Introduction: The NB-4 Pistol
Picture of The NB-4 Pistol
Check my Sipriani V3.0 too!
Here it is!
It's a powerful 5 shot gun with an average range of 50 to 60 ft.
If you're bored or something try to decode the name.
I especially like this gun because of it's smooth lines and it can pack one heck of a punch for a gun of it's size.
Heres some pro's and no's:
Pros:
-Great Range
-Great Performance
-Magazine never jams
-Looks "slick"
No's:
-Lots of parts for a pistol
-A 5 shot mag which might be short when you're in a knex war (The El Diablo's mag can be used on this gun if you want to go in combat).
Like it?
Building time, then!
Step 1: Strength Sides
Picture of Strength Sides
These parts are for added body strength and might even be required for a gun that must be able to survive itself.
Step 2: Mag Sides
Picture of Mag Sides
These are the mag sides which keep the bullets in place.
Step 3: Mag Pusher
Picture of Mag Pusher
This is the part which pulls up the bullets for a auto-reload
Step 4: Firing Rod
Picture of Firing Rod
This part is the part which actually fires the bullets.
I used a small amount of tape first, and then a rubberband wrapped around it, to make it less of an impact on the gun.
Step 5: Trigger
Picture of Trigger
This is the new trigger.
It's asymetrical, so you might have to put the tans on the other side of the trigger if you're a righty.
Step 6: Mag Front and Rear
Picture of Mag Front and Rear
These bits are the actual mag tip.
Step 7: Handle
Picture of Handle
Having trouble?
Ask it in a comment.
Step 8: Barrel
Picture of Barrel
This is the part which holds the loaded bullet until it's fired.
Step 9: Assembly
Picture of Assembly
Having Trouble?
Ask it in a Comment and i'll reply as soon as possible.
Step 10: You're Done!!!
Picture of You're Done!!!
Well, well, well.
You've got yourself the first NB-4 weaponry.
Have freaking much fun with my knex guns!!!
-Viccie.B1993-
~KnexBuild~ (author)2012-02-03
I made this and it is awesome. 5 stars.
~Meme~ (author)2012-01-28
I love it. Best pistol ever!!!!!!!!!!!. (Its better than oblivitus's ultra pistol 2).
Fred the evil puppet (author)2011-03-20
What does NB-4 actually stand for?
I was a GTA IV addict back when i made this, so it's a short for 'N'iko 'B'ellic from GTA '4'
skyfaller (author)Skreetsha2011-03-24
It could also stand for... Not bad ''4'' (a) pistol. :D
Skreetsha (author)skyfaller2011-03-26
Lol, didn't even think of that one. Thanks man
skyfaller (author)Skreetsha2011-03-31
I said it for fun, but i guess your welcome.
DracoUltima (author)2011-02-06
Is this gun's range as he says it is? I'm somewhat skeptical about 60 feet.....I'll start building when I get home.
Skreetsha (author)DracoUltima2011-02-08
60 Might be a bit high, but that's about the highest i ever got. It averages in at around 45 feet.
DracoUltima (author)Skreetsha2011-02-14
I get around 40, not bad but I like your RX9 better.
Skreetsha (author)DracoUltima2011-02-15
The inverted crossbow? Ye, i really liked that 1 too. Thanks
DracoUltima (author)Skreetsha2011-02-15
Be sure to check on my new sub machine gun. It uses a rail system, not very strong but something unique, it will be posted within a day or two.
SomeAsianKid (author)2011-01-27
I added a slide to it, it works great thanks :DDD
Heres the slide :D
rrr67 (author)2010-01-24
wtflagnod  is actually inside
killersir751 (author)rrr672010-10-27
a zig-zag of red triangular connectors
knex shooter (author)2010-05-16
 builded :) its ok :)    accurate, quite powerful (2 red postman bands) yeah its ok - jams frequently tho
knex shooter (author)2010-05-12
 im confused, do you build 4 pieces, or is picture 2 another angle of picture 1 ?
