loading
Step 5: Time to bring this animal to life.
Step 5:
I had mapped out roughly were the top of the hair line would be by this point so that it didn't hang down over the eyes too much!
1. To create the teeth i just used some left over foam (nothing gets wasted here!) and cut them in to the shape until they resemble that of Animals. I also painted them white although the more i worked on the mask while they were attached the paint started to cracked here and there which actually gave it more of a real look. To attache them to the mouth i just sewed them to the mask behind the lip.
2. For the Eyes again i took some left over orange felt which i glued to the bottom of them to create an eyelid. I first however painted them white giving them about 3/4 coats to really give them an unreal look, then glued on two circular black felt eyes which i had cut out earlier. To get the shine on them i used clingfilm tightly wrapped around each eye, although I'm sure there maybe other ways to achieve this. I attached the eyes to the face by super gluing the bottom eyelid that i had attached directly to the mask. It takes a bit of doing get the right position for the eyes, but just keep movin' them about holding them in with needles until you are happy.
3. For the eyebrows i cut a feather boa in half and bent the cut stripes in half again to thickin'. I then sewed on each eyebrow just above each eye, sewing directly onto the mask. I only added like one stitch either side of the eyebrow so that the feather boa had some room to move about and give that crazy Animal look.
So glad I found this. Been wanting to do Animal for a few years and this allowed me to finally pull it off. Great project!
<p>love your animal, can I ask what size measurements you used for the head? Its a bit hard to get from such a small picture.. thanks</p>
I wanted to thank you for putting up this project. Using the helmet out of foam, I made the Count von Count costume which turned out great.
<p>Hey Avital, thank you so much for your comments! Glad to hear this instructable helped. Would love to see a pic of your Count Mask, if possible? Plan to make a few more this year! </p>
Hello I hope you still access this site. I need some further explanation on the mouth portion. I am so confused. Please tell me where the tights connect to the mask I understand how to do it but just not where :( <br>
Hi Coco, sorry i wasn't able to reply to this message before Halloween as i was out of the country with no internet. I hope you where able to sort the Mouth Issue out? Or if you still require help just let me know. Thank you.
Just wanted to say thank you for the detailed and quite helpful instructions. <br> <br>Thanks to you I was, needless to say, the hit of the party. <br> <br>
Thank you so much for your kind comment Elephino. So glad my instructable was able to help you out! The Costume looks amazing. Cheers also for posting a picture. ROCK ON \m/
Hey All,<br><br>Just wanted to drop a quick message to say that I'm planning on adding an extra step to the Instructable to show of everyone's finished Animal Heads they have created. I have been sent a couple already and see one an here, they just look amazing! <br><br>If you could send me the a finished picture of your Animal Head pic:<br><br>Nathan_thomas_gunn@hotmail.co.uk<br><br>I'll upload it here as well as add a link to your instructable site for a bit of promo if you would like also. Not forgetting a link to the new Muppets Movie site.<br><br>Thanks again to everyone for the comments and taken the time to give this a bash.<br><br>Nath.
gfdfgh
Thank you so much for making your design available on the web! I followed your instructions and made an amazing Animal head for Halloween. Everyone loved it!
Hey Saries, glad to hear my instructable was so useful to you :D Be sure to post some pictures would be great to see the finished product \m/
Done!
That looks ACE \m/. Delighted with the idea of wearing one of those Orange Lycra suits underneath to give your skin that actual Muppet look. Amazing!! <br>
Hi Nath,<br><br>Great project! I'm off to go buy some foam, but can you clarify one thing for me: in the list of stuff you used it says 1/2 inch foam, but looking at the pictures and comparing it to whats in the store it looks more like 1 inch. Can you clarify which you used/which you would suggest? the 1/2 inch doesn't look all that stiff.<br><br>Thanks!<br>Dave
Hi Dave, thanks for the message. Sorry about that it should actually be 1&quot; just realized the mistake now. Thanks for the heads up!<br><br>Although you do get different types of foam, some or more durable than others, so you can get away with it being slightly thinner aka 1/2inch. The best plan of action would be to go for 1inch, and see how that feels in terms of durability, then from there it size can be adjusted.<br><br>Hope that helps. If you (or anybody) have any other questions feel free to give me a shout. <br><br>thanks, Nath
this is the only step that confuses me... could you possibly clarify? i really want to make one of these for my boyfriend, he is a drummer :)<br>where does the pictured wire structure sit inside the mask? did you put the tights on after gluing the wires in place? i do not really understand :(
The wire structure is only used to work out how far in the tights need to be without them hitting your nose when you put the mask on and take it off. <br><br>If you take the middle part of the wire structure and basically glue/tape that inside the mask from the middle of the top lip to the middle of the bottom lip then try putting the mask on. If the wire isn't hitting your nose but there's still a lot of room to play with try adding some more length or bend to the wire. Once you make the tweaks to the point you are able to out the mask on with minimal to no contact with the wire, then the next step is to take a longer piece of wire and basically tape/glue the end on from cheek to cheek making sure that it also get's attached to the wire you have already in place to the front of it. Again try the mask on once in place to make sure it does not hit your nose again.<br><br>The next stage is to stretch the tights right over the mouth making sure you give up enough slack for them to hit the back of your wire structure that is in place. You will find it easier to peg the tights to the top and bottom lip as you are doing this, again making sure there is some slack on for the tights to hit the back of the structure. <br><br>Once you have it pegged in place again try the mask on and make sure it does not hit your nose (have said that quite a lot now :P )<br><br>Next step is to glue on the top lip from the inside and again for the bottom lip. I found it easier to do it in stages - unpegging to add the glue and adding the peg to help the glue set. <br><br>Once the glue has set REMOVE the wire structure. You should now be able to wear your mask without your nose protruding from the mouth. <br><br>Hope these instructions are more helpful. If not please let me know and I'll do my best to add some visual instructions. <br><br>Good luck, Nath
This is fantastic, and I can actually see what improvements I'd need to do to it, to make an Elmo, Oscar &amp;/or Ernie mask. Or just one to hang on the wall to scare the be-jesus out of my cats. I love Animal. I have a ball cap of him and a glow in the dark t-shirt. :D :D :D
Hey Tricorvus, hopefully the design will be of use to you (although your cats may not be so impressed!). I agree that the design could be very easily adapted into just about any Muppet. I'm hoping people will try out some new designs based on mine and post them here - can't wait to see what everyone comes up with! :)
GRUNT (is what he says)
i don't ken who the girl is, but top notch creativity on the costume &amp; i'm willing to bet wi'out the mask she's hot!
She's the co-creator, and yes... she is! ;)
Oh my god. I was going to make my Animal costume in a completely different manner, and im glad you posted this, bc I might have to do it this way. If and when I finish, I will be sure to post pics in the comments. <br><br>AMAZING!
Please do! Looking forward to see the results! If there are any steps in the guide that are unclear or you want any more info let me know :)
this is amazing!! wow, i'm really stunned by your craftsmanship. great job!
Thanks! It was a lot of fun and kept me out of trouble for a few evenings! ;)
Great great job with this. How much did all the supplies run for this project?
Hey Belcher, thanks for the comments. <br><br>All the supplies cost me around &pound;25, although I did phone up my local furniture supply store regarding the foam. They were only too happy to give me what I needed as they had loads waiting to be dumped. I can't promise that would be the case where you are, but you might get lucky. <br><br>Any other questions feel free to give me a shout. <br><br>Thanks, Nath.
About This Instructable
43,586views
151favorites
License:
More by normanthybeast:The Muppet Man Project The Muppet Project
Add instructable to:
