3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Most Useful Machine
What do you make for a man that has most everything; a tiny waving flag, sprouts to keep him healthy and an automatic pill dispenser just in case the sprouts fail? It wasn't immediately clear. So, I looked at his profile to see what he likes. From what I could tell he liked useless machines, gear clocks and stuff. I thought for a long time about what he might want made for him based on what I already knew.
I was ruminating over one project in particular that he had built called the IRritator when it suddenly struck me, I bet he might have something that requires a remote control, like a TV (at least, I am hoping that he has a TV). Anyhow, assuming that he has a TV, I bet he has pressed the channel-up button thousands, if not tens-of-thousands, of times. That's a lot of effort being exerted to change the channel. But what if that effort was not necessary? What if there was a way to change the channel without ever exerting the effort it took to press the button? What if there was a machine that pressed the button for you once per minute? Well then, perhaps, just maybe, that would be The Most Useful Machine... EVER!
And thus, I have made janw The Most Useful Machine... EVER! for the Instructables Gift Exchange. If it turns out that he doesn't have a TV and this machine isn't as useful as I hoped it would be, then perhaps he can combine it with his IRritator and make the most annoying clock ever made. Towards this end, I have also mailed him the minute hand, so that should he need to, he can use it to trigger the IRritator for one minute every hour.
Step 1Go get stuff
Go get stuff
You will need:
(x1) over-sized universal remote control
(x1) servo motor with the controller board removed **
(x1) curved doorstop
(x1) 14" x 14" x 1/4" acrylic sheet
(x1) clock movement (with second hand)
(x1) small magnet
(x1) reed switch
(x1) extension spring
(x1) double-threaded standoff and corresponding screws
(x1) 2 x AA battery holder
(x3) AA batteries
(x8) 1/2" bolts with nuts
(x1) a few short zip ties
(x2) self-adhesive Velcro strips (the length of the remote)
** Learn how to remove a servo controller on this page.
65 comments
1-40 of 65next »
Jun 26, 2011. 2:51 PMhafsteinn says:
Very nice! besides the awesome gadget the instructable it self is very nicely set up, very professional and the photos are awesome! nice work!
Aug 5, 2010. 7:46 AMrounderone says:
Howdy - Thanks for sharing this instructable! I was wondering... would it be possible for the machine to detect when the TV plays the ads louder than the regular show and then turn down the ads to normal volume then turn the volume back up when the ads are over and the show comes back on? Just an idea. Thanks again for sharing.
Jan 20, 2011. 4:03 PMpcgirl says:
TV stations **swear** that they the adverts don't have louder volume.. and most of the time they are right. The reason it sometimes sounds louder, is that it's more noise. Music, fast talking, flashing lights.
Otherwise, I think this one is fantastic! Something that I build for my father or husband - if I could actually do this sort of thing. :D
Aug 18, 2010. 6:20 PMIronManMC says:
That device was invented back in the 1920's. It's called a compressor/limiter. The simplest (and cheapest) compressor would be a cadmium sulfide photoresistor (Radio Shack has 'em) and either a small incandescent light (those little tiny "grain of wheat" types emit plenty of light) or a flat front LED, sealed in a light-proof container, such as a piece of heat shrink tubing with both ends plugged and sealed. The LED could be run from the TV's speaker (you'll probably need an L pad or pot that'll sink the amp's output power), and the photoresistor would probably work best connected from ground to the VC's wiper.
As the volume increases, the amp power rises, the light gets brighter, and the photoresistor's resistance lowers, shunting the audio coming into the pot to ground.
BTW even though this is cheap and easy, it's one of the better sounding compressors, especially if you go with the incandescent lamp. The lamp smooths the sound, which results in much smoother operation.
-Mike
Aug 5, 2010. 3:50 PMiEdd says:
Yes. ------------------------------------------------------------------------------------------------------------ This instructable just uses a bunch of mechanical components to make it completely ineffecient. However, the novelty factor of that makes it pretty funny and interesting. ----------------------------------------------------------------------------------------------------------- For what you are doing, you want to use a microcontroller and "read in" the volume up and down button codes. Your arduino (or similar) has IR transmitters and a microphone. You would need to sample the volume and then turn it down or up. ----------------------------------------------------------------------------------------------------------- I hate how the instructables comments can't have paragraphs unless I fill the line with dashes.
Aug 18, 2010. 6:28 PMIronManMC says:
-Mike
Aug 6, 2010. 2:19 PMRobertwan says:
But in fact, there /still/ aren't paragraphs, since the comment as it is shows is a different width than the comment input box.
Aug 6, 2010. 4:38 PMiEdd says:
Yeah. Sigh.
Unless this rich editor actually supports hard returns, like it seems to in the preview.
Aug 7, 2010. 5:37 AMRobertwan says:
Ah-ha!
Well, now you know.  Rich editor FTW!
Jan 7, 2011. 5:24 PMknexinventer says:
cool
Sep 12, 2010. 12:03 PMJakeg says:
Hi, thanks so much for the great Instructable... I do, however, have one problem. When I try to upload the .eps file to Ponoko it says that there is no lines in the template. I assume that this is a problem on your end so can you double check the file and send me the updated one? O yeah and where did you get the clock movement? also, how long is the extension spring. Thanks so much...
-Jake
Sep 13, 2010. 2:07 PMJakeg says:
Thanks for your Reply!
Sep 9, 2010. 6:55 AMZion_Sphere says:
stop making me become lazy lol
Sep 1, 2010. 6:34 PMnikk985 says:
really good job
Aug 2, 2010. 12:28 AMzack247 says:
haha... awesome.you could totally annoy someone by making it press the volume up button once per minute. hide it, and watch them freak out. or even better, make it press the power button every minute...
Aug 2, 2010. 12:44 AMBongmaster says:
i had a tv once that randomly decided that it was gonna shoot the volume up to full XD dunno wat caused it. no mobiles around it at the time since they wernt as widespread as they are now, and no remote hidden anywhere.
Aug 2, 2010. 7:23 AMtoelle says:
Cellphones doesn't usually interfere with TVs. TVs use IR signals. It could be caused by sunlight, candles, or anything else that emits IR radiation. A random IR pattern could be recognized by the TV as a signal to turn up the volume.
Aug 2, 2010. 3:00 PMBongmaster says:
yea i know cells dont interfere with tvs, only the sound wenit goes bipbipbadip, and i know they ure ir im not a derp ;). was jsut saying there was nothning around, not even sunlight or any light that can intefere on a ir spectrum.. it was just a skitzoid tv specially since it also decided to detune to static randomly too and make me get up to press the channel again XD
Aug 2, 2010. 3:12 PMTechNerd1012 says:
It was a ghost! lol
Aug 8, 2010. 6:53 PMPSPerson says:
ITS A TRAP!
Aug 8, 2010. 1:03 PMtanmanknex says:
The ghost wanted him to work out by making him get up
Aug 2, 2010. 8:08 PMBongmaster says:
XD
Aug 7, 2010. 2:24 PM9ale7 says:
(i'm writing this because i like the tutorial) the tut is great, but i had no idea about how would the motor start working ??? you should've explained more about how the "MAGNETIC REED SWITCH" will work, i had to read about the stuff you need to realize what is going on. maybe you should add more description in "step 9", and draw an arrow over the " magnet", then the last video will explain everything. finally ....to be honest, i will for sure use this same ""circuit"" in other projects :) LOVE IT 8)
Aug 5, 2010. 8:49 AMAnson16 says:
Needs more cowbell
Aug 5, 2010. 9:04 AMDraakUSA says:
Definitely more cowbell. :-)
Aug 6, 2010. 6:54 AMMad inventor says:
Cowbell, huh? http://www.youtube.com/watch?v=xJglaqH5Tno
Aug 6, 2010. 4:42 AMlogotipo says:
Good idea , but , it dont go to increase the obease people in the word ?
Aug 5, 2010. 7:23 PMldb477 says:
I noticed the zombie vs ninjas silouette thing in the background haha.
Aug 5, 2010. 3:34 PMhjartland says:
Many great ideas and techniques going in to building such a ... Useful? machine. I like it!
Aug 5, 2010. 2:29 PMcdousley says:
ITS PERFECT! SO SIMPLE BUT SO GREAT!
Aug 5, 2010. 7:14 AMsxdemon says:
Thats a very big remote you have here lol
Aug 5, 2010. 6:55 AMubiquitoussmokey says:
one word: AWESOME! :)
Aug 3, 2010. 8:32 AMjanw says:
This was just the gift for me! So good thinking Randofo! I was always facinated by those cartoon-machines where a hand comes out to push a button. So this makes me smile when I see it at work. I also love the analog clock as trigger. It makes me think of those oldschool timebombs. I also want to thank you, Randofo, for caring about my health. Thanks to your machinem my thumb won't be overworked and so I won't need my pillmachine for that ;)
Aug 3, 2010. 11:14 AMboris_1981 says:
this is really useless... LOVE IT!! awesomely well done, the pictures are extremely clear,well documented and the idea itself is ingenious and clever! :D
Aug 2, 2010. 10:48 AMfrenzy says:
Needs More Toothbrushes and Vibrating Motors
1-40 of 65next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2361
Author:randofo(Randy Sarafan loves you!)
I am the Technology Editor here at Instructables. I am also the author of the books 'Simple Bots,' and '62 Projects to Make with a Dead Computer'. Subscribing to me = fun and excitement!
