The NRF24L01 Wireless Motor Speed Control System With Arduino
Published
Introduction: The NRF24L01 Wireless Motor Speed Control System With Arduino
About: www.ICStation.com is a top store of electronic, which specializes in all kinds of IC products, such IC accessories, Module, Robots, Development Board, Transistor, Capacitor and so on. We're located in She...
ICStation team introduce you the NRF24L01 Wireless Motor Speed Control System.This system works under DC 5V voltage. It uses the NRF24L01 Wireless Module to transmit speed control data and the Hall Sensor to detect the real rotate speed. This design uses the PWM duty cycle to modulate and realize the speed control.What’s more, It can be used in the
situation which do not need high speed control precision, such as the automatic control of the curtain.
Functions:
1)When initialize the sending part, the LCD1602 board displays the characters of the original PMW data and the speed which is with zero. The receiving part will control the wireless transmission of data and displays the real rotate
speed after the receiving part finished the initialization.
2) When the Receiving Module works, the rotate speed of the Motor will change according to the data which is transmitted by the sending part. The Holl Sensor Speed Measure Module begins to detect the rotate speed and the LED light of the Holl sensor lights. Meanwhile, the Wireless Module of the receiving part will send the detected rotate speed data back to the Sending part.
3) For the sending part, we need four keys (K0,K1,K2,K3) in the keyboard to change the speed of the motor. The associated functions of the four keys as following:
①Press the key KO for the first time, the motor moves as the first gear of speed; press the key KO again, the motor moves as the second gear of speed; the third time when we press the key KO, the motor moves as the third gear of speed; the,forth time when we press the K0,,the motor moves as the first gear of speed.
②Press the key K1, we can switch the rotate speed of increasing or reducing.
③Press the key K2, we can change the rotate speed to five more or less.
④Press the key K3, we can change the rotate speed to ten more or less.
Code for reference:
http://www.icstation.com/newsletter/eMarketing/NRF24L01_Control_Code.zip
Step 1: Components List:
Step 2: Schematic Diagram
Step 3: The Connection of Receiving Part
1.Connect the NRF24L01 Wireless Module to the ICStation UNO.
SCK--Digital pin 13 ;MOSI-- Digital pin 11 CS——Digital pin 7;
CS——Digital pin 8;MOSI-- Digital pin 12
2.Connect the L298N to the ICStation UNO
VMS—7.2V Anode;GND—Cathode INA—GND;
INB—VCC(5V);ENA—Digital pin 5
3.Connect the Hall Module to the ICStation UNO
DOUT—Digital pin 3
Step 4: The Connection of Sending Part
1.Connect the NRF24L01 Wireless Module to the ICStation MEGA2560
SCK--Digital pin 52 ;MOSI-- Digital pin 51 MOSI--Digital pin 50;
CS——Digital pin 9 CE——Digital pin 8
2.Connect the 1602 LCD Module to the ICStation MEGA2560
SCL—A5 ;SDA—A4
3.Connect the keyboard to the ICStation MEGA2560
S1—Digital pin 22;S1—Digital pin 23 S1—Digital pin 24;S1—Digital pin 25
Step 5: Video to Show Effect
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    5 Discussions
    gspir
    1 year ago
    Sorry, but why the hell you are using this terrible and non-friendly ancient method to give insturction of how to make it work ? "next page" then "next page" like being in 1980's. Never heard about youtube and video tutorials ?
    The code for reference is not working, can you please give me an updated version.
    the nrf data sending is not working
    if i use a joystick on behalf of the key pad than what will be the sketch?for speedjet and speedsend and it is a nice project
    I am familiar with applications concerning nRF24l01 transceiver. And I ensure the is very hard to consider that you can use it with Joystick. If you take a look on what protocol it uses you will find : SPI protocol which is seemed not to be used in LTI (Linear time invariant) systems which utilize the Buffer size formula. If you wanna use a real time system to control a DC motor with live PWM signal you may head to a UART module like APC220 transceiver which based on RX & TX method. If you have any questionnaire, we can discuss it together.
    Sincerely,
    Abd El-Rahman Oreiby
