The Most Useless Machine EVER!
Step 4Parts
Parts
The Ultimate Useless Machine V2 :  pre-soldered machines and Kits are available here: http://frivolousengineering.com/?page_id=1568
Or you can order parts from Digi-key:
Battery Holder 4-AA Cells BH24AAW-ND (Note: 3 AA's or even 2 AA's should work, your mileage may vary)
DPDT Toggle Switch 450-1533-ND
SPDT Micro-Switch EG4544-ND (Just about any with 3 pins and a lever should work.)
Parallax Continuous Rotation Servo 900-00008-ND (No need to modify the gears on this servo, you just have to do the wiring to the motor)
NOTES:
The servo I'm using is a JR Sport ST47. It's a standard size servo with a torque of 55.0 oz-in.
Stay away from any of the micro-sized servo’s. A standard size servo with at least 4-5Kg/Cm torque will work in most cases. Keep in mind that the toggle switch and arm length are some of the things that will determine how strong a servo you’ll need. Most of the standard servos should do the job.
mrrigsby reports that a toggle switch from Radio Shack, catalog # 275-636 works.
He also pointed out that it's better to use "4 fresh alkaline batteries--with 4 rechargeables, I couldn't depend on having enough power to always throw the switch."
64 comments
1-40 of 64next »
May 22, 2011. 6:46 AMicelandinthesun says:
This is the most amazing thing i have ever seen. Thank you so much!
May 10, 2011. 11:09 AMMeuryn says:
It isn't the parallax servo, can't find them anywhere in the UK (apart from DigiKeyUK which charges £12 delivery!), but this looks like a continuous rotation servo, will this work?
http://www.oomlout.co.uk/index.php?main_page=product_info&products_id=235
May 10, 2011. 12:53 PMMeuryn says:
Ok, thanks!
Feb 22, 2011. 12:33 AMJasonJAYWatson says:
Would an illuminated toggle switch work? Like this one...?
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=360-1939-ND
Nov 29, 2010. 10:57 AMmara0192 says:
would this work for the toggle switch?
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=360-1015-ND
Jun 15, 2010. 4:01 AM6black6knight6 says:
hello , im working on this item ive buy your listed toggle switch , and says on- off -on so i have a momentary toggle switch in this project is useless right ?
Jun 16, 2010. 4:05 PMPierce 93 says:
I was going to ask the same thing, the switch listed online is on-off-on, not on-on. I don't think there would be a difference with continuity, but I personally believe it would be annoying to click the switch twice to turn it on.
Jun 16, 2010. 11:24 PM6black6knight6 says:
sorry i still dont understand what kind of toggle switch use , on-on , on-off - on-off-mom ? im very confused
Jun 17, 2010. 2:01 AMjanzak says:
I don't think an on-off-mom switch would do you much good in this project but I'd love one for when I don't feel like doing my laundry or making breakfast
Jun 17, 2010. 2:05 AM6black6knight6 says:
so what kind of switch i must use on this ? i still dont understand
Jun 17, 2010. 9:41 AMPierce 93 says:
Try to find a 5 amp on-on switch. You only want the thing to click into two positions. Using the on-off-on would be annoying because of that extra click in the middle. Now I say "try" because I've had difficulty finding one, but it doesn't have to be 5 amps. Anything rated higher will work, and SaskView has said that 3 amps would work, although I personally wouldn't recommend it. Janzak- nice joke.
Jun 17, 2010. 10:13 AMjanzak says:
Haha sorry. I had to.
Jun 17, 2010. 9:48 AMPierce 93 says:
This would be perfect. I'm a little annoyed that it's so hard to find a DPDT switch without a middle setting. PLEASE correct me if I'm wrong but this thing should only click into two positions. http://www.galesburgelectric.com/McGill-1121-0003-DPDT-ON-ON-6-Amp-Toggle-Switch.html
Jun 17, 2010. 3:20 PMPierce 93 says:
Hey guys I know for sure now that anything 3 amps and up is good. Also, as long as the switch is DPDT and only has two settings, it's exactly what you want. I went out and bought a 3 amp dpdt switch at Radioshack for 3 bucks and it looks like it's going to work fine. It actually has a faceplate that says on|off, but don't let that deter you, it should work anyway if you wire it right. Plus, if you don't want to see the faceplate, you can remove it!
Jun 18, 2010. 10:11 PMBad2Grim says:
You sir are my hero. THANK YOU!!!!
Jun 10, 2010. 7:29 AMmara0192 says:
does the main toggle switch have to be a 5A switch? digikey is out of stock on them and all i can find elsewhere is 3A
Feb 14, 2010. 9:38 PMtniemuth95 says:
 the micro switch from digi-key isnt there anymore, or atleast the part number changed.  Could u find another one from digi-key? I'd rather not have to make separate trips/ buy from other places and pay addition shipping and handling
Feb 14, 2010. 9:55 PMtniemuth95 says:
 that or find a motor that will work from radioshack, I would prefer to buy from radioshack but if they dont have one I will buy from digi-keys.
Mar 15, 2010. 12:09 PMjeff-o says:
There's no difference between the US and Canadian Digikey sites, they have the same stock.  They just list prices in Canadian dollars instead of USD.
Feb 15, 2010. 12:53 PMtniemuth95 says:
 hmm, i got it to work.  for some reason it wasnt working last night. Thanks!
Feb 9, 2010. 1:05 PMTheReaper says:
Can i use an Ne555n timer instead if the NE555P one?
Feb 9, 2010. 4:09 PMTheReaper says:
If it wouldnt be too much trouble, could u post what it would like on a breadboard
Feb 9, 2010. 5:05 PMTheReaper says:
Thanks alot man, you seriously rule :D
Feb 13, 2010. 12:20 PMTheReaper says:
Thanks alot! i cant thank you enough :D
Feb 10, 2010. 11:11 PMToggleme says:
What would be the effect of using a 0.15 uF capacitor? My local shop only had these...
Feb 10, 2010. 8:46 PMzapedy says:
 What gauge of wire is being used
Jan 31, 2010. 10:30 AMJorgassimo says:
Is it possible to use servo with thease specs:
Servo 4.8-6.0V, output torque 4.0kg/cm/4.8V, Speed 0.25s/60degree
I havent done electronics so much but I can solder quite well. Is it too difficult for beginner to mod the servo to be continous?
1-40 of 64next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
200
Author:Frivolous Engineering(FrivolousEngineering.com)
My name is Brett Coulthard and I'm a telecommunications tech. I like to tinker/hack/make stuff. Please visit my blog at http://frivolousengineering.com
