The Color-Changing Martini
 by makendo
Contest WinnerFeatured
This drink smokes elegantly, changes from a calm blue to fuschia as it cools from room temperature to drinkably cold, and tastes like a dirty martini.
1-40 of 68Next »
ccrazed says: Oct 30, 2012. 10:05 AM
Not a great idea to use dry ice. A girl in the UK had a drink with dry ice and nearly died, she was lucky but had her stomach removed.
Green Silver in reply to ccrazedOct 31, 2012. 5:19 AM
That was liquid nitrogen according to the news, she took the down in one challenge. I guess if the dry ice were to be placed under a gauze which was fixed to the glass it would be a whole lot more reassuring.
makendo (author) in reply to ccrazedOct 30, 2012. 11:11 AM
Yes, I would recommend those of a nervous disposition to stay well away from this drink, or to just make the drink change colour by adding a clear acidic drink (there are lots - Sprite works). I think it's fair to say in general that if you don't know anything about an ingredient, you should treat it with extreme caution (I think a guy recently died from eating live cockroaches in a competition). If you make a drink with boiling water and consume it before it cools, you will scald yourself extremely badly. So if we give someone a very hot drink, we warn them of that fact. Same principle applies here. Ingesting dry ice is dangerous, so wait for the cocktail to stop smoking before drinking it.
ralexander4 says: Oct 24, 2012. 4:32 PM
Hi, one of my students chose your instructable for their advertising workshop, they did the nameing, packaging and ad campaign, hope you like it.
http://tallerpublicidadulsa.blogspot.mx/2012/10/wild-brew.html
makendo (author) in reply to ralexander4Oct 25, 2012. 8:48 AM
Good stuff - hard to make a drink made from cabbage juice appear sexy, but I think they managed it!
tinker234 says: Mar 19, 2012. 8:49 PM
nice idea i wonder if i could make a virgn verison
kcabral28 says: Dec 28, 2009. 8:41 PM
Just a thought, If you dissolved baking soda into water and then froze it into small ice cubes, would you be able to create alkaline ice and scrape off the sodium?  Isnt there a way to desalinate water by freezing it? Even if you can't remove the sodium from the ice maybe a slow release of base from the ice cubes as they melt would allow the color change to last longer or even swing back to blue after the dry ice completely sublimates? I'm definately trying this out soon.  Great idea!
makendo (author) in reply to kcabral28Dec 29, 2009. 12:06 AM
Thanks. Lots of ideas here! Freezing a salty solution generates ice + an even saltier solution, until eventually you'll start crystallizing out the salt (in this case, sodium bicarbonate) and you'll have a mixture of salt crystals and ice when the whole thing solidifies. I'd encourage you to experiment, for sure, but work it out with water first - don't waste all the booze!
belsey in reply to makendoNov 26, 2011. 7:25 PM
How about using potassium bicarbonate instead of baking soda? They do make it food grade and is used in specialty baking instead of sodium bicarbonate -- it should have a similar effect without the salt...
makendo (author) in reply to belseyNov 27, 2011. 1:59 PM
I'm sure it would work, but I'm much less sure that the effect of the potassium on taste would be beneficial. "Lite" salt substitutes about half of the Na in NaCl with K, but tastes pretty vile (it has a sort of bitter aftertaste, though YMMV).
ilpug says: Oct 17, 2011. 8:25 PM
I really really need to do this.
cmanuel1 says: Mar 31, 2011. 6:25 PM
COLOUR CHANGING BANANA SMOOTHIES!
jaegerschlager says: Dec 9, 2010. 10:37 PM
Have you tried blueberry instead of red cabbage? Should be essentially the same indicator, more pleasant taste from what else gets extracted.
makendo (author) in reply to jaegerschlagerDec 9, 2010. 11:01 PM
No, I haven't. Good idea though, as blueberries also contain anthocyanins. I was mostly looking for something that went with the salt. Any suggestions for a slightly salty, blueberry-flavoured cocktail welcome!
DotatDabbled says: Oct 5, 2010. 6:30 PM
Just dropping in to say "Awesome, Dude!" I've featured this on Dabbled.org today..
Dot
makendo (author) in reply to DotatDabbledOct 5, 2010. 7:21 PM
Hey, thanks Dot... funny, I never thought of it as creepy or Halloween-worthy... but dammit, you're right.
jgroenert says: Dec 27, 2009. 8:20 AM
I don't heat the cabbage. I make cabbage indicator for children's science classes by blending cabbage to a pulp with water. Strain and freeze xtra for later use.
Lovely drink . Would pickled cabbage brine work?Would add flavor . I am going to have to ask the local martini miester.
makendo (author) in reply to jgroenertDec 27, 2009. 11:33 AM
Thanks. Yes, you can see in the photo of the chopped-up cabbage that the colour is leaching out before the cabbage is heated.
Haven't tried pickled cabbage brine - but I think it's salty enough already!
Nyxius in reply to makendoFeb 13, 2010. 6:56 PM
 instead of using sodium bicarbonate to balance the solution why not use dilute 3% hydrogen peroxide?  it's not dangerous if consumed in the small quantities you would use in the drink.  Plus there is no salt as a by product... just plain old H2O.
If you try this method instead of baking soda, then I would strongly recommend mixing in the proper amount of peroxide into you indicator well before serving since the reaction is probably going to be pretty slow.
Nyxius in reply to NyxiusFeb 13, 2010. 7:18 PM
 Oh and just to give you the chemistry...
NaHCO3 & {H+ & (Ac)-}  --> Na?(Ac) & H2CO3 -->  Na?(Ac) & H2O & CO2
H2O2 & {H+ & (Ac)-} -->  2(-OH) & {H+ & (Ac)-}  -->  2(H2O) & (Ac)-
(Ac)-   + CO2 -->  (Ac)-  & H2CO3  -->  {H+ & (Ac)-} & CO2
Worst case scenario is that you denature your indicator & it stops functioning...
makendo (author) in reply to NyxiusFeb 14, 2010. 1:42 PM
Thanks for the suggestion... but H2O2 is a weak acid, not a base, so I don't see how it can replace the NaHCO3. It's also a strong oxidising agent, so as you say, there is a good chance it will bleach the indicator (which is another type of color change, of course!). I'm puzzled by the chemistry you've provided - is "Ac" the acetate ion (usually written OAc)? If so, the top reaction looks like baking soda + vinegar, but I can't figure out the next 2 at all.
Nyxius in reply to makendoFeb 14, 2010. 2:25 PM
Sorry...(Ac) is my personal notation for a generic anion (in this case...your indicator?).  Hydroxide is a weak acid like you said, but it is also unstable and usually decays into two hydroxide ions as a mid-step to creating stable H2O and O2.  The hydroxide ions function as your base to neutralize the acid by stealing the hydrogen to make H2O.  I was not sure about what other chemicals are in your indicator solution so the third line is just a guess of what happens after you add the dry ice (anions don't like staying anions from my experience).
Nyxius in reply to NyxiusFeb 14, 2010. 2:52 PM
This is a very slow reaction... can be sped up using ultra violet radiation.  Also dissolved oxygen will make the drink taste sweeter.
makendo (author) in reply to NyxiusFeb 14, 2010. 4:45 PM
No, you're confusing anions with radicals... and oxygen is tasteless (just as well, or we'd be constantly overwhelmed with the flavor... in fact, I'm beginning to wonder if you're pulling my leg).
In case you're serious, my advice: DON'T make a drink with pharmacy peroxide. You really don't want to be consuming it (and unless you're sure the reaction has gone to completion, you will be). From the MSDS for 3% H2O2:
Ingestion: Large oral doses may cause irritation and blistering to the mouth, throat, and abdomen. May also cause abdominal pain, vomiting, and diarrhea.
pandaboy292 says: Jan 22, 2010. 7:24 PM
thats sweet. now only if i were old enough to drink.
makendo (author) in reply to pandaboy292Jan 22, 2010. 8:18 PM
Thanks - but no problem, you get the same effect for non-alcoholic drinks - and also see http://www.instructables.com/id/The-Color-Changing-Sports-Drink-Mocktail/
pandaboy292 in reply to makendoJan 23, 2010. 8:27 PM
awesome. ill have to try that. but where do u get citric acid?
makendo (author) in reply to pandaboy292Jan 23, 2010. 10:03 PM
Try a health food store or specialty grocery store.
pandaboy292 in reply to makendoJan 24, 2010. 9:12 AM
alright. thanks.
revelae in reply to pandaboy292Jan 25, 2010. 1:40 PM
lime juice(and i would assume other citrus juices) works, thats what i used.
nanosec12 in reply to revelaeJan 31, 2010. 10:24 AM
Can also use ground up vitamin C pills ( ascorbic acid ) to get the same effect.
Jodex says: Jan 19, 2010. 12:25 PM
The victory came to the right address :-) Althought I didn't vote for anybody :-P =/
makendo (author) in reply to JodexJan 19, 2010. 4:59 PM
Well, that's a vote of confidence anyway! Thanks.
lobo_pal says: Dec 29, 2009. 4:01 PM
You should know that you can get poisoning from dry ice easily.
makendo (author) in reply to lobo_palDec 29, 2009. 5:36 PM
All the scenarios for poisoning that I can imagine are pretty bizarre. There are commercial devices designed, I assume, to stop drinkers accidentally or intentionally ingesting the dry ice in smoky cocktails - see www.mistystix.com/ - is that what you mean?
I would recommend those of a nervous disposition to stay well away from this drink, or to just make the drink change colour by adding a clear acidic drink (there are lots - Sprite would work). If you're really worried about safety, read the MSDS, which will completely put you off!
lobo_pal in reply to makendoJan 5, 2010. 10:53 PM
Well, i heard about it from my friend, we're both freshmen chemical engineering students, so we thought it was really funny when we heard. She was at the party, but I was not.
RebelWithoutASauce in reply to makendoJan 5, 2010. 12:39 AM
Lobo_pal, the only danger of dry ice is how cold it is. The dry ice Osmcann is talking about is the solid form of Carbon Dioxide, which we actually create in our bodies and breathe in and out constantly. So, I would not worry about being poisoned by this substance, you are much more likely to give yourself frostbite.
lobo_pal in reply to RebelWithoutASauceJan 5, 2010. 10:48 PM
I know that, I was referring to the fact that it is entering the stomach, and not the lungs. I am not sure why, but I have seen people get sick from it.
WNCmountaingirl says: Jan 4, 2010. 8:04 PM
Dry ice is actually quite safe to use in drinks - but you shouldn't touch it - wait for it be gone before actually drinking...as it can burn skin...
as_Dead says: Dec 30, 2009. 3:51 PM
(removed by author or community request)
1-40 of 68Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
