The Most Awesome Speaker
Published
Introduction: The Most Awesome Speaker
Today, we are going to show you how to build an inexpensive, yet reasonably strong speaker for under $20. We were inspired by a youtube video that we watched. We decided to change the design of the speaker but we used their style inards
Step 1: Gather Materials for Speaker
This step Is relitively easy, yet an important one none the less, gather materials.
Magnets, paper plate, wooden painted stick, plastic bucket, Aux cord, copper wire, hot glue/ hot glue gun, sauder
Step 2: Coil the Wire
once you have all materials you will need to make the coil. Take the magnets and wrap a piece of paper 1 or 2 times around the magnets, just enough so that when the magnets are placed inside the coil they aren't restricted. Tape the piece of paper closed. Warm a hot glue gun.
Step 3: Seal the Wire
Next wrap your wire around the piece of paper about a half inch long, tightly woven. After that slide the magnets out, and baste the coil with hot glue (just remember to not lose the ends of the wire) and slide the paper out.
Step 4: Set the Magnets and Coil
Glue the coil to the middle of the large paper plate than rest on top of magnets
Step 5: Attach Magnets
2 extra magnets can be attached to the bottom underneath the stick if need be. After the magnets are attached and the stick trimmed we need to find the sort of goldilocks zone of where to put the magnet in relation to the coil.
Step 6: Secure Inards
Once the goldilocks zone is found hot glue the wooden stirrer to the bucket.
Step 7: Solder the Coils to the Aux Cord
Solder the sealed coiled wire to the Aux cord. Solder the left and right
Step 8: Cut Hole in Bottom of the Bucket for Easy Aux Cord Access
Use a razor blade to cut a small hole just barely big enough to fit the Aux cord out. To fully secure the Aux cord and seal the speaker hot glue the arounf the wires.
Step 9: Rock Out and Enjoy the Music
if the speacker isn't loud enough than add more magets or an amp.
    • Casting Contest
      Casting Contest
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
    Very interesting design for a speaker--who knew you could make a speaker from a bucket?!
    Thanks for sharing this!
