Step 3Bend the acrylic
Put on heat resistant work gloves and get your heat gun.
When you are sure that it is clamped just right, apply heat using a heat gun over the length of the acrylic where you would like to make the bend. Travel back and forth over this area slowly. If you let the heat gun stay still in one spot, bubbles may start to form in the acrylic.
When the acrylic starts to soften (it will visibly droop a tiny bit), gently apply even pressure in the direction that you want to bend it and hold it in place at 90 degrees until it starts to harden and cool. When doing this, be careful to bend it the right way or you will end up with a backwards bracket.
Add Comment
