3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Near-Perfect Tent: Design and Build a Recycled Tent
Step 10Tent Assembly
Tent Assembly
This is simpler than it may seem. Just pin and sew the four walls to the roof, one at a time, then sew the walls to each other along the corner seams.
I started with the front doors, then did the back wall, then sewed in the side doors. Once all four walls were sewn to the roof, I sewed the vertical, or corner seams together one at a time.
Leave the top four corners unsewn in the last inch or two so as to attach the webbing for the poles and guy lines.
Then sew in the floor in the same way. On three of your walls, you'll be sewing the door zippers to the floor. This is only slightly harder than sewing the tops of the walls to the roof. You just need to make sure that when you sew the two zippers in together that you don't crowd the teeth too much or run over them with your stitch. There were several points where I sewed through the zipper teeth doing this and had to rip the seam back open. It sucked, but it all works out in the end, so just be careful and be thorough when you pin the seams together.
Remember that you'll be turning the tent inside out to make these seams (just like a pair of pants or a T-shirt) so that they'll look neat from the outside...
**Again, I suggest leaving the floor and ceiling corners unsewn at this point. Just sew the seams shut to within an inch or so of the corners. It's easier to add all of the webbing for stakes and lines all at once after the tent is fully assmebled.
I did this step all in one semi-intense go, and didn't take pictures of the process. From the standpoint of assembly it's as easy as putting together a little model house. From the perspective of process it's a little harder, but not unlike anything you have to do up to this point. I've included some photos to to give a sense of how this is done below.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
43
Author:bentm
just some fella