CODKING (author)2010-05-07
get a of the top and 1 of the bottom pleeease
Living The Dead (author)2010-04-24
Other Guns INB4
Oh wait
JaymzFlipper (author)2010-03-14
 Im half a second old and made this in one hundredth of a second!!!
I GOT YOU ALL BEAT!!
mister97 (author)2009-07-21
ok this made me stop making the gun its confusing, frustrating, and i thought i needed 2 more pieces but i needed 4 more
blastboydanny (author)mister972010-02-11
it stoped me u realy need more pictures of differnent angles and step by stap instructions to make the complicated bits it looks like a good gun but bad instructable 1*
Merugop (author)mister972009-12-26
 its kind of easy
linkkiller (author)2009-05-22
is the white rod the same as the gray rod
coreyt (author)linkkiller2009-07-08
no a white rod dosent bend a grey will if you dont have a white or clear as i would think use a black one its not the best but it works
Pizzapie500 (author)coreyt2010-01-19
I know this is a really late reply, but where do you get the clear rods? I looked for it on knex.com and I couldn't find it. If you find it can you give me a link?
cool bas3 (author)Pizzapie5002010-02-02
you get them in the knex starbust spinner set
but there are only 2 of them in that set
Yea.
sanchixx (author)2010-01-31
i cant make the barrel
~Z~ (author)2010-01-26
not bad for pistol?
KnexFreek (author)2010-01-21
The NB-4 Pistol =
The NoodlesBeefcake-4 Pistol
Seleziona (author)KnexFreek2010-01-26
LOL
KnexFreek (author)Seleziona2010-01-26
 lol
just pull back the ram really hard until u can see the mag pusher move up but not too hard  or it will break the gun.
are those the blue spacers from step 1 or are they new
are the blue spacers needed now or in a later step? im confused... :-0
Merugop (author)2009-12-27
 I am making a smaller version of the NB-4pistol can i post it as the NB-3 pistol (with of course credits to you)?
Spc force (author)2009-07-29
does it reli matter what is in the inside???
mettaurlover (author)Spc force2009-08-10
yes, actually, it does. just try building my gun without caring about the innards. it's MUCH simpler than this. you'll end up with a piece of crap that doesn't work. built correctly, it's actually very easy to us, and gets great force and range.
Merugop (author)mettaurlover2009-12-26
 no it odesn't only between the green connectors is important.
knex_mepalm (author)mettaurlover2009-08-19
im working on a bigger barrel designed for biggger rounds but with a twist, the ram has 0 friction (from the barrel anyways)
mettaurlover (author)knex_mepalm2009-08-19
nice. mine doesn't even have a ram; no wasted energy.
there would be wasrted energy from the notion of it snapping back into the position and it rubbing the sides
mettaurlover (author)knex_mepalm2009-08-20
not so much; it's as low friction as a barrel can be. also, the ammo isn't attached to the RB, therefore eliminating the problem. no unnecessary wasted energy.
Merugop (author)2009-12-26
 lol i can make this gun without instuctions i made it like 10 times
Killbunny (author)2009-12-14
It's exactly the El Diablo's handle.
I mean EXACTLY. Except for ONE PIECE.
Merugop (author)Killbunny2009-12-26
the first gun i made on Ible and its still my favo
 Is it forbidden to copy one of your own guns?
Killer~SafeCracker (author)2009-08-23
My friend shot me in the neck with this. It hurts.
About This Instructable
7,020views
17favorites
Bio: Favourite games are LittleBigPlanet2 and Gran Turismo 5. Favourite music genre is drum and bass, but my current favourite song is Gorillaz - Clint Eastwood. I ... More »
More by Skreetsha:A-600 "Low Ridah" ChopperStuart W.R. V4.0The Sipriani Rifle V3.0 (FT210)
Add instructable to:
