The Most Useless Machine EVER!
Step 9Dead Bug Circuit Construction:
The circuit has very few parts so instead of making a circuit board or using a prototyping board I just soldered most of the components directly to the appropriate pins on the 555 chip.
This method of prototyping is called Dead Bug construction.  As the name implies, the finished results aren't very pretty and often resemble a dead bug.
You’ll need a fine tipped soldering iron, steady hands and basic soldering skills.
Keep in mind that you don’t have to dead bug the circuit.  Prototyping or perf board can be used for the final circuit, or just keep it on the half-size breadboard that you tested it on.
20 comments
Feb 17, 2011. 6:05 PMbio88 says:
I wonder how hard it would be to make the servo rotate 90, hit switch, wait say, 10 seconds, then rotate/return to home. All initiated by a momentary switch! That would be cool.
May 23, 2011. 12:55 PMFJMSoft says:
SaskView... I'm not a pro, but, maybe an another 555 set for 10 seconds which resets or disables first one, maybe another toggle switch will be necessary.
May 22, 2011. 7:31 PMabvnatter says:
capacitors. do your research. I'm not the best at this so please be safe. In one of my classes we were able to make LEDs pulse very slowly or quickly depending on what size resistor we threw in the line. I popped a couple caps by putting them in the circuit backward.
Mar 21, 2011. 6:35 PMBrunoG says:
maybe with a transistor and a big capacitor connected in series
May 23, 2011. 8:31 AMbpfh says:
an NE555 timer circuit would do a a great time delay - just wire the current wire that runs the finger output and plug that into the NE555 trigger... you could then turn it on, leave it on a table, wait until guests arrive and have a zombie finger appear from the box after 10 minutes!!
You could also implement the circuit with a PICAXE chip and you could make random reponses to the box, and program it to do other things (like the Useless Machine that after a preset number of times getting turned on starts spinning around on the desk before turning itself off! )
Jun 10, 2010. 3:20 PMgarrickg says:
i'm trying to troubleshoot my circuit. A big problem I'm having is the battery overheating, and smoking, even when the microswitch is pressed down.
Apr 1, 2010. 3:03 PMWhizzman says:
Since I couldn't find an answer to this question: How is C1 poled?
Feb 17, 2010. 12:54 PMinsane2642 says:
Hi,
I'm having problems with my servo, it only rotates in one direction.
I haven't modified it, and I can't see any difference between my circuit, and the ones shown here. BTW I am trying to use the 555 circuit, and don't really want to crack open my servo!
Thanks for any help.
Feb 21, 2010. 7:02 AMinsane2642 says:
Thanks for your help.
I think what happened was the connections to the toggle switch were a bit dodgy. I got a soldering iron today and put them in, and now it works like a treat!
Thanks anyway, and thanks for the instructable!
Jan 15, 2010. 1:11 PMihaveasubaru says:
This is probably something i'm going to have to figure out myself because of my wiring but i'm curious if anyone can tell me the deal...
Everything is wired up perfect, exactly like Sask's schematic. Checked 40 times over...and for some reason it works with and without the micro-switch.
when the microswitch is in its normal up position and the toggle is hit, the servo rotates up, then the toggle is hit again and it goes back to where it was. it also works like it should in the instructable. hmm
It's not really problem im just curious if anyone knows the reason.
ok, Awesome instructable, thanks for the inspiration!
Feb 8, 2010. 6:09 PMihaveasubaru says:
got it to work! thanks! awesome instructable...
http://www.youtube.com/watch?v=NPDU7pLXSDo
Feb 5, 2010. 2:53 PMkingbling11 says:
 Mine wont work!!!
I have wired it matching yours (Switch in second configuration) (Pic of second machine) and it simply does nothing when i turn it on!!
I can make the servo wiggle about a bit by connecting pins 2 and 3 together with a probe. I multimeter tested the servo power and its getting 5.5 volts when the batteries are giving off 5.8.
Anybody got any ideas as to why its not working?
 Thanks in advance.
Jan 30, 2010. 2:44 PMbreakspeare832 says:
What is C2?
Jan 30, 2010. 4:37 PMDerekMellott says:
c2 was deleted, it was not needed.
Jan 31, 2010. 12:14 PMbreakspeare832 says:
thanks for the info
Jan 30, 2010. 8:12 AMbreakspeare832 says:
Could you please show how to wire this on a breadboard?
Jan 20, 2010. 10:18 AMmaxximerus says:
Hey, I've got a question.
I'm trying to build one myself. Ordered all the parts to make the circuit first. But now I'm wondering. The 555 has got 8 pins. 4 on each side. How do I know which pin is what? There are no numerbers what so ever on it.
When It's done I'll post a video of it. Just have to make it work first. haha.
Jan 25, 2010. 9:38 PMRazormann242 says:
maxximerus
There will be a small dot on the top of the 555, that will be the number one, pins facing down, left side, from there it goes 1234 and from the bottem up right side 5678. hope that helps...Ray
Jan 18, 2010. 8:42 PMjazzluvr says:
my servo is only turning a 1/4 turn, everything looks right - even rewired twice to double check... same result.
any suggestions?
Jan 18, 2010. 9:00 PMpoorsob says:
I had the same problem.  I put another 15k resister in parallel with the 15k resister that was already there.  This turns it into a 7.5K and makes the stroke about 1/2 a turn.
Jan 18, 2010. 9:27 PMjazzluvr says:
perfect. that worked.  thanks for the help. so the amount of current controls the amount the servo turns.
Jan 13, 2010. 7:57 PMChild of Strife says:
Heeeeeey... hi. im only 12 and, kind of new to all this stuff, have little supplies and a very low budget. my biggest problem is the whole soldering thing, is there some way i could dead bug it without a soldering iron? Or is there some other method i could use that does not require soldering?
thx,
Child of Strife-- childofstrife@gmail.com
comments end here
cut along dotted line
Jan 15, 2010. 2:50 AMzakerid says:
a switch with screw terminals would start you in the right direction.
like this one-
cgi.ebay.com/ebaymotors/TOGGLE-SWITCH-DPDT-20-amp-12-volts-2-ea_W0QQcmdZViewItemQQhashZitem35a63deea7QQitemZ230422343335QQptZRaceQ5fCarQ5fParts
using the modified servo without the 555 circuit would be the way to go.
Jan 15, 2010. 12:12 PMChild of Strife says:
thanks, but, like i said, im very new to this stuff and i dont understand exactly what you mean by "modified servo," so if you could point out where i could find one of these, that would be great,
thx.
comments end here
Jan 7, 2010. 6:07 AMbeware87 says:
I have a question about the servo it has 3 wires 1 black(i supose is for the -) 1 red(for the +) and 1 white (i supose for the conection 3 of the servo) am i correct?
Thanks
Jan 11, 2010. 2:43 PMcrawbridge says:
 Yes. The black will go to ground, 1 on the 555 chip, a yellow, which should go to 3 on the 555 chip and a red which should go to pin 4.
Jan 6, 2010. 5:44 PMfordman15243 says:
(Sorry, another stupid question coming...) Can you tell me where the black wire for the servo goes to on the 555? I can't see on the picture...
Jan 8, 2010. 8:00 AMfordman15243 says:
ok, thank you! =)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
200
Author:Frivolous Engineering(FrivolousEngineering.com)
My name is Brett Coulthard and I'm a telecommunications tech. I like to tinker/hack/make stuff. Please visit my blog at http://frivolousengineering.com
