
A lat
Marker
Step 2: Draw the Folding and Cutting Lines
Draw a rectangle 160 * 21 starting at the side (all 8 sides)
the full lines are folding lines
the stripped lines are cutting lines
Fold the 2 flaps over and make e square
(hint: make a smal incision inside the box to make the folding easier)
Step 3: Transparant Tube
Cut the tube in 4 pièces of 24 cm
(hint: you can use a normal stanley knife)
Step 4: Solder Led Strips
1 Cut the strips on a lengt of -+24 cm (You can see where you should cut the line with a scissors)
2 Cut out the silicone CAREFULLY
3 Tin your path.
4 Unwrap the electrical treat
5 tin your elektrical treat
6. Solder the electrical treat on the paths
(Hint: Solder the ledstrips in parallel (they keep working also when one led is down)
Make sure that your led Strip definitely works, is'n that so check your solder contacts.
Step 5: Assembly
Slide the transparant tube inside the square
Past the ledstrips into the tube
Connect the led strip to the transformer
Close the top of the box with glue or transparant tape
